楼主: c1pher_小愚
[进阶教程] homebridge homeassistant 配置萤石C6H摄像头
发表于 2017-8-25 08:57:11 | 显示全部楼层
25989406 发表于 2017-8-24 22:03
ffmpeg路径对吗,ffmpeg执行会报错吗
ffmpeg执行不报错,新版的ffmpeg安装在Chroot环境下的,  Hass装在docker下的,不知道怎么填这个Chroot下的路径,帮看下,谢谢
root@DS216:/# ffmpeg
ffmpeg version 3.2.5-1~bpo8+1 Copyright (c) 2000-2017 the FFmpeg developers
  built with gcc 4.9.2 (Debian 4.9.2-10)
  configuration: --prefix=/usr --extra-version='1~bpo8+1' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --disable-libebur128 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
  libavutil      55. 34.101 / 55. 34.101
  libavcodec     57. 64.101 / 57. 64.101
  libavformat    57. 56.101 / 57. 56.101
  libavdevice    57.  1.100 / 57.  1.100
  libavfilter     6. 65.100 /  6. 65.100
  libavresample   3.  1.  0 /  3.  1.  0
  libswscale      4.  2.100 /  4.  2.100
  libswresample   2.  3.100 /  2.  3.100
  libpostproc    54.  1.100 / 54.  1.100
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
 楼主| 发表于 2017-8-25 20:18:40 | 显示全部楼层
1.你贴这个只是执行ffmpeg(只要装了ffmpeg当然不会有错,这么测试没用),并没有带摄像头的数据,测试成功是指用ffmpeg能连上摄像头不报错
2.你hass 在docker里,那你就不能在chroot里执行命令测试,
你要在群晖的用户态里执行ffmpeg 的测试(使用ffmpeg的绝对路径)
以我自己的chroot为例
chroot目录:/volume1/@appstore/debian-chroot/var/chroottarget/
chroot中ffmpeg的目录:/usr/local/bin/ffmpeg
合在一起 测试的命令应该是
/volume1/@appstore/debian-chroot/var/chroottarget/usr/local/bin/ffmpeg
ffmpeg_bin也应该填上面这个绝对路径。
完整测试命令:
/volume1/@appstore/debian-chroot/var/chroottarget/usr/local/bin/ffmpeg   -rtsp_transport tcp -i rtsp://admin:[email protected]:554/h264/ch1/main/av_stream -an -f null -
 楼主| 发表于 2017-8-25 20:19:50 | 显示全部楼层
myhomeha 发表于 2017-8-25 08:57
ffmpeg执行不报错,新版的ffmpeg安装在Chroot环境下的,  Hass装在docker下的,不知道怎么填这个Chroot下 ...
看我上一条回复
发表于 2017-8-26 12:02:42 | 显示全部楼层
非常感谢您的指导,苦恼我昨天把Docker自带的ffmpeg删除了,没有可执行文件了,
发表于 2017-8-26 23:27:33 | 显示全部楼层
期待大神在群晖Docker环境的HA里加载ffmpeg成功!
 楼主| 发表于 2017-8-27 10:45:15 | 显示全部楼层
那你看错帖子了,这里没docker,也不会去搞
云淡风轻近午天
发表于 2017-8-28 08:58:21 来自手机 | 显示全部楼层
支持一下,就是看到楼主的帖子入手了一个,准备到货哈哈哈
云淡风轻近午天
发表于 2017-8-28 17:42:20 | 显示全部楼层
想请教一下C6H的默认用户名是admin,知道了,密码是验证码哈哈
 楼主| 发表于 2017-8-28 19:52:21 | 显示全部楼层
对,底座上的验证码
云淡风轻近午天
发表于 2017-8-28 21:06:46 | 显示全部楼层
25989406 发表于 2017-8-28 19:52
对,底座上的验证码
这个系统可以拿到权限吗?比如开telnet ssh等
APP改验证码无效,仅限于APP,RTSP还是得用原厂的
GMT+8, 2025-9-14 03:21 , Processed in 0.453681 second(s), 7 queries , MemCached On.
