楼主: 三木
[插件集成] [4月1日更新!!]斐讯DC1插座自制固件接入ha
发表于 2021-10-26 18:41:32 | 显示全部楼层
挺好用的,一直在用,可惜ESPHOMV2021.10.2 后驱动改在了esphom下了,cat9554驱动弄过去也不能用了,报错,大神还可以修改一个版本吗
发表于 2022-1-20 00:22:19 | 显示全部楼层
谢谢大佬,感觉很好用的样子。
发表于 2022-3-7 16:12:07 | 显示全部楼层
DC1的库报错了   大佬能不能扔一个改过的?更新一下?
Platform error switch.phicomm_dc1 - cannot import name 'SwitchDevice' from 'homeassistant.components.switch' (/usr/src/homeassistant/homeassistant/components/switch/__init__.py)
发表于 2022-4-10 11:17:34 | 显示全部楼层
谢谢大佬,图片清晰,指导仔细,先收藏学习。今天突然想要DC1复活,所以搜神了,有幸遇见,感谢!
发表于 2022-5-3 22:09:12 | 显示全部楼层
一编译就挂了,麻烦看看下面这个日志
WARNING Calling ESPHome with the configuration before the command is deprecated and will be removed in the future.
WARNING Please instead use:
WARNING    esphome compile c:\espdc1\config_yaml\dc1-homeassistant-api.yaml
INFO Reading configuration c:\espdc1\config_yaml\dc1-homeassistant-api.yaml...
ERROR Unexpected exception while reading configuration:
  File "c:\espdc1\Python\lib\runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "c:\espdc1\Python\lib\runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "c:\espdc1\Python\lib\site-packages\esphome\__main__.py", line 834, in <module>
    sys.exit(main())
  File "c:\espdc1\Python\lib\site-packages\esphome\__main__.py", line 825, in main
    return run_esphome(sys.argv)
  File "c:\espdc1\Python\lib\site-packages\esphome\__main__.py", line 803, in run_esphome
    config = read_config(dict(args.substitution) if args.substitution else {})
  File "c:\espdc1\Python\lib\site-packages\esphome\config.py", line 974, in read_config
    res = load_config(command_line_substitutions)
  File "c:\espdc1\Python\lib\site-packages\esphome\config.py", line 829, in load_config
    return _load_config(command_line_substitutions)
  File "c:\espdc1\Python\lib\site-packages\esphome\config.py", line 817, in _load_config
    result = validate_config(config, command_line_substitutions)
  File "c:\espdc1\Python\lib\site-packages\esphome\config.py", line 744, in validate_config
    result.run_validation_steps()
  File "c:\espdc1\Python\lib\site-packages\esphome\config.py", line 124, in run_validation_steps
    task.step.run(self)
  File "c:\espdc1\Python\lib\site-packages\esphome\config.py", line 488, in run
    validated = schema(input_conf)
  File "c:\espdc1\Python\lib\site-packages\esphome\voluptuous_schema.py", line 34, in __call__
    res = super().__call__(data)
  File "c:\espdc1\Python\lib\site-packages\voluptuous\schema_builder.py", line 272, in __call__
    return self._compiled([], data)
  File "c:\espdc1\Python\lib\site-packages\voluptuous\schema_builder.py", line 817, in validate_callable
    return schema(data)
  File "c:\espdc1\Python\lib\site-packages\voluptuous\schema_builder.py", line 594, in validate_dict
    return base_validate(path, iteritems(data), out)
  File "c:\espdc1\Python\lib\site-packages\esphome\voluptuous_schema.py", line 148, in validate_mapping
    cval = cvalue(key_path, value)
    return schema(data)
  File "c:\espdc1\Python\lib\site-packages\esphome\pins.py", line 66, in validator
    return entry[1](value)
TypeError: 'tuple' object is not callable
请按任意键继续. . .
发表于 2023-4-5 18:48:23 | 显示全部楼层
慕名而来 膜拜一下
kmsg
发表于 2023-4-5 22:50:02 | 显示全部楼层
xiguaboy 发表于 2022-5-3 22:09
一编译就挂了,麻烦看看下面这个日志
你好,打扰了。
请问你DC1刷机,编译的问题解决了吗?我这边遇到和你一样的报错。
发表于 2023-5-16 08:42:05 | 显示全部楼层
一编译就挂了,麻烦看看下面这个日志
我也是一样,有没有解决方法
发表于 2024-1-2 12:40:52 | 显示全部楼层
应该是cat9554造成的,有没有代码大佬看看!!
发表于 2024-10-14 16:25:45 | 显示全部楼层
我也是编译固件报错,求大老帮助。
GMT+8, 2026-1-14 18:47 , Processed in 1.817909 second(s), 10 queries , MemCached On.
