楼主: jiluxinqing
[插件集成] 网易云音乐【支持语音播放专辑】【2020-7-14更新】
 楼主| 发表于 2019-7-28 19:24:13 | 显示全部楼层
evantalk 发表于 2019-7-28 16:00
能正常播放到Dlna设备,但是有报错,求解答
2019-07-28 15:20:06 INFO (SyncWorker_15) [custom_compone ...
估计是操作的流程有问题,我自己没有测试到,按正常流程走应该是没问题的
http://github.com/shaonianzhentan
发表于 2019-8-24 16:55:30 | 显示全部楼层
大佬我的不能播放是咋回事,ha 0.97.1     歌单能刷出来就是进度条不走
 楼主| 发表于 2019-9-25 12:37:42 | 显示全部楼层
2019-09-25更新
发表于 2019-9-26 23:22:48 | 显示全部楼层
好像更新之后进度条还是不懂,我用的是mopidy。
 楼主| 发表于 2019-9-27 10:46:30 | 显示全部楼层
正常应该会动的啊,我使用vlc测试过,下次我再试试mopidy
发表于 2019-9-27 21:31:38 | 显示全部楼层
在hassio上配置成功,很不错,感谢;;
发表于 2019-9-28 15:33:27 | 显示全部楼层
感谢分享!!
发表于 2019-9-28 23:27:47 | 显示全部楼层
安装重启报错.
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 376, in _async_set_up_integrations
    *(async_setup_component(hass, domain, config) for domain in domains_to_load)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 562, in async_forward_entry_setup
    result = await async_setup_component(self.hass, domain, self._hass_config)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 46, in async_setup_component
    return await setup_tasks[domain]  # type: ignore
  File "/usr/src/homeassistant/homeassistant/setup.py", line 52, in async_setup_component
    return await task  # type: ignore
  File "/usr/src/homeassistant/homeassistant/setup.py", line 137, in _async_setup_component
    hass, config, integration
  File "/usr/src/homeassistant/homeassistant/config.py", line 757, in async_process_component_config
    platform = p_integration.get_platform(domain)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 232, in get_platform
    f"{self.pkg_path}.{platform_name}"
  File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 728, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/config/custom_components/ha-cloud-music/media_player.py", line 72, in <module>
    files, names = getallfile(__dirname+'\\dist')
  File "/config/custom_components/ha-cloud-music/media_player.py", line 58, in getallfile
    allfilelist=os.listdir(path)
改成这样不报错了 files, names = getallfile(__dirname+'/dist')
下面这个是SSL的原因, 加载的资源是http的包括头像,背景和CD封面.只在js里找到一个背景图片的资源URL. 其他没找到应该在哪里改.
发表于 2019-10-11 11:09:09 | 显示全部楼层
非常感谢!
发表于 2019-10-11 17:42:52 | 显示全部楼层
一直报错
ERROR (MainThread) [homeassistant.core] Error doing job: Future exception was never retrieved
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/home/zxl/homeassistant/custom_components/ha-cloud-music/media_player.py", line 164, in interval
    if self.media_duration > 2 and self.media_duration - 2 <= self.media_position and self.next_count > 0:
  File "/home/zxl/homeassistant/custom_components/ha-cloud-music/media_player.py", line 271, in media_duration
    return self._media.attributes['media_duration']
KeyError: 'media_duration'
GMT+8, 2025-9-15 03:10 , Processed in 0.916166 second(s), 13 queries , MemCached On.
