查看: 481015|回复: 347
[插件集成] 小米电风扇卡片(重新写)
发表于 2019-10-14 17:24:32 | 显示全部楼层 |阅读模式
Xiaomi Fan Lovelace Card
hacs_badge
小米电风扇Lovelace卡片, 喜欢的给个star. 地址
Features
Update
v1.3.0
  • Rebuild code
  • Optimize and fix multiple logic problems
  • Optimize the UI configuration panel
    v1.2.2
  • Swing angle UI display
  • Add aspect-ratio configuration
  • Add background color configuration
    v1.2.1
  • Fix the problem of speed information out of sync.
  • Add sway angle interaction.
  • Support for Lovelace UI configuration.
    v1.2
  • Delete the temperature and humidity information.
  • Refactor the layout.
  • Increase battery power ring display (if device supports)
  • Increase the speed of the regulation.
  • Increase the angle adjustment button.
HACS Installation
Search for Lovelace-fan-xiaomi
Manual Installation
  1. Download fan-xiaomi.js
  2. Copy to www\community\lovelace-fan-xiaomi\fan-xiaomi.js
  3. Add the following to your Lovelace resources
    resources:
      - url: /hacsfiles/lovelace-fan-xiaomi/fan-xiaomi.js?v=0.2
        type: module
  4. Add the following to your Lovelace config views.cards key
    type: 'custom:fan-xiaomi'
    entity: fan.zhi_neng_dian_feng_shan_3
Credits
shaonianzhentan
花神
参与人数 9金钱 +116 HASS币 +20 收起 理由
jyz_0501 + 12 墙都不扶,就服楼主!
wangkang + 5 墙都不扶,就服楼主!
dpf1025 + 5
eric + 20 感谢楼主分享!
Jerrylee + 7 膜拜大神!
chiunownow + 7 墙都不扶,就服楼主!
neroxps + 20 感谢楼主分享!
咸味土豆 + 20 又如滚滚黄河之水,一发不可收拾…….
+ 20 + 20 这个真心酷!
发表于 2019-10-14 18:28:58 | 显示全部楼层
谢谢分享
发表于 2019-10-14 19:02:39 | 显示全部楼层
发表于 2019-10-14 19:11:50 | 显示全部楼层
thanks for sharing
发表于 2019-10-14 19:32:14 | 显示全部楼层
谢谢楼主!!!
发表于 2019-10-14 19:50:13 | 显示全部楼层
谢谢分享
活跃会员
发表于 2019-10-14 20:39:03 | 显示全部楼层
帅气!!!!
Jeff
活跃会员
发表于 2019-10-14 20:40:53 | 显示全部楼层
谢谢楼主!!!可以支持小米风扇1X吗
Jeff
发表于 2019-10-14 20:56:55 | 显示全部楼层
谢谢分享,点赞,666
发表于 2019-10-14 21:09:12 | 显示全部楼层
这个效果太攒了,刚把风扇收起来,看来要拿出来试试了
GMT+8, 2026-1-15 21:56 , Processed in 0.715784 second(s), 10 queries , MemCached On.
