查看: 18464|回复: 17
小度音箱pro拆解
发表于 2018-11-11 14:51:24 来自手机 | 显示全部楼层 |阅读模式
百度出了个小度音箱pro,就下单买了个玩玩
昨天到手了,今天就拆了看看
拆开发现电源接口处就直接引出了tx rx
连接看看可玩性大不大
AXG:BL1:d95c53:a4926f;FEAT:F0DC31BC:2000;POC:F;EMMC:800;NAND:0;READ:0;0.0;0.0;CHK:0;
sdio debug board detected
TE: 140893
BL2 Built : 15:37:12, Apr 28 2018. axg g9a42d9e - yuegui.he@droid13-sz
set vcck to 1070 mv
set vddee to 1070 mv
Board ID = 12
CPU clk: 1200MHz
DDR low power enabled
DDR3 chl: Rank0 16bit @ 912MHz
bist_test rank: 0 25 06 44 2e 11 4b 27 08 47 2d 10 4a 00 00 00 00 00 00 00 00 00 00 00 00 609   - PASS
Rank0: 128MB-2T-13
AddrBus test pass!
NAND init
chk page: 00000480
chk page: 000004c0
chk page: 00000500
chk page: 00000540
bbt blk:00000012
bbt page:00000000
0000000000000000000000000000000000000000000000000000000000000000
Load FIP HDR from NAND, src: 0x0000c000, des: 0x01700000, size: 0x00004000
Load BL3x from NAND, src: 0x00010000, des: 0x01704000, size: 0x00098000
NOTICE:  BL31: v1.3(release):a1a8551
NOTICE:  BL31: Built : 15:59:55, Nov  9 2017
NOTICE:  BL31: AXG secure boot!
NOTICE:  BL31: BL33 decompress pass
[Image: axg_v1.1.3268-b93dd79 2017-12-01 14:22:18 huan.biao@droid12]
OPS=0x42
92 6d e7 75 d6 64 44 8e d1 5 b8 da bl30:axg ver: 9 mode: 0
bl30:axg thermal0
[0.014567 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01 (Oct 17 2018 - 20:01:56)
DRAM:  128 MiB
Relocation Offset is: 06ec2000
register usb cfg[0][1] = 0000000007f571b8
NAND:  get_sys_clk_rate_mtd() 261, clock setting 200!
nand id: 0xec 0xf1
128MiB, SLC, page size: 2048, OOB size: 64
NAND device id: ec f1 0 95 42 c6
NAND device: Manufacturer ID: 0xec, Chip ID: 0xec (Samsung M Generation NAND 1Gib FS33ND01GS108TFI0)
m3_nand_adjust_timing() sys_clk_rate 200, bus_c 6, bus_t 7
oob_fill_cnt =32 oob_size =64, bch_bytes =14
ecc mode:6 ecc_page_num=2 eep_need_oobsize=16
plane_num=1 writesize=0x800 ecc.size=0x200 bch_mode=1
oob avail size 6
Creating 1 MTD partitions on "M Generation NAND 1Gib FS33ND01GS108TFI0":
0x000000000000-0x000000200000 : "bootloader"
M Generation NAND 1Gib FS33ND01GS108TFI0 initialized ok
nand id: 0xec 0xf1
PLANE change!
aml_nand_init :oobmul=1,oobfree.length=8,oob_size=64
oob avail size 8
bbt_start=18 env_start=22 key_start=26 dtb_start=30
nbbt: info size=0x400 max_scan_blk=22, start_blk=18
nbbt : phy_blk_addr=18, ec=0, phy_page_addr=0, timestamp=1
nbbt free list:
blockN=19, ec=-1, dirty_flag=0
blockN=20, ec=-1, dirty_flag=0
blockN=21, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1092: page_num=1
aml_nand_scan_rsv_info 1095
nbbt valid addr: 240000
aml_nand_bbt_check 1230 bbt is valid, reading.
