楼主: lidicn
Debian10安装Hassio
发表于 2019-11-1 22:10:04 | 显示全部楼层
发表于 2019-11-2 08:41:22 | 显示全部楼层
学习一下!!!!!
发表于 2019-11-3 12:46:11 | 显示全部楼层
ganxiefenxiang
发表于 2019-11-3 13:25:58 | 显示全部楼层
求助。。每次都是在 Setting up modemmanager 卡住,需要重启树莓派。连接的网络也会出问题。
pi@raspberrypi:~ $ sudo apt-get install bash \
> jq \
> curl \
> avahi-daemon \
> dbus \
> apparmor-utils \
> network-manager
Reading package lists... Done
Building dependency tree
Reading state information... Done
avahi-daemon is already the newest version (0.7-4+b1).
bash is already the newest version (5.0-4).
curl is already the newest version (7.64.0-4).
dbus is already the newest version (1.12.16-1).
dbus set to manually installed.
The following additional packages will be installed:
  apparmor dns-root-data dnsmasq-base libbluetooth3 libgudev-1.0-0 libjansson4
  libjq1 libmbim-glib4 libmbim-proxy libmm-glib0 libndp0 libnm0 libonig5
  libpcap0.8 libqmi-glib5 libqmi-proxy libteamdctl0 modemmanager ppp
  python3-apparmor python3-libapparmor
Suggested packages:
  apparmor-profiles-extra vim-addon-manager libteam-utils
The following NEW packages will be installed:
  apparmor apparmor-utils dns-root-data dnsmasq-base jq libbluetooth3
  libgudev-1.0-0 libjansson4 libjq1 libmbim-glib4 libmbim-proxy libmm-glib0
  libndp0 libnm0 libonig5 libpcap0.8 libqmi-glib5 libqmi-proxy libteamdctl0
  modemmanager network-manager ppp python3-apparmor python3-libapparmor
0 upgraded, 24 newly installed, 0 to remove and 0 not upgraded.
Need to get 7,468 kB of archives.
After this operation, 25.7 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:2 http://archive.raspberrypi.org/debian buster/main armhf libbluetooth3 armhf 5.50-1+rpt1 [93.3 kB]
Get:3 http://archive.raspberrypi.org/debian buster/main armhf dnsmasq-base armhf 2.80-1+rpt1 [400 kB]
Get:1 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libjansson4 armhf 2.12-1 [34.6 kB]
Get:4 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libmm-glib0 armhf 1.10.0-1 [903 kB]
Get:5 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libndp0 armhf 1.6-1 [9,328 B]
Get:6 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libnm0 armhf 1.14.6-2 [294 kB]
Get:7 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libteamdctl0 armhf 1.28-1 [10.1 kB]
Get:8 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf network-manager armhf 1.14.6-2 [2,135 kB]
Get:9 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf apparmor armhf 2.13.2-10 [438 kB]
Get:10 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf python3-libapparmor armhf 2.13.2-10 [85.0 kB]
Get:11 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf python3-apparmor armhf 2.13.2-10 [141 kB]
Get:12 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf apparmor-utils armhf 2.13.2-10 [114 kB]
Get:13 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf dns-root-data all 2019031302 [5,396 B]
Get:14 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libonig5 armhf 6.9.1-1 [150 kB]
Get:15 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libjq1 armhf 1.5+dfsg-2+b1 [119 kB]
Get:16 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf jq armhf 1.5+dfsg-2+b1 [59.3 kB]
Get:17 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libgudev-1.0-0 armhf 232-2+rpi1 [11.8 kB]
Get:18 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libmbim-glib4 armhf 1.18.0-1 [142 kB]
Get:19 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libmbim-proxy armhf 1.18.0-1 [70.7 kB]
Get:20 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libpcap0.8 armhf 1.8.1-6 [124 kB]
Get:21 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libqmi-glib5 armhf 1.22.0-1.2 [443 kB]
Get:22 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf libqmi-proxy armhf 1.22.0-1.2 [9,032 B]
Get:23 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf modemmanager armhf 1.10.0-1 [1,363 kB]
Get:24 http://mirrors.ocf.berkeley.edu/raspbian/raspbian buster/main armhf ppp armhf 2.4.7-2+4.1 [312 kB]
Fetched 7,468 kB in 48s (155 kB/s)
Preconfiguring packages ...
