楼主: 三木
[插件集成] [4月1日更新!!]斐讯DC1插座自制固件接入ha
发表于 2019-11-30 12:23:28 | 显示全部楼层
chwater 发表于 2019-11-30 05:44
你把yaml里这段改成下面这个试试
cat9554:
我也与到同样问题,多谢你的指点,已经搞定。谢谢谢谢
发表于 2019-12-8 20:09:50 | 显示全部楼层
大佬厉害了
发表于 2019-12-11 14:40:47 | 显示全部楼层
牛逼牛逼  先回帖再看内容
发表于 2019-12-15 22:38:14 | 显示全部楼层
原来大神在这里
发表于 2019-12-16 02:28:27 来自手机 | 显示全部楼层
原来如此厉害
发表于 2019-12-17 01:43:00 来自手机 | 显示全部楼层
没搞明白跟dns劫持的区别。。。不还是得用ha服务器吗?仅仅是不用劫持?我是小白,真不懂
发表于 2019-12-20 15:14:43 | 显示全部楼层
#WiFi芯片版本,型号中带B的为csm64f02_b,不带B的为csm64f02
  board_model: esp01_1m
如果将esp01_1m改为csm64f02_b,编译提示找不到相应的类型,默认esp01_1m通过
关于irq_pin那个看上边的网友问答解决了
但是编译到最后又失败了
|   |-- <Wire> 1.0
|   |-- <ESP8266WiFi> 1.0
|   |-- <ESPAsyncTCP> 1.2.0
|   |   |-- <ESP8266WiFi> 1.0
|   |-- <ESP8266mDNS>
Building in release mode
Compiling .pioenvs\dc1_01\src\main.cpp.o
Generating LD script .pioenvs\dc1_01\ld\eagle.app.v6.common.ld
Compiling .pioenvs\dc1_01\lib519\ESP8266WiFi\BearSSLHelpers.cpp.o
src\main.cpp: In function 'void setup()':
src\main.cpp:30:3: error: 'io' has not been declared
   io::CAT9554Component *cat9554_hub = App.make_cat9554_component(0x20, 4);
src\main.cpp:30:25: error: 'cat9554_hub' was not declared in this scope
src\main.cpp:30:43: error: 'class esphome::Application' has no member named 'mak
e_cat9554_component'
src\main.cpp:63:161: error: 'io' has not been declared
   binary_sensor::GPIOBinarySensorComponent *binary_sensor_gpiobinarysensorcompo
nent = App.make_gpio_binary_sensor("dc1_01 key1", cat9554_hub->make_input_pin(0,
io::CAT9554_INPUT, false));
src\main.cpp:64:163: error: 'io' has not been declared
nent_2 = App.make_gpio_binary_sensor("dc1_01 key2", cat9554_hub->make_input_pin(
1, io::CAT9554_INPUT, false));
src\main.cpp:65:163: error: 'io' has not been declared
nent_3 = App.make_gpio_binary_sensor("dc1_01 key3", cat9554_hub->make_input_pin(
2, io::CAT9554_INPUT, false));
*** [.pioenvs\dc1_01\src\main.cpp.o] Error 1
========================= [FAILED] Took 55.19 seconds =========================
发表于 2019-12-20 15:57:18 | 显示全部楼层
要用docker的那个环境来编译
发表于 2019-12-22 15:01:39 | 显示全部楼层
固件下载不了怎么办
发表于 2019-12-28 10:29:26 来自手机 | 显示全部楼层
牛逼牛逼… 先马克
GMT+8, 2025-7-1 14:50 , Processed in 0.302167 second(s), 17 queries , MemCached On.
