楼主: trz0332
[插件集成] 删!!!!!!!!!!!!!!!!!!!!!!
 火.. [复制链接]
发表于 2019-5-29 16:34:50 | 显示全部楼层
Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.7/site-packages/homeassistant/components/device_tracker/__init__.py", line 703, in async_device_tracker_scan
    found_devices = await scanner.async_scan_devices()
  File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/config/custom_components/lede/device_tracker.py", line 133, in scan_devices
    self._update_info()
  File "/config/custom_components/lede/device_tracker.py", line 180, in _update_info
    result=self.token.get(url).json()
  File "/usr/local/lib/python3.7/site-packages/requests/models.py", line 897, in json
    return complexjson.loads(self.text, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/simplejson/__init__.py", line 518, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 370, in decode
    obj, end = self.raw_decode(s)
  File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 400, in raw_decode
    return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
HA系统版本为0.93B1 没看懂错在哪里小白。望指点!谢谢
发表于 2019-5-29 19:15:33 来自手机 | 显示全部楼层
lede17,lede18 有啥区别
发表于 2019-5-30 15:25:18 | 显示全部楼层
配置检查
此处可以帮助你检验最新修改的配置文件有效性
配置无效
Integration gocloud not found when trying to verify its device_tracker platform.
C:\Users\Administrator\Desktop/1559200887(1).png
发表于 2019-5-30 15:26:20 | 显示全部楼层
楼主,帮忙看下啥情况,谢谢
发表于 2019-6-2 12:12:20 | 显示全部楼层
是这样子放嘛?
   还是出这个错误
发表于 2019-6-11 11:26:56 | 显示全部楼层
请问大佬,我配置好了,怎么没反应啊,我这样放文件和配置正不正确啊我的ha不是最新版的 TIM截图20190611112544.jpg TIM截图20190611112528.jpg TIM截图20190611112947.jpg
版主
发表于 2019-6-12 02:08:41 | 显示全部楼层
谢谢大神。自己在使用Koolshare Lede做软路由,用的lede 1.8的插件,貌似有问题,麻烦您看一下。谢谢。
配置文件:
device_tracker:
  - platform: lede_1_8
    host: 192.168.19.1
    username: !secret lede_username
    password: !secret lede_password
    zone: Calmdown
    latitude: !secret home_latitude
    longitude: !secret home_longtitude
    consider_home: 25  #设备离线延时
    interval_seconds: 10  #扫描间隔时间
    track_new_devices: yes  #是否检测新设备
错误Log:
  File "/usr/src/homeassistant/homeassistant/components/device_tracker/setup.py", line 150, in async_device_tracker_scan
  File "/config/custom_components/lede_1_8/device_tracker.py", line 133, in scan_devices
    self._update_info()
  File "/config/custom_components/lede_1_8/device_tracker.py", line 180, in _update_info
发表于 2019-6-14 23:52:24 | 显示全部楼层
大神,高恪的,日志显示“cooking过期,需要重新登陆”,哪里设置有问题?
发表于 2019-6-18 15:01:27 | 显示全部楼层
Log Details (ERROR)
Tue Jun 18 2019 14:56:57 GMT+0800 (中国标准时间)
  File "/usr/src/app/homeassistant/components/device_tracker/__init__.py", line 692, in async_device_tracker_scan
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/device_tracker/device_tracker.py", line 133, in scan_devices
    self._update_info()
  File "/config/custom_components/device_tracker/device_tracker.py", line 180, in _update_info
  File "/usr/local/lib/python3.6/site-packages/requests/models.py", line 897, in json
  File "/usr/local/lib/python3.6/site-packages/simplejson/__init__.py", line 518, in loads
  File "/usr/local/lib/python3.6/site-packages/simplejson/decoder.py", line 370, in decode
  File "/usr/local/lib/python3.6/site-packages/simplejson/decoder.py", line 400, in raw_decode
楼主 你好 我0.821版本 修改了文件名 报错 帮我看看  软路由刷了lede 虚拟机运行的
发表于 2019-6-21 16:04:51 | 显示全部楼层
同Integration gocloud not found when trying to verify its device_tracker platform.
自己加入空白__init__.py文件后不报错
但是找不到实体
GMT+8, 2025-9-18 02:50 , Processed in 0.202471 second(s), 15 queries , MemCached On.
