楼主: plutosherry
[插件集成] 彩云天气 动态图标完整版【Caiyun Weather for lovelace】【原创】
教程狂人论坛风云人物突出贡献
发表于 2019-2-9 09:12:30 | 显示全部楼层
wukequdai5426 发表于 2019-2-8 08:20
感谢分享,我也用的这个毛玻璃特效的,但是彩云天气嵌套不了,能否分享一下配置 ...
      - type: 'custom:card-modder'
        style:
          --paper-card-background-color: rgba(67, 73, 84, 0.5)
          --paper-item-icon-color: white
          --primary-text-color: white
          --secondary-text-color: pink
          --paper-listbox-color: 'var(--primary-color)'
          --paper-listbox-background-color: rgba(67, 73, 84, 0.9)
          -webkit-backdrop-filter: blur(5px)
          backdrop-filter: blur(15px)
          color: white
          border-radius: 15px
        card:
          type: custom:caiyun-weather-card
          title: '彩云天气'
          entity_sun: sun.sun
          entity_hourly_summary: sensor.caiyun_weather_hourly_des
          entity_minutely_summary: sensor.caiyun_weather_minutely_des
          entity_current_conditions: sensor.now_caiyun_weather
          entity_humidity: sensor.now_caiyun_humidity
          entity_pressure: sensor.now_caiyun_pressure
          entity_precipitation: sensor.now_caiyun_precipitation
          entity_temperature: sensor.now_caiyun_temperature
          entity_visibility: sensor.now_caiyun_vis
          entity_wind_bearing: sensor.now_caiyun_wind_dir
          entity_wind_speed: sensor.now_caiyun_wind_spd
          entity_now_aqipm25: sensor.now_caiyun_pm25
          entity_now_air_aqi: sensor.now_caiyun_aqi
          entity_now_temphigh: sensor.caiyun_now_high_temperature
          entity_now_templow: sensor.caiyun_now_low_temperature
          entity_carwash: sensor.caiyun_now_carwash
          entity_forecast_skycon_1: sensor.caiyun_weather_1
          entity_forecast_skycon_2: sensor.caiyun_weather_2
          entity_forecast_skycon_3: sensor.caiyun_weather_3
          entity_forecast_skycon_4: sensor.caiyun_weather_4
          entity_forecast_temphigh_1: sensor.caiyun_high_temperature_1
          entity_forecast_temphigh_2: sensor.caiyun_high_temperature_2
          entity_forecast_temphigh_3: sensor.caiyun_high_temperature_3
          entity_forecast_temphigh_4: sensor.caiyun_high_temperature_4
          entity_forecast_templow_1: sensor.caiyun_low_temperature_1
          entity_forecast_templow_2: sensor.caiyun_low_temperature_2
          entity_forecast_templow_3: sensor.caiyun_low_temperature_3
          entity_forecast_templow_4: sensor.caiyun_low_temperature_4
          entity_forecast_aqi_1: sensor.caiyun_air_aqi_1
          entity_forecast_aqi_2: sensor.caiyun_air_aqi_2
          entity_forecast_aqi_3: sensor.caiyun_air_aqi_3
          entity_forecast_aqi_4: sensor.caiyun_air_aqi_4
          entity_forecast_carwash_1: sensor.caiyun_carwash_1
          entity_forecast_carwash_2: sensor.caiyun_carwash_2
          entity_forecast_carwash_3: sensor.caiyun_carwash_3
          entity_forecast_carwash_4: sensor.caiyun_carwash_4
          entity_forecast_precipitation_1: sensor.caiyun_precipitation_1
          entity_forecast_precipitation_2: sensor.caiyun_precipitation_2
          entity_forecast_precipitation_3: sensor.caiyun_precipitation_3
          entity_forecast_precipitation_4: sensor.caiyun_precipitation_4
发表于 2019-2-9 12:06:26 | 显示全部楼层
FrankLv 发表于 2019-2-9 09:12
[code]      - type: 'custom:card-modder'
        style:
          --paper-c ...
感谢了,已经用上了
发表于 2019-2-11 11:24:55 | 显示全部楼层
感谢lz分享
发表于 2019-2-11 13:15:39 | 显示全部楼层
楼主666666
发表于 2019-2-12 13:21:17 | 显示全部楼层
补充3点:1,用前端UI编辑器的同学注意下:entity写不全会报错的,只有全部写完才不报错
别管我左边写的,反正就是写不全就会报错
2,你的那个configuration.yaml里要有sun:
3,楼主有个代码写错了air_now_city_aqi应该是caiyun_now_air_aqi
我的部分代码截图(治好了之后感觉太复杂,换别的卡片了)
type: 'custom:caiyun-weather-card'
title: 彩云天气
entity_sun: sun.sun
entity_now_air_aqi: sensor.caiyun_now_air_aqi
发表于 2019-2-12 22:09:07 | 显示全部楼层
数据都有,但是只显示在首页顶部,没有card,也没有报错信息,如何解决?版本0.87.1,默认config路径(configuration.yaml同级)目录下是没有ui-lovelace.yaml
发表于 2019-2-12 23:56:21 | 显示全部楼层
459662146 发表于 2019-2-2 16:50
用了九楼的js和yaml了还是这个样子怎么回事
原来是需要改为yaml模式(全手工码代码),原来的配置全都没了,全部手写一遍,这工作量大的有点崩溃!configuration.yaml中加入
lovelace:
  mode: yaml
发表于 2019-2-13 00:24:43 | 显示全部楼层
ha里面数据是有了 接下来不知道怎么添加到页面了,,,,
发表于 2019-2-13 04:53:29 | 显示全部楼层
你好,我想问一下,这个插件是不是有个前置的插件?能否提供一下?我的插件中就没有能见度这个属性
发表于 2019-2-13 15:44:25 | 显示全部楼层
楼主ui-lovelace.yaml中的缩进或者别的有异常,无法显示天气界面。
GMT+8, 2025-9-19 06:38 , Processed in 1.268120 second(s), 15 queries , MemCached On.