aml_nand_read_rsv_info:397,read nbbt info to 240000
nenv: info size=0x10000 max_scan_blk=26, start_blk=22
nenv : phy_blk_addr=24, ec=0, phy_page_addr=0, timestamp=5
nenv free list:
blockN=22, ec=1, dirty_flag=1
blockN=23, ec=1, dirty_flag=1
blockN=25, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1092: page_num=32
nenv valid addr: 300000
nkey: info size=0x8000 max_scan_blk=30, start_blk=26
nkey : phy_blk_addr=27, ec=0, phy_page_addr=0, timestamp=2
nkey free list:
blockN=26, ec=0, dirty_flag=1
blockN=28, ec=-1, dirty_flag=0
blockN=29, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1092: page_num=16
nkey valid addr: 360000
ndtb: info size=0x20000 max_scan_blk=34, start_blk=30
ndtb : phy_blk_addr=-1, ec=0, phy_page_addr=0, timestamp=0
ndtb free list:
blockN=30, ec=-1, dirty_flag=0
blockN=31, ec=-1, dirty_flag=0
blockN=32, ec=-1, dirty_flag=0
blockN=33, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1092: page_num=64
ndtb valid addr: fffffffffffe0000
aml_nand_dtb_check 1206 NO dtb exist
tpl: off 4456448, size 2097152
 NAND bbt detect factory Bad block at 4060000
aml_nand_add_partition:1794 factory bad addr=203
 NAND bbt detect factory Bad block at 7fe0000
Creating 7 MTD partitions on "M Generation NAND 1Gib FS33ND01GS108TFI0":
0x000000440000-0x000000640000 : "tpl"
0x000000640000-0x000000a40000 : "boot0"
0x000000a40000-0x000000e40000 : "boot1"
0x000000e40000-0x000002240000 : "system0"
0x000002240000-0x000003640000 : "system1"
0x000003640000-0x000006c60000 : "opt"
0x000006c60000-0x000008000000 : "data"
aml_key_init 170
MMC:   aml_priv->desc_buf = 0x0000000006fc9720
aml_priv->desc_buf = 0x0000000006fcba40
SDIO Port B: 0, SDIO Port C: 1
uboot env amlnf_env_read : ####
aml_nand_read_rsv_info:397,read nenv info to 300000
In:    serial
Out:   serial
Err:   serial
[burnup]Rd:Up sz 0x800 to align 0x1000
[burnup]Rd:Up sz 0x8800 to align 0x1000
Net:   Phy 0 not found
dwmac.ff3f0000amlkey_init() enter!
amlnf_key_read key data len too much
aml_nand_read_rsv_info:397,read nkey info to 360000
[EFUSE_MSG]keynum is 4
[KM]Error:f[keymanage_dts_get_key_device]L85:mac key name is not exist
[KM]Error:f[_get_km_ops_by_name]L231:key mac not know device 4
[KM]Error:f[key_unify_query_exist]L350:key[mac] not cfg in dts
MACADDR:02:8e:d1:05:b8:da(from chipid)
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
InUsbBurn
noSof
amlkey_init() 71: already init!
[burnup]Rd:Up sz 0x27af64 to align 0x1000
aml log : Sig Check 1275
save_power_post ...
## Booting Android Image at 0x01080000 ...
reloc_addr =6ff3c50
copy done
load dtb from 0x1000000 ......
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x017dd008
[rsvmem] no check for rsvmem, should check int kernel
   Loading Device Tree to 0000000006fa4000, end 0000000006faf763 ... OK
Starting kernel ...
uboot time: 2048161 us
[    0.000000@0] Booting Linux on physical CPU 0x0
[    0.000000@0] Linux version 4.9.54 (builder@xiaolu-OptiPlex-7050) (gcc version 6.4.1 20171012 (Linaro GCC 6.4-2017.11) ) #1 SMP PREEMPT Wed Oct 17 20:05:49 CST 2018
[    0.000000@0] Boot CPU: AArch64 Processor [410fd034]
[    0.000000@0] earlycon: aml_uart0 at MMIO 0x00000000ff803000 (options '')
[    0.000000@0] bootconsole [aml_uart0] enabled
[    0.000000@0] psci: probing for conduit method from DT.
