查看: 16930|回复: 14
MYNRF24 网关部分使用介绍及入门
huex
发表于 2019-1-26 00:55:15 | 显示全部楼层 |阅读模式
MYNRF24 网关介绍部分
@(原创请勿转载!)
2019.1.22更新增加编译后的固件,添加WiFiManager完成web配网MQTT等!二楼固件及刷入工具!
mysensor网关,是主要的数据处理中枢,网关类型也比较多,支持串行数据usb接口,支持以太网接口,支持MQTT,并且额外官方还制作出sam21的高速处理以太网或者usb数据网关,具体参考:https://www.mysensors.org/build/select_gateway
  本次主要介绍MQTT网关,MQTT又可以使用RS485,ESP8266,RJ45 W5100介质,目前我已经前期做过几片wemmos mini d1的pcb,本文主要方便本次PCB用户,由于前期只做了个样数量只有几片,所以本次按顺序无偿赠送给前几位用户,实在抱歉,网关工作不是我目前 的主要目标,后期稳定使用后,我会再去设计一款支持sma天线的网关工作板并提供PCB文件。
脚位链接
pcb模块
  pcb针对wemos mini d1设计,支持nrf24l01+,rfm69,nrf24l01+pla,板载ams1117-3.3脚,默认使用nrf24l01+无需增压转,可以正面添加4.7uf电容一颗
  enter image description here
  拿到pcb板后请注意脚位与你的wemos mini是否一致,由于淘宝nodemcu wemos mini与wemos mini 是出入的
务必注意脚位方向,否则损坏NRF24L01模块
网关模块
  请按下图与esp8266链接上。
网关代码
MQTT网关
 * The MySensors Arduino library handles the wireless radio link and protocol
 * between your home built sensors/actuators and HA controller of choice.
 * The sensors forms a self healing radio network with optional repeaters. Each
 * repeater and gateway builds a routing tables in EEPROM which keeps track of the
 * network topology allowing messages to be routed to nodes.
 * Created by Henrik Ekblad <[email protected]>
 * Copyright (C) 2013-2018 Sensnology AB
 * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
 * Documentation: http://www.mysensors.org
 * Support Forum: http://forum.mysensors.org
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License
 * version 2 as published by the Free Software Foundation.
 * REVISION HISTORY
 * Version 1.0 - Henrik Ekblad
 * DESCRIPTION
 * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
 * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
 * LED purposes:
 * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
 * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
 * - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
 * - ERR (red) - fast blink on error during transmission error or receive crc error
 * See https://www.mysensors.org/build/connect_radio for wiring instructions.
 * If you are using a "barebone" ESP8266, see
 * https://www.mysensors.org/build/ ... or-barebone-esp8266
 * Inclusion mode button:
 * - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
 * Hardware SHA204 signing is currently not supported!
 * Make sure to fill in your ssid and WiFi password below for ssid & pass.
// Enable debug prints to serial monitor
#define MY_DEBUG   //debug模式
// Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h
#define MY_BAUD_RATE 9600
// Enables and select radio type (if attached)
#define MY_RADIO_RF24
//#define MY_RADIO_RFM69
//#define MY_RADIO_RFM95
#define MY_GATEWAY_MQTT_CLIENT
#define MY_GATEWAY_ESP8266
// Set this node's subscribe and publish topic prefix
#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"    //MQTT 网关发送主题
#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"   //MQTT 网关接收主题
// Set MQTT client id
#define MY_MQTT_CLIENT_ID "mysensors-1"                 //MQTT 网关客户端ID
// Enable these if your MQTT broker requires username/password
#define MY_MQTT_USER "username"                //MQTT 网关用户验证 没有请注释
#define MY_MQTT_PASSWORD "password"                //MQTT 用户密码 同上没有请注释
// Set WIFI SSID and password
#define MY_WIFI_SSID "MySSID"        //wifi名称
#define MY_WIFI_PASSWORD "MyVerySecretPassword"        //wifi密码
//以下是静态设置,建议网关使用固定IP,路由或者以下固定都行
// Set the hostname for the WiFi Client. This is the hostname
// it will pass to the DHCP server if not static.
// #define MY_HOSTNAME "mqtt-sensor-gateway"
// Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP)
//#define MY_IP_ADDRESS 192,168,178,87
// If using static ip you can define Gateway and Subnet address as well
//#define MY_IP_GATEWAY_ADDRESS 192,168,178,1
//#define MY_IP_SUBNET_ADDRESS 255,255,255,0
// MQTT broker ip address.
#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68 //MQTT 网关地址
//MQTT broker if using URL instead of ip address.
// #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
// The MQTT broker port to to open
#define MY_PORT 1883 //MQTT 网关端口
//以下是授权信任设置 默认不用更改
// Enable inclusion mode
//#define MY_INCLUSION_MODE_FEATURE
// Enable Inclusion mode button on gateway
//#define MY_INCLUSION_BUTTON_FEATURE
// Set inclusion mode duration (in seconds)
//#define MY_INCLUSION_MODE_DURATION 60
// Digital pin used for inclusion mode button
//#define MY_INCLUSION_MODE_BUTTON_PIN D1
// Set blinking period
//#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Flash leds on rx/tx/err
//#define MY_DEFAULT_ERR_LED_PIN 16  // Error led pin
//#define MY_DEFAULT_RX_LED_PIN  16  // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN  16  // the PCB, on board LED
#include <ESP8266WiFi.h>
#include <MySensors.h>
void setup()
    // Setup locally attached sensors
void presentation()
    // Present locally attached sensors here
void loop()
    // Send locally attached sensors data here
此文件在ardunio 示例里面是存在的,这里重新啰嗦一下
端口网关
  ESP8266还可以充当UDP数据网关,官方有对应的软件可以使用,能详细查看日志和node数据,支持多种功能
下载链接:
ardunio请打开示例
参与人数 1金钱 +20 HASS币 +20 收起 理由
+ 20 + 20 膜拜大神!
huex
 楼主| 发表于 2019-1-26 00:55:16 | 显示全部楼层
刷机工具: flash.zip (21.83 KB, 下载次数: 11)
固件链接: GatewayESP8266MQTTClient.ino.d1_mini.bin (419.88 KB, 下载次数: 11)
发表于 2019-1-26 05:43:29 | 显示全部楼层
谢谢楼主分享!!!
发表于 2019-1-26 07:48:41 | 显示全部楼层
楼主6666666
我就是六神
活跃会员教程狂人灌水之王
发表于 2019-1-26 09:08:33 | 显示全部楼层
看天书一样  膜拜楼主~~
发表于 2019-1-26 15:00:56 | 显示全部楼层
楼主威武啊
发表于 2019-1-26 16:43:10 | 显示全部楼层
感谢分享,虽然不知道说的是啥
发表于 2019-1-26 21:33:44 | 显示全部楼层
学习学习
发表于 2019-1-26 22:41:14 | 显示全部楼层
谢谢楼主分享,能给个pcb我吗?
发表于 2019-1-27 08:34:45 | 显示全部楼层
MySensors是一个比较早的“智能开源硬件”项目,相关的硬件DIY可以在openhardware.io发布
GMT+8, 2025-8-9 14:32 , Processed in 0.323181 second(s), 9 queries , MemCached On.