Selecting previously unselected package libbluetooth3:armhf.
(Reading database ... 41220 files and directories currently installed.)
Preparing to unpack .../00-libbluetooth3_5.50-1+rpt1_armhf.deb ...
Unpacking libbluetooth3:armhf (5.50-1+rpt1) ...
Selecting previously unselected package libjansson4:armhf.
Preparing to unpack .../01-libjansson4_2.12-1_armhf.deb ...
Unpacking libjansson4:armhf (2.12-1) ...
Selecting previously unselected package libmm-glib0:armhf.
Preparing to unpack .../02-libmm-glib0_1.10.0-1_armhf.deb ...
Unpacking libmm-glib0:armhf (1.10.0-1) ...
Selecting previously unselected package libndp0:armhf.
Preparing to unpack .../03-libndp0_1.6-1_armhf.deb ...
Unpacking libndp0:armhf (1.6-1) ...
Selecting previously unselected package libnm0:armhf.
Preparing to unpack .../04-libnm0_1.14.6-2_armhf.deb ...
Unpacking libnm0:armhf (1.14.6-2) ...
Selecting previously unselected package libteamdctl0:armhf.
Preparing to unpack .../05-libteamdctl0_1.28-1_armhf.deb ...
Unpacking libteamdctl0:armhf (1.28-1) ...
Selecting previously unselected package network-manager.
Preparing to unpack .../06-network-manager_1.14.6-2_armhf.deb ...
Unpacking network-manager (1.14.6-2) ...
Selecting previously unselected package apparmor.
Preparing to unpack .../07-apparmor_2.13.2-10_armhf.deb ...
Unpacking apparmor (2.13.2-10) ...
Selecting previously unselected package python3-libapparmor.
Preparing to unpack .../08-python3-libapparmor_2.13.2-10_armhf.deb ...
Unpacking python3-libapparmor (2.13.2-10) ...
Selecting previously unselected package python3-apparmor.
Preparing to unpack .../09-python3-apparmor_2.13.2-10_armhf.deb ...
Unpacking python3-apparmor (2.13.2-10) ...
Selecting previously unselected package apparmor-utils.
Preparing to unpack .../10-apparmor-utils_2.13.2-10_armhf.deb ...
Unpacking apparmor-utils (2.13.2-10) ...
Selecting previously unselected package dns-root-data.
Preparing to unpack .../11-dns-root-data_2019031302_all.deb ...
Unpacking dns-root-data (2019031302) ...
Selecting previously unselected package dnsmasq-base.
Preparing to unpack .../12-dnsmasq-base_2.80-1+rpt1_armhf.deb ...
Unpacking dnsmasq-base (2.80-1+rpt1) ...
Selecting previously unselected package libonig5:armhf.
Preparing to unpack .../13-libonig5_6.9.1-1_armhf.deb ...
Unpacking libonig5:armhf (6.9.1-1) ...
Selecting previously unselected package libjq1:armhf.
Preparing to unpack .../14-libjq1_1.5+dfsg-2+b1_armhf.deb ...
Unpacking libjq1:armhf (1.5+dfsg-2+b1) ...
Selecting previously unselected package jq.
Preparing to unpack .../15-jq_1.5+dfsg-2+b1_armhf.deb ...
Unpacking jq (1.5+dfsg-2+b1) ...
Selecting previously unselected package libgudev-1.0-0:armhf.
Preparing to unpack .../16-libgudev-1.0-0_232-2+rpi1_armhf.deb ...
Unpacking libgudev-1.0-0:armhf (232-2+rpi1) ...
Selecting previously unselected package libmbim-glib4:armhf.
Preparing to unpack .../17-libmbim-glib4_1.18.0-1_armhf.deb ...
Unpacking libmbim-glib4:armhf (1.18.0-1) ...
Selecting previously unselected package libmbim-proxy.