[    0.000000@0] psci: PSCIv1.0 detected in firmware.
[    0.000000@0] psci: Using standard PSCI v0.2 function IDs
[    0.000000@0] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000@0] percpu: Embedded 20 pages/cpu @ffffffc007f70000 s44440 r8192 d29288 u81920
[    0.000000@0] Detected VIPT I-cache on CPU0
[    0.000000@0] CPU features: enabling workaround for ARM erratum 845719
[    0.000000@0] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 31488
[    0.000000@0] Kernel command line: noinitrd ubi.mtd=5,2048 rootfstype=ubifs root=ubi0:rootfs init=/sbin/init console=ttyS0,115200 no_console_suspend earlycon=aml_uart,0xff803000
[    0.000000@0] PID hash table entries: 512 (order: 0, 4096 bytes)
[    0.000000@0] Dentry cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.000000@0] Inode-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.000000@0] Memory: 116776K/128000K available (5310K kernel code, 372K rwdata, 1484K rodata, 320K init, 814K bss, 11224K reserved, 0K cma-reserved)
[    0.000000@0] Virtual kernel memory layout:
[    0.000000@0]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000@0]     vmalloc : 0xffffff8008000000 - 0xffffff8108000000   (     4 GB)
[    0.000000@0]       .text : 0xffffff8009080000 - 0xffffff80095b0000   (  5312 KB)
[    0.000000@0]     .rodata : 0xffffff80095b0000 - 0xffffff8009730000   (  1536 KB)
[    0.000000@0]       .init : 0xffffff8009730000 - 0xffffff8009780000   (   320 KB)
[    0.000000@0]       .data : 0xffffff8009780000 - 0xffffff80097dd008   (   373 KB)
[    0.000000@0]        .bss : 0xffffff80097dd008 - 0xffffff80098a8864   (   815 KB)
[    0.000000@0]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000@0]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000@0]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000@0]               0xffffffbf00000000 - 0xffffffbf00200000   (     2 MB actual)
[    0.000000@0]     memory  : 0xffffffc000000000 - 0xffffffc008000000   (   128 MB)
[    0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000@0] Preemptible hierarchical RCU implementation.
[    0.000000@0]        Build-time adjustment of leaf fanout to 64.
[    0.000000@0]        RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000@0] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000@0] NR_IRQS:64 nr_irqs:64 0
[    0.000000@0] axg_aoclkc_init: register ao clk ok![    0.000000@0] axg_amlogic_init_sdemmc: register amlogic sdemmc clk
[    0.000000@0] axg_amlogic_init_media: register meson media clk
[    0.000000@0] axg_amlogic_init_misc: register amlogic axg misc clks
[    0.000000@0] axg_amlogic_init_misc: register amlogic sdemmc clk
[    0.000000@0] axg_clkc_init initialization complete
[    0.000000@0] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000@0] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000003@0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008249@0] meson_bc_timer: mclk->mux_reg =ffffff8008008190,mclk->reg =ffffff800800a194
[    0.016783@0] Console: colour dummy device 80x25
[    0.021104@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.031586@0] pid_max: default: 32768 minimum: 301
[    0.036475@0] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
[    0.043143@0] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
[    0.050982@0] sched-energy: CPU device node has no sched-energy-costs
[    0.056819@0] Invalid sched_group_energy for CPU0
[    0.061519@0] CPU0: update cpu_capacity 1024
[    0.065815@0] ASID allocator initialised with 65536 entries
[    0.103695@0] Meson chip version = RevB (25:B - 42:0)
[    0.139705@1] Detected VIPT I-cache on CPU1
[    0.139755@1] Invalid sched_group_energy for CPU1
[    0.139758@1] CPU1: update cpu_capacity 1024
[    0.139760@1] CPU1: Booted secondary processor [410fd034]
[    0.167742@2] Detected VIPT I-cache on CPU2
[    0.167775@2] Invalid sched_group_energy for CPU2
[    0.167777@2] CPU2: update cpu_capacity 1024
[    0.167780@2] CPU2: Booted secondary processor [410fd034]
[    0.195793@3] Detected VIPT I-cache on CPU3
[    0.195822@3] Invalid sched_group_energy for CPU3
[    0.195825@3] CPU3: update cpu_capacity 1024
[    0.195827@3] CPU3: Booted secondary processor [410fd034]
[    0.195890@0] Brought up 4 CPUs
[    0.249287@0] SMP: Total of 4 processors activated.
