查看: 29863|回复: 19
[求助] HA登录失败 Unable to connect to Home Assistant
发表于 2018-12-9 11:03:35 | 显示全部楼层 |阅读模式
安装0.83.3后用电脑登录HA新建账号成功,之后用同一台电脑就一直无法登录,输入账号密码登录,在loading转圈之后就显示Unable to connect to Home Assistant.
用其他设备 手机、平板登录都没有问题,log显示
2018-12-09 01:39:21 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.1763354704] Disconnected: Did not receive auth message within 10 seconds
2018-12-09 01:50:12 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.1763422768] Disconnected: Did not receive auth message within 10 seconds
2018-12-09 01:58:36 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.123.2
2018-12-09 02:03:00 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.123.2
查看HA service显示
  01:39:01 mossbian hass[450]: 2018-12-09 01:39:01 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/token to 192.168.1.110 (auth: False)
  01:39:01 mossbian hass[450]: 2018-12-09 01:39:01 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.1.110 (auth: False)
  01:39:21 mossbian hass[450]: 2018-12-09 01:39:21 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.1763354704] Disconnected: Did not receive auth
  01:40:24 mossbian hass[450]: 2018-12-09 01:40:24 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/providers to 192.168.123.2 (auth: False)
  01:40:24 mossbian hass[450]: 2018-12-09 01:40:24 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/login_flow to 192.168.123.2 (auth: False)
  01:49:51 mossbian hass[450]: 2018-12-09 01:49:51 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/login_flow/1bd7eab2673742f4a4f1168783a5039e to 192.168
  01:49:52 mossbian hass[450]: 2018-12-09 01:49:52 INFO (MainThread) [homeassistant.components.http.view] Serving / to 192.168.123.2 (auth: False)
  01:49:52 mossbian hass[450]: 2018-12-09 01:49:52 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/token to 192.168.123.2 (auth: False)
  01:49:52 mossbian hass[450]: 2018-12-09 01:49:52 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.123.2 (auth: False)
  01:50:12 mossbian hass[450]: 2018-12-09 01:50:12 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.1763422768] Disconnected: Did not receive auth
安装之后没改任何配置就有这个问题,也没用过DDNS,添加trust network和使用legacy API都不行。换过几个不同的路由器也不行。
之前用过的没有换用新的Auth的版本登录都没有问题。
用其他设备登录也会出现 Login attempt or request with invalid authentication from XX, 但是都可以成功登录。只有我主要用的电脑不行。
找不出原因不知道怎么解决了,求大神帮助
发表于 2018-12-10 22:43:12 | 显示全部楼层
我也这样
 楼主| 发表于 2018-12-13 10:12:33 | 显示全部楼层
去官方论坛问了也没有什么解决方法。。倒是看到好几个一样问题的
lse 手机认证
发表于 2019-1-19 11:18:14 | 显示全部楼层
我是本地访问没问题,远程SSL访问不行。错误现象跟你一样
2019-01-19 11:16:27 INFO (MainThread) [homeassistant.components.http.view] Serving / to 114.222.184.199 (auth: False)
2019-01-19 11:16:28 INFO (MainThread) [homeassistant.components.http.view] Serving /manifest.json to 114.222.184.199 (auth: False)
发表于 2019-2-10 11:56:44 | 显示全部楼层
有没有解决呢?我也一样的问题
发表于 2019-7-28 15:40:34 | 显示全部楼层
我以前没有,这两天升级后,就这样了
Rie 手机认证
发表于 2019-8-14 08:42:38 | 显示全部楼层
我也一样 解决了吗
发表于 2020-2-17 23:26:14 | 显示全部楼层
也是这个问题,我的手机登录不了,其他设备正常登录,有知道原因的么
发表于 2020-2-21 18:12:43 | 显示全部楼层
同样的问题,你们现在解决了吗
发表于 2020-2-29 21:47:56 | 显示全部楼层
zxlch 发表于 2020-2-21 18:12
同样的问题,你们现在解决了吗
前几天忽然好了,莫名其妙的,也不知道问题出在哪儿
GMT+8, 2025-6-28 11:29 , Processed in 0.105138 second(s), 24 queries .
