楼主: natic
[基础教程] ESPHome刷机教程
发表于 2019-4-19 11:42:17 | 显示全部楼层
楼主请教个问题,为什么我的状态显示是online了,也通过集成添加到了设备,但是在日志看,提示这样的:
INFO Reading configuration...
INFO Starting log output from livingroom.local using esphome API
INFO Connecting to livingroom.local:6053 (0.0.0.0)
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 0.0.0.0: [Errno 111] Connection refused). Re-Trying in 1 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 0.0.0.0: [Errno 111] Connection refused). Re-Trying in 2 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 0.0.0.0: [Errno 111] Connection refused). Re-Trying in 4 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 0.0.0.0: [Errno 111] Connection refused). Re-Trying in 8 seconds
 楼主| 发表于 2019-4-19 11:46:53 | 显示全部楼层
INF ...
报错说没连上wifi,在你的路由器里面找一下esp有没有连上wifi
发表于 2019-4-19 13:37:30 | 显示全部楼层
学习一下,感谢分享!
发表于 2019-4-19 14:15:50 | 显示全部楼层
esphome 功能很强大 为homeassistant 量身定做的
发表于 2019-4-19 20:19:22 | 显示全部楼层
新版sonoff basic 用的是esp8285的芯片,不知道能不能通刷esphome,好期待
 楼主| 发表于 2019-4-19 21:33:27 来自手机 | 显示全部楼层
可以的,文档有写
winn
发表于 2019-4-19 23:14:56 | 显示全部楼层
学习学习
发表于 2019-4-20 00:02:58 | 显示全部楼层
学习一下,感谢分享
发表于 2019-4-20 08:04:35 | 显示全部楼层
这个不错的
发表于 2019-4-20 08:36:40 | 显示全部楼层
学习学习
GMT+8, 2025-9-10 06:11 , Processed in 0.323958 second(s), 11 queries , MemCached On.