[    0.254195@0] CPU features: detected feature: 32-bit EL0 Support
[    0.260269@0] CPU: All CPU(s) started at EL2
[    0.264535@0] alternatives: patching kernel code
[    0.269262@0] Invalid sched_group_energy for CPU3
[    0.273885@0] Invalid sched_group_energy for Cluster3
[    0.278955@0] Invalid sched_group_energy for CPU2
[    0.283680@0] Invalid sched_group_energy for Cluster2
[    0.288754@0] Invalid sched_group_energy for CPU1
[    0.293480@0] Invalid sched_group_energy for Cluster1
[    0.298554@0] Invalid sched_group_energy for CPU0
[    0.303280@0] Invalid sched_group_energy for Cluster0
[    0.308864@0] devtmpfs: initialized
[    0.320792@0] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.325126@0] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.331693@0] pinctrl core: initialized pinctrl subsystem
[    0.337983@0] NET: Registered protocol family 16
[    0.357714@0] cpuidle: using governor menu
[    0.357931@0] vdso: 2 pages (1 code @ ffffff80095b7000, 1 data @ ffffff8009784000)
[    0.363804@0] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.370992@0] DMA: preallocated 256 KiB pool for atomic allocations
domain-0 init dvfs: 4
[    0.385301@0] aml_iomap: amlogic iomap probe done
[    0.397057@0] aml_snd_reg_map[0], reg:ff632000, size:20
[    0.397101@0] aml_snd_reg_map[1], reg:ff642000, size:2000
[    0.402089@0] aml snd iomap probe done
[    0.406740@0] irq: type mismatch, failed to map hwirq-103 for /interrupt-controller@2c001000!
[    0.443479@2] pps_core: LinuxPPS API ver. 1 registered
[    0.443511@2] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email][email protected][/email]>
[    0.452755@2] PTP clock support registered
[    0.456882@2] aml_i2c version: 20140813
[    0.460914@2] aml-i2c ff805000.i2c: add adapter aml_i2c_adap0(ffffffc0069d08d0)
[    0.468213@2] aml-i2c ffd1e000.i2c: add adapter aml_i2c_adap2(ffffffc0069d10d0)
[    0.475423@2] Advanced Linux Sound Architecture Driver Initialized.
