楼主: ghostist
[经验分享] 让你的小方/大方摄像头在HA里彻底不卡
发表于 2019-3-26 11:48:00 | 显示全部楼层
ghostist 发表于 2019-3-26 11:08
本地用VLC播放器看一下能否播rtsp
地址没问题,VLC可以播
发表于 2019-3-26 22:51:39 | 显示全部楼层
谢谢LZ,确实快了很多!
发表于 2019-3-29 02:20:41 | 显示全部楼层
通常的海康rtsp可以用吗,如果可以的话,still_image_url:填什么?
发表于 2019-3-30 21:26:39 | 显示全部楼层
楼主!设置了这个后,提示安装av==6.1.2失败!怎么解决
Unable to install package av==6.1.2: Failed building wheel for av
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-7jdnba2_/av/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-zcl2sifj/install-record.txt --single-version-externally-managed --prefix  --compile --user --prefix=" failed with error code 1 in /tmp/pip-install-7jdnba2_/av/
2019-03-30 21:26:14 ERROR (MainThread) [homeassistant.requirements] Not initializing stream because could not install requirement av==6.1.2
2019-03-30 21:26:14 ERROR (MainThread) [homeassistant.setup] Setup failed for stream: Could not install all requirements.
发表于 2019-4-15 05:51:57 | 显示全部楼层
感谢,已经用上了。附上一段我的摄像头额外配置,算是做一点小参考
timer:
  motion_record_disable:
    duration: '00:00:30'
shell_command:
  rclone_sync_dafang_onedrive: rclone sync /home/chiunownow/DCIM/ dafang-onedriveAFANG-CAM
group:
  motion_record:
    icon: mdi:camera-enhance
    entities:
      - automation.motion_record_20s
      - automation.motion_snapshot
automation:
  - alias: motion_record_20s
    trigger:
      entity_id: binary_sensor.dafang_motion_sensor
      platform: state
      to: 'on'
    condition:
      - condition: state
        entity_id: timer.motion_record_disable
        state: 'idle'
    action:
      - service: script.toggle
        entity_id: script.motion_record_v2
      - delay: 00:00:40
      - service: shell_command.rclone_sync_dafang_onedrive
  - alias: motion_snapshot
    trigger:
      platform: state
      to: 'on'
    action:
      - service: timer.start
      - service: camera.snapshot
        data:
          entity_id: camera.dafangcgi
          filename: "/home/chiunownow/DCIM/Picture/{{ now().strftime('%y%m%d-%H%M%S') }}.jpg"
  - alias: turn_on_motion_record
    trigger:
      entity_id: group.device_tracker
      platform: state
      to: 'not_home'
      for:
        minutes: 5
    action:
      - service: homeassistant.turn_on
        entity_id: group.motion_record
      - data:
          message: 监测到屋主不在家,打开动作记录
        service: notify.ios_nownows_iphone
  - alias: turn_off_motion_record
    trigger:
      platform: state
      to: 'home'
    action:
      - service: homeassistant.turn_off
      - data:
          message: 监测到屋主到家,关闭动作记录
script:
  motion_record_v2:
    sequence:
      - service: camera.record
        data_template:
          entity_id: camera.dafang3
          filename: "/home/chiunownow/DCIM/Video/{{ now().strftime('%y%m%d-%H%M%S') }}.mp4"
          duration: "20"
          lookback: "10"
ha监测到大方的动作传感器off-on时,录视频+快照,通过 rclone 同步到 OneDrive,再用 ifttt 监测 OneDrive 的图片和视频文件夹,新增文件时推送到 telegram
发表于 2019-5-22 15:30:57 | 显示全部楼层
原先RSTP卡,现在用图片一秒获取一次
发表于 2019-5-22 20:08:29 | 显示全部楼层
厉害厉害,学习了!
 楼主| 发表于 2019-5-23 08:37:08 | 显示全部楼层
rexchen 发表于 2019-5-22 15:30
原先RSTP卡,现在用图片一秒获取一次
新特性允许点开进去直接看流媒体
0.92以上版本应该可以在页面默认集成流媒体 不用再点开(我没更新到这个版本)
发表于 2020-1-13 17:52:56 | 显示全部楼层
chiunownow 发表于 2019-4-15 05:51
[md]
这个是在那个文件里配置的
发表于 2020-3-15 13:11:11 | 显示全部楼层
Unable to install package av==6.1.2: Failed b ...
我也是,解决了吗
GMT+8, 2025-9-18 02:40 , Processed in 0.334133 second(s), 11 queries , MemCached On.
