楼主: xiamiok
[插件集成] [仅适用于lovelace UI] weather 组件的彩云天气平台
 楼主| 发表于 2019-1-17 18:16:00 | 显示全部楼层
qiaowei361 发表于 2019-1-11 21:46
不能使用,configuration.yaml要配置过吗?
要开启Lovelace UI
 楼主| 发表于 2019-1-17 18:17:10 | 显示全部楼层
windgo 发表于 2019-1-11 12:23
有辦法加入未來預測天氣的數值嗎?
剛裝好發覺沒有未來幾小時的預測了
不過還是很好看 感謝分享! ...
看有没有人做新的Weather Card了,我这只是简单地把彩云API的数据填进官方提供的Card里面
 楼主| 发表于 2019-1-17 18:18:54 | 显示全部楼层
sclsgj 发表于 2019-1-7 13:49
不能用,界面都没有显示处来
晕,这就神奇了,我有空加一下异常处理
发表于 2019-2-12 11:09:03 | 显示全部楼层
2月 12 11:22:35 mossbian hass[1183]: 2019-02-12 11:22:35 ERROR (MainThread) [homeassistant.components.weather] Error while setting up platform colorfulclouds
2月 12 11:22:35 mossbian hass[1183]: Traceback (most recent call last):
2月 12 11:22:35 mossbian hass[1183]:   File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
2月 12 11:22:35 mossbian hass[1183]:     SLOW_SETUP_MAX_WAIT, loop=hass.loop)
2月 12 11:22:35 mossbian hass[1183]:   File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
2月 12 11:22:35 mossbian hass[1183]:     return fut.result()
2月 12 11:22:35 mossbian hass[1183]:   File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
2月 12 11:22:35 mossbian hass[1183]:     raise self._exception
2月 12 11:22:35 mossbian hass[1183]:   File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
2月 12 11:22:35 mossbian hass[1183]:     result = self.fn(*self.args, **self.kwargs)
2月 12 11:22:35 mossbian hass[1183]:   File "/home/homeassistant/.homeassistant/custom_components/weather/colorfulclouds.py", line 28, in setup_platform
2月 12 11:22:35 mossbian hass[1183]:     name=config.get(CONF_NAME, 'colorfulclouds'))])
2月 12 11:22:35 mossbian hass[1183]:   File "/home/homeassistant/.homeassistant/custom_components/weather/colorfulclouds.py", line 40, in __init__
2月 12 11:22:35 mossbian hass[1183]:     self.update()
2月 12 11:22:35 mossbian hass[1183]:   File "/home/homeassistant/.homeassistant/custom_components/weather/colorfulclouds.py", line 95, in update
2月 12 11:22:35 mossbian hass[1183]:     self._realtime_data = json.loads(json_text)
2月 12 11:22:35 mossbian hass[1183]:   File "/usr/lib/python3.5/json/__init__.py", line 312, in loads
2月 12 11:22:35 mossbian hass[1183]:     s.__class__.__name__))
2月 12 11:22:35 mossbian hass[1183]: TypeError: the JSON object must be str, not 'bytes'
0.87用不起
发表于 2019-2-12 11:48:15 | 显示全部楼层
    def update(self):
        json_text = requests.get(str.format("https://api.caiyunapp.com/v2/{}/{},{}/realtime.json?unit=metric:v2", self._api_key, self._lng, self._lat)).content.decode("utf-8")
        json_text = requests.get(str.format("https://api.caiyunapp.com/v2/{}/{},{}/forecast.json?unit=metric:v2", self._api_key, self._lng, self._lat)).content.decode("utf-8")
        self._forecast_data = json.loads(json_text)
治好了,缺个.decode("utf-8")
发表于 2019-2-14 16:47:52 | 显示全部楼层
非常好,简单易用
发表于 2019-2-19 16:19:41 | 显示全部楼层
学习学习
发表于 2019-2-26 10:27:47 | 显示全部楼层
suwill 发表于 2019-2-12 11:09
[code]2月 12 11:22:35 mossbian hass[1183]: 2019-02-12 11:22:35 ERROR (MainThread) [hom ...
一模一样的问题
发表于 2019-2-26 19:22:52 | 显示全部楼层
这个和普通的有什么区别呢
发表于 2019-3-15 17:11:00 | 显示全部楼层
多谢楼主分享,多谢
GMT+8, 2025-9-19 02:57 , Processed in 1.289179 second(s), 10 queries , MemCached On.
