楼主: roiff
[进阶教程] 一次性付费6块钱让你拥有内网穿透和一个壳域名,超稳!
发表于 2018-9-30 22:14:34 | 显示全部楼层
菲神,天天练n1,我装的docker,用linux命令提示错误
发表于 2018-11-2 22:18:11 | 显示全部楼层
6块钱付了,没有成功
发表于 2018-11-3 07:53:04 | 显示全部楼层
顶楼主到天花板!!!
发表于 2018-11-17 10:41:48 | 显示全部楼层
支持@!!!!
发表于 2018-11-29 17:11:42 | 显示全部楼层
为什么N1上 不可以用
root@amlogic:/tmp# sudo chmod 777 phddns_rapi_3.0.2.armhf.deb
root@amlogic:/tmp# sudo dpkg -i phddns_rapi_3.0.2.armhf.deb
(Reading database ... 45907 files and directories currently installed.)
Preparing to unpack phddns_rapi_3.0.2.armhf.deb ...
/var/lib/dpkg/info/phddns.prerm: 26: [: 1843: unexpected operator
Remove Phddns Service Success.
Unpacking phddns:armhf (3.0.2) over (3.0.1) ...
Setting up phddns:armhf (3.0.2) ...
/var/lib/dpkg/info/phddns.postinst: 16: [: 1843: unexpected operator
/var/lib/dpkg/info/phddns.postinst: 30: /var/lib/dpkg/info/phddns.postinst: /usr/orayapp/oraysl: not found
dpkg: error processing package phddns:armhf (--install):
installed phddns:armhf package post-installation script subprocess returned error exit status 127
Processing triggers for systemd (237-3ubuntu10) ...
Errors were encountered while processing:
phddns:armhf
发表于 2018-12-1 20:04:36 来自手机 | 显示全部楼层
感谢菲神
发表于 2018-12-1 20:07:06 来自手机 | 显示全部楼层
我起学习
发表于 2018-12-1 22:12:36 | 显示全部楼层
折腾半天一致安装错误
发表于 2018-12-5 08:21:44 | 显示全部楼层
300y 发表于 2017-10-1 15:40
hass.io的话 用duckdns吧 方便
我是hass.io,你告诉我一下怎么弄内网穿透
发表于 2020-6-10 10:16:05 | 显示全部楼层
感谢大神
GMT+8, 2025-9-14 03:19 , Processed in 0.681594 second(s), 8 queries , MemCached On.
