楼主: natic
[进阶教程] 基于Tasmota DIY红外遥控器,支持模拟空调浴霸等高码率信号
发表于 2020-1-3 09:28:34 | 显示全部楼层
需要红外发射,前来学习
发表于 2020-1-16 10:38:03 | 显示全部楼层
发表于 2020-1-16 16:38:51 | 显示全部楼层
谢谢分享
发表于 2020-1-20 16:50:57 | 显示全部楼层
谢谢分享
发表于 2020-2-12 14:07:45 来自手机 | 显示全部楼层
學習學習
发表于 2020-2-17 16:24:57 | 显示全部楼层
红外接收管怎样都学不到遥控器的码,更换了tasmota的好多版本都一样,红外接收管换了几个都一样,型号是1838B的
 楼主| 发表于 2020-2-18 08:03:57 | 显示全部楼层
kenlau 发表于 2020-2-17 16:24
红外接收管怎样都学不到遥控器的码,更换了tasmota的好多版本都一样,红外接收管换了几个都一样,型号是183 ...
用手机摄像头看一下遥控器红外的灯是不是亮的
发表于 2020-2-18 13:21:03 | 显示全部楼层
红外灯亮的,我用博联都可以学遥控器的码和控制,就是在tasmota那里学码没任何反应,不知道是不是固件版本的问题
发表于 2020-2-24 09:46:34 | 显示全部楼层
您好,从控制台看显示无效的02:42:18 MQT: stat/tasmota/RESULT = {"IRSend":"Invalid JSON"}
发送:0,3512,1712,504,426,504,1300,504,426,504,454,586,426,504,426,504,426,504,452,586,426,504,426,504,426,504,454,586,424,504,1302,502,426,504,454,586,424,504,426,504,426,504,454,586,1300,504,426,504,1300,504,1330,586,426,504,426,504,1300,504,452,586,426,504,1300,504,426,532,452,586,1300,504,426,504,1302,532,452,586,1300,506,1302,504,426,504,1330,586,1302,504,426,504,424,504,452,586,1302,504,426,504,426,504,452,586,1300,504,426,504,426,530,454,586,426,504,1300,502,428,530,452,586,426,504,426,504,426,504,452,586,1302,502,1302,504,426,530,454,614,426,504,424,506,424,504,454,586,426,504,426,504,1302,502,454,586,1300,504,426,504,424,532,454,586,1302,502,426,506,1300,502,454,586,426,504,424,504,426,504,452,586,426,504,1300,504,1302,502,452,588,426,504,424,504,426,504,454,584,426,504,426,504,426,504,1328,588,426,504,426,504,426,504,452,586,1302,502,1302,502,428,504,1328,642,30088,3512,1738,504,426,504,1328,532,452,532,452,586,424,504,452,532,452,532,452,586,426,504,454,530,454,532,454,584,428,504,1328,532,452,532,452,586,424,504,452,532,454,530,454,586,1302,504,454,530,1328,532,1328,588,424,504,452,532,1328,532,454,584,426,504,1328,534,452,530,452,586,1300,504,454,532,1330,530,454,586,1302,502,1330,532,452,530,1330,586,1300,504,452,532,452,532,452,586,1300,504,452,532,452,532,452,586,1300,504,454,532,452,532,452,586,426,504,1328,532,454,530,454,586,426,504,452,532,452,532,452,586,1300,504,1330,532,452,532,452,614,426,504,454,530,454,530,454,614,426,504,454,530,1330,532,452,612,1302,502,452,532,454,530,454,614,1300,504,454,532,1328,532,452,612,426,504,452,532,452,532,452,616,424,504,1328,532,1328,532,452,614,426,504,454,530,452,532,452,614,426,504,452,532,452,532,1328,612,424,506,452,532,452,532,452,614,1302,504,1328,532,452,530,1328,668
红外遥控器按下去接收的消息是:{"Time":"2020-02-24T02:41:05","IrReceived":{"Protocol":"UNKNOWN","Bits":212,"Hash":"0xB9F74553","RawData":[3512,1712,504,426,504,1300,504,426,504,454,586,426,504,426,504,426,504,452,586,426,504,426,504,426,504,454,586,424,504,1302,502,426,504,454,586,424,504,426,504,426,504,454,586,1300,504,426,504,1300,504,1330,586,426,504,426,504,1300,504,452,586,426,504,1300,504,426,532,452,586,1300,504,426,504,1302,532,452,586,1300,506,1302,504,426,504,1330,586,1302,504,426,504,424,504,452,586,1302,504,426,504,426,504,452,586,1300,504,426,504,426,530,454,586,426,504,1300,502,428,530,452,586,426,504,426,504,426,504,452,586,1302,502,1302,504,426,530,454,614,426,504,424,506,424,504,454,586,426,504,426,504,1302,502,454,586,1300,504,426,504,424,532,454,586,1302,502,426,506,1300,502,454,586,426,504,424,504,426,504,452,586,426,504,1300,504,1302,502,452,588,426,504,424,504,426,504,454,584,426,504,426,504,426,504,1328,588,426,504,426,504,426,504,452,586,1302,502,1302,502,428,504,1328,642,30088,3512,1738,504,426,504,1328,532,452,532,452,586,424,504,452,532,452,532,452,586,426,504,454,530,454,532,454,584,428,504,1328,532,452,532,452,586,424,504,452,532,454,530,454,586,1302,504,454,530,1328,532,1328,588,424,504,452,532,1328,532,454,584,426,504,1328,534,452,530,452,586,1300,504,454,532,1330,530,454,586,1302,502,1330,532,452,530,1330,586,1300,504,452,532,452,532,452,586,1300,504,452,532,452,532,452,586,1300,504,454,532,452,532,452,586,426,504,1328,532,454,530,454,586,426,504,452,532,452,532,452,586,1300,504,1330,532,452,532,452,614,426,504,454,530,454,530,454,614,426,504,454,530,1330,532,452,612,1302,502,452,532,454,530,454,614,1300,504,454,532,1328,532,452,612,426,504,452,532,452,532,452,616,424,504,1328,532,1328,532,452,614,426,504,454,530,452,532,452,614,426,504,452,532,452,532,1328,612,424,506,452,532,452,532,452,614,1302,504,1328,532,452,530,1328,668],"RawDataInfo":[423,423,0]}}
 楼主| 发表于 2020-2-24 15:52:10 | 显示全部楼层
发送:0,3512 ...
不要用控制台,用命令行
GMT+8, 2025-9-16 02:43 , Processed in 1.039928 second(s), 12 queries , MemCached On.
