查看: 7400|回复: 4
Hass.io Add-ons: SSH & Web Terminal 配置
发表于 2018-11-12 15:54:22 | 显示全部楼层 |阅读模式
Hass.io Add-ons: SSH & Web Terminal  这个插件怎么配置呢,我配置了用户名,服务可能启来,但是不能打开Web GUI,哪们配置过?
发表于 2018-11-12 16:07:08 | 显示全部楼层
要注意看日志
 楼主| 发表于 2018-11-12 16:14:38 | 显示全部楼层
日志内容
Hass.io Add-on: SSH & Web Terminal v3.5.0
SSH & Web Terminal access to your Home Assistant instance
By: Franck Nijhof <[email protected]>
armhf / Raspbian GNU/Linux 9 (stretch) / HA 0.82.0 / SU 139 / stable
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-requirements.sh: executing...
WARNING: Logging in with root use is security wise, a bad idea!
WARNING: Logging in with a SSH password is security wise, a bad idea!
WARNING: Please, consider using a public/private key pair
INFO: Password is NOT in the Have I Been Pwned database! Nice!
FATAL: The configured certfile is not found
[cont-init.d] 10-requirements.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
发表于 2018-12-19 14:43:07 | 显示全部楼层
我也是遇到这个问题,不用自己生成的KEY就可以
发表于 2020-1-31 21:21:36 | 显示全部楼层
设置好用户名和密码即可,如果端口被宿主机占用,就改下端口,启动后多刷新几次网页...
GMT+8, 2025-7-9 13:18 , Processed in 0.218099 second(s), 12 queries , MemCached On.