Preparing to unpack .../18-libmbim-proxy_1.18.0-1_armhf.deb ...
Unpacking libmbim-proxy (1.18.0-1) ...
Selecting previously unselected package libpcap0.8:armhf.
Preparing to unpack .../19-libpcap0.8_1.8.1-6_armhf.deb ...
Unpacking libpcap0.8:armhf (1.8.1-6) ...
Selecting previously unselected package libqmi-glib5:armhf.
Preparing to unpack .../20-libqmi-glib5_1.22.0-1.2_armhf.deb ...
Unpacking libqmi-glib5:armhf (1.22.0-1.2) ...
Selecting previously unselected package libqmi-proxy.
Preparing to unpack .../21-libqmi-proxy_1.22.0-1.2_armhf.deb ...
Unpacking libqmi-proxy (1.22.0-1.2) ...
Selecting previously unselected package modemmanager.
Preparing to unpack .../22-modemmanager_1.10.0-1_armhf.deb ...
Unpacking modemmanager (1.10.0-1) ...
Selecting previously unselected package ppp.
Preparing to unpack .../23-ppp_2.4.7-2+4.1_armhf.deb ...
Unpacking ppp (2.4.7-2+4.1) ...
Setting up python3-libapparmor (2.13.2-10) ...
Setting up dnsmasq-base (2.80-1+rpt1) ...
Setting up libjansson4:armhf (2.12-1) ...
Setting up dns-root-data (2019031302) ...
Setting up apparmor (2.13.2-10) ...
Created symlink /etc/systemd/system/sysinit.target.wants/apparmor.service → /lib/systemd/system/apparmor.service.
Setting up libpcap0.8:armhf (1.8.1-6) ...
Setting up libteamdctl0:armhf (1.28-1) ...
Setting up libnm0:armhf (1.14.6-2) ...
Setting up ppp (2.4.7-2+4.1) ...
Created symlink /etc/systemd/system/multi-user.target.wants/pppd-dns.service → /lib/systemd/system/pppd-dns.service.
Setting up libmm-glib0:armhf (1.10.0-1) ...
Setting up libbluetooth3:armhf (5.50-1+rpt1) ...
Setting up python3-apparmor (2.13.2-10) ...
Setting up libndp0:armhf (1.6-1) ...
Setting up libonig5:armhf (6.9.1-1) ...
Setting up libgudev-1.0-0:armhf (232-2+rpi1) ...
Setting up libmbim-glib4:armhf (1.18.0-1) ...
Setting up libjq1:armhf (1.5+dfsg-2+b1) ...
Setting up network-manager (1.14.6-2) ...
Created symlink /etc/systemd/system/dbus-org.freedesktop.nm-dispatcher.service → /lib/systemd/system/NetworkManager-dispatcher.service.
Created symlink /etc/systemd/system/network-online.target.wants/NetworkManager-wait-online.service → /lib/systemd/system/NetworkManager-wait-online.service.
Created symlink /etc/systemd/system/multi-user.target.wants/NetworkManager.service → /lib/systemd/system/NetworkManager.service.
Setting up libmbim-proxy (1.18.0-1) ...
Setting up apparmor-utils (2.13.2-10) ...
Setting up jq (1.5+dfsg-2+b1) ...
Setting up libqmi-glib5:armhf (1.22.0-1.2) ...
Setting up libqmi-proxy (1.22.0-1.2) ...
Setting up modemmanager (1.10.0-1) ...
发表于 2019-11-3 13:27:01 | 显示全部楼层
用脚本安装也是。奔溃。
发表于 2019-11-3 14:43:13 | 显示全部楼层
感谢分享!
ggkk
发表于 2019-11-3 19:46:08 | 显示全部楼层
学习学习
发表于 2019-11-3 23:35:22 | 显示全部楼层
好好学习
发表于 2019-11-4 02:40:38 | 显示全部楼层
好好学习
发表于 2019-11-4 12:34:07 来自手机 | 显示全部楼层
学习学习
GMT+8, 2025-6-29 16:57 , Processed in 1.576059 second(s), 22 queries .
