查看: 20847|回复: 26
[新奇玩法] 天猫精灵按呗(BLE按钮)接入HA实现各种奇怪功能
发表于 2019-7-4 22:40:37 | 显示全部楼层 |阅读模式
天猫精灵不知道啥时候出了一款BLE按钮,价格不错,加上优惠后三个按钮六十块钱出头,需要搭配天猫精灵作为网关,比小米的便宜多了。果断撸几个回来折腾。具体购买链接和使用需求请某宝搜索按呗咨询客服。
套路
  1. 将HA接入猫精(有条件的用 aihome,没条件的用论坛新版猫精
  2. 写几个input_boolean专门给猫精控制
  3. 把上面的input_boolean在猫精APP里分配到奇怪的房间
  4. 写几个automation来实现想要的功能
保姆房车库宠物房都是不存在的,专门给猫精按钮分配的
Package.yaml
此处用我自己使用的三个功能作为案例供参考:
  1. 单击:将小米飞利浦台灯设为夜灯或关灯
  2. 双击:睡眠灯光,关掉大部分照明灯
  3. 长按:打开空调并设置为24度大风或关空调
# 先生成几个假按钮给猫精
input_boolean:
  tmall_b1_1:
  tmall_b1_2:
  tmall_b1_3:
# 让猫精接入上面的假按钮。此处使用aihome方案,论坛新版猫精请自行修改
homeassistant:
  customize:
    input_boolean.tmall_b1_1:
      friendly_name: "宠物房的挂灯"
      aihome_device: True
      aligenie_deviceName: 挂灯
      aligenie_zone: 宠物房
      aligenie_deviceType: light
      aligenie_actions: ["TurnOn", "TurnOff"]
    input_boolean.tmall_b1_2:
      friendly_name: "宠物房的射灯"
      aihome_device: True
      aligenie_deviceName: 射灯
      aligenie_zone: 宠物房
    input_boolean.tmall_b1_3:
      friendly_name: "宠物房的筒灯"
      aihome_device: True
      aligenie_deviceName: 筒灯
      aligenie_zone: 宠物房
# 将 climate 组件的空调情况转为 sensor 方便 automation 调用
  - platform: template
    sensors:
      climate_operation_mode:
        value_template: "{{state_attr('climate.zhu_wo_kong_diao', 'operation_mode')}}"
# 让按钮实现功能
automation:
  - alias: 单击-关小米飞利浦台灯
    initial_state: true
    trigger:
      platform: state
      entity_id: input_boolean.tmall_b3_1
      to: "on"
    condition:
      condition: or
      conditions:
        - condition: state
          entity_id: light.fei_li_pu_tai_deng
          state: "on"
        - condition: state
          entity_id: light.fei_li_pu_tai_deng_ambient_light
          state: "on"
    action:
      - service: homeassistant.turn_off
  - alias: 单击-小米飞利浦台灯设为夜灯
    initial_state: true
    trigger:
      platform: state
      to: "on"
    condition:
      condition: and
      conditions:
        - condition: state
          state: "off"
        - condition: state
          state: "off"
    action:
      - service: light.turn_on
        data:
          brightness: 1
  - alias: 双击-关家里所有灯
    initial_state: true
    trigger:
      platform: state
      entity_id: input_boolean.tmall_b3_2
      to: "on"
    action:
        entity_id: group.sleep_mode
  - alias: 长按-关空调
    initial_state: true
    trigger:
      platform: state
      entity_id: input_boolean.tmall_b3_3
      to: "on"
    condition:
      condition: state
      entity_id: sensor.climate_operation_mode
      state: "cool"
    action:
      - service: climate.turn_off
        entity_id: climate.zhu_wo_kong_diao
  - alias: 长按-开空调
    initial_state: true
    trigger:
      platform: state
      to: "on"
    condition:
      condition: state
      state: "off"
    action:
      - service: climate.set_operation_mode
        data:
          operation_mode: cool
      - service: climate.set_temperature
        data:
          temperature: 24
      - service: script.toggle
        entity_id: script.set_acfan_speed_large
参与人数 3金钱 +32 HASS币 +10 收起 理由
龙魂炎虎 + 5 纳尼,还有这种操作?
jasonpc + 7
+ 20 + 10 纳尼,还有这种操作?
发表于 2019-7-4 23:25:58 | 显示全部楼层
发现天猫精灵开始玩蓝牙了,也是一个好思路。。。
发表于 2019-7-4 23:33:19 | 显示全部楼层
这个延迟有多大?
 楼主| 发表于 2019-7-5 00:19:48 来自手机 | 显示全部楼层
maybeloveu 发表于 2019-7-4 23:33
这个延迟有多大?
一秒到五秒左右,通讯过程漫长,仅适合对延迟无需求的场景
Freddy.
最佳新人卓越贡献
发表于 2019-7-5 08:26:22 | 显示全部楼层
那么这个按钮能接入HA不?
流水无味
灌水之王
发表于 2019-7-5 08:28:57 | 显示全部楼层
按按钮天猫会语音反馈吗?
我记得以前虚拟设备的话对着天猫喊打开 宠物房的台灯,天猫会逗比回答灯已经打开!
(最近两天发现天猫改性了,只回答:已开!)
发表于 2019-7-5 08:49:44 | 显示全部楼层
xieahui 发表于 2019-7-5 08:28
按按钮天猫会语音反馈吗?
我记得以前虚拟设备的话对着天猫喊打开 宠物房的台灯,天猫会逗比回答灯已经打 ...
按键没有反馈
改性我前天也发现了  回复基本是  好 OK 好的 已开 开了 已打开  反正不会超过3个字
发现的当天白天我在猫精论坛吐槽话多的事了 还以为是后台给我改权了
我就是六神
活跃会员教程狂人灌水之王
发表于 2019-7-5 08:49:46 | 显示全部楼层
按按钮天猫会语音反馈吗?
是的,现在回答简练了,NND 以前太煞笔了,而且有时候还强制性自我介绍,太烦人了,猫精的硬广都打到家里了,体验超级不好
现在回答简练了,不知道自我介绍还有没有
发表于 2019-7-5 08:51:05 | 显示全部楼层
思路可以  虚拟个不存在的设备  打通HA和猫精
众筹19搞了一个
流水无味
灌水之王
发表于 2019-7-5 09:13:11 | 显示全部楼层
众筹19搞了一个
昨天看到 60不到3个 哪里看到的忘记了 你们有看到吗? 想下手当按钮用
小米那个太贵了
GMT+8, 2025-9-13 03:08 , Processed in 1.079282 second(s), 7 queries , MemCached On.
