楼主: 三木
[插件集成] [4月1日更新!!]斐讯DC1插座自制固件接入ha
发表于 2019-11-24 12:58:37 | 显示全部楼层
  File "D:\dc\esphome-tools-dc1-master\Python27\lib\site-packages\esphome-1.13.0.dev0-py2.7.egg\esphome\__main__.py", line 297, in command_compile
    exit_code = compile_program(args, config)
  File "D:\dc\esphome-tools-dc1-master\Python27\lib\site-packages\esphome-1.13.0.dev0-py2.7.egg\esphome\__main__.py", line 163, in compile_program
    rc = platformio_api.run_compile(config, args.verbose)
  File "D:\dc\esphome-tools-dc1-master\Python27\lib\site-packages\esphome-1.13.0.dev0-py2.7.egg\esphome\platformio_api.py", line 38, in run_compile
    return run_platformio_cli_run(config, verbose)
  File "D:\dc\esphome-tools-dc1-master\Python27\lib\site-packages\esphome-1.13.0.dev0-py2.7.egg\esphome\platformio_api.py", line 34, in run_platformio_cli_run
    return run_platformio_cli(*command, **kwargs)
  File "D:\dc\esphome-tools-dc1-master\Python27\lib\site-packages\esphome-1.13.0.dev0-py2.7.egg\esphome\platformio_api.py", line 22, in run_platformio_cli
    import platformio.__main__
  File "D:\dc\esphome-tools-dc1-master\Python27\lib\site-packages\platformio-4.1.0-py2.7.egg\platformio\__main__.py", line 21, in <module>
    from platformio import __version__, exception, maintenance, util
  File "D:\dc\esphome-tools-dc1-master\Python27\lib\site-packages\platformio-4.1.0-py2.7.egg\platformio\maintenance.py", line 22, in <module>
    from platformio import __version__, app, exception, fs, telemetry, util
  File "D:\dc\esphome-tools-dc1-master\Python27\lib\site-packages\platformio-4.1.0-py2.7.egg\platformio\app.py", line 23, in <module>
    import requests
  File "D:\dc\esphome-tools-dc1-master\Python27\lib\site-packages\requests-2.22.0-py2.7.egg\requests\__init__.py", line 43, in <module>
    import urllib3
ImportError: No module named urllib3
编译固件提示这错误怎么回事ImportError: No module named urllib3
发表于 2019-11-24 16:51:42 | 显示全部楼层
现在各种报错根本没有办法用,怎么回事呢有知道的吗?
发表于 2019-11-24 17:38:20 | 显示全部楼层
ERROR: Could not find a version that satisfies the requirement pip (from versions: none)
ERROR: No matching distribution found for pip
这种报错怎么解决
发表于 2019-11-25 09:05:31 | 显示全部楼层
263net 发表于 2019-8-14 16:20
同问此文件在哪??
同问此文件在哪?电脑是macbook
发表于 2019-11-25 09:06:38 | 显示全部楼层
65999wlc 发表于 2019-8-30 10:06
楼主,https://github.com/Samuel-0-0/esphome-core这个里面没有setup.py呢??
我也没看到有这个文件,也搜索不到
发表于 2019-11-25 15:28:48 | 显示全部楼层
我安装编译环境老是出错 杀毒软件关掉也报错
发表于 2019-11-27 22:36:48 | 显示全部楼层
INFO Reading configuration...
Failed config
cat9554: [source D:\esphome-tools-dc1-lite\config_yaml\dc.yaml:79]
  'irq' is a required option for [cat9554].
  - [source D:\esphome-tools-dc1-lite\config_yaml\dc.yaml:79]
    address: 32
请按任意键继续. . .
不知道是什么回事?1823b
发表于 2019-11-27 22:41:13 | 显示全部楼层
Failed config
cat9554: [source D:\esphome-tools-dc1-master\config_yaml\dc1.yaml:79]
  - [source D:\esphome-tools-dc1-master\config_yaml\dc1.yaml:79]
    address: 32
请按任意键继续. . .
出现这个提示,一直无法成功。刚开始的时候也是201楼的提示,后来更新了,就这样了。
更换过电脑,系统是WIN7.
发表于 2019-11-30 05:17:18 | 显示全部楼层
fengzhicheng 发表于 2019-11-27 22:41
[32mINFO Reading configuration... [0m
Failed config
我用Win10也提示这个,看报错的意思是 cat9554需要配置中断。。。我试了半天也没弄明白应该怎么搞。。。估计还是编译环境的问题。。。。你那编过去了么?
发表于 2019-11-30 05:44:22 | 显示全部楼层
Failed config
你把yaml里这段改成下面这个试试
cat9554:
  - id: cat9554_hub
    address: 0x20
    irq: GPIO4
GMT+8, 2025-7-1 14:49 , Processed in 0.272971 second(s), 17 queries , MemCached On.