[    0.481868@2] Bluetooth: Core ver 2.22
[    0.485114@2] NET: Registered protocol family 31
[    0.489727@2] Bluetooth: HCI device and connection manager initialized
[    0.496289@2] Bluetooth: HCI socket layer initialized
[    0.501351@2] Bluetooth: L2CAP socket layer initialized
[    0.506630@2] Bluetooth: SCO socket layer initialized
[    0.512572@3] clocksource: Switched to clocksource arch_sys_counter
[    0.526445@3] NET: Registered protocol family 2
[    0.526981@3] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[    0.532540@3] TCP bind hash table entries: 1024 (order: 2, 16384 bytes)
[    0.539195@3] TCP: Hash tables configured (established 1024 bind 1024)
[    0.545804@3] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.551781@3] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.558410@3] NET: Registered protocol family 1
[    0.564138@3] led pwm dt ok
[    0.565616@3] pwm conf ok
[    0.568669@3] wifi: power_on_pin_OD = 0;
[    0.572151@3] aml_wifi wifi: [wifi_dev_probe] no power_on_pin2
[    0.578088@3] aml_wifi wifi: [pwm_double_channel_conf_dt] wifi pwm dt ok
[    0.584769@3] aml_wifi wifi: [pwm_double_channel_conf] wifi pwm conf ok
[    0.591405@3] aml_wifi wifi: [wifi_dev_probe] dhd_static_buf setup
[    0.597835@3] Wifi: bcmdhd_init_wlan_mem: bcmdhd_init_wlan_mem prealloc ok
[    0.604530@3] aml_wifi wifi: [wifi_dev_probe] interrupt_pin=68
[    0.610395@3] aml_wifi wifi: [wifi_dev_probe] irq_num=0, irq_trigger_type=1
[    0.617390@3] aml_wifi wifi: [wifi_dev_probe] power_on_pin=69
[    0.623170@3] aml_wifi wifi: [wifi_dev_probe] clock_32k_pin=0
[    0.629155@3] aml_wifi wifi: [wifi_setup_dt] wifi_setup_dt
[    0.634489@3] aml_wifi wifi: [wifi_setup_dt] irq num is:(91)
[    0.640141@3] aml_wifi wifi: [wifi_setup_dt] interrupt_pin(68)
[    0.646014@3] aml_wifi wifi: [wifi_setup_dt] power_on_pin(69)
[    0.652345@3] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.660998@3] audit: initializing netlink subsys (disabled)
[    0.665400@3] audit: type=2000 audit(0.584:1): initialized
[    0.671500@3] workingset: timestamp_bits=62 max_order=15 bucket_order=0
[    0.684779@3] fuse init (API version 7.26)
[    0.687831@3] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.690865@3] io scheduler noop registered
[    0.694963@3] io scheduler deadline registered
[    0.699596@3] io scheduler cfq registered (default)
[    0.711954@3] Unable to detect cache hierarchy from DT for CPU 0
[    0.718213@3] loop: module loaded
[    0.718965@3] zram: Added device: zram0
[    0.719942@3] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.726699@3] tun: Universal TUN/TAP device driver, 1.6
[    0.731645@3] tun: (C) 1999-2004 Max Krasnyansky <[email][email protected][/email]>
[    0.738372@3] i2c /dev entries driver
[    0.742015@3] Bluetooth: HCI UART driver ver 2.3
[    0.746351@3] Bluetooth: HCI UART protocol H4 registered
[    0.752606@3] cpu cpu0: bL_cpufreq_init: CPU 0 initialized
[    0.759022@0] arm_big_little: bL_cpufreq_register: Registered platform driver: scpi
[    0.766116@0] ff803000.serial: clock gate not found
[    0.769863@0] meson_uart ff803000.serial: ==uart0 reg addr = ffffff80080d9000
[    0.777006@0] ff803000.serial: ttyS0 at MMIO 0xff803000 (irq = 124, base_baud = 1500000) is a meson_uart
[    0.792086@0] meson_uart ff803000.serial: ttyS0 use xtal(8M) 24000000 change 0 to 115200
[    0.794684@0] console [ttyS0] enabled
[    0.801895@1] bootconsole [aml_uart0] disabled
[    0.811300@1] meson_uart ffd24000.serial: ==uart1 reg addr = ffffff80080db000
[    0.817814@1] ffd24000.serial: ttyS1 at MMIO 0xffd24000 (irq = 139, base_baud = 1500000) is a meson_uart
[    0.827765@1] secmon: reserve memory init fail:-22
[    0.831911@1] secmon: probe of secmon failed with error -22
[    0.837768@1] cpuinfo: failed to allocate shared memory
[    0.842600@1] cpuinfo: probe of cpu_info failed with error -12
[    0.848807@1] clkmsr: msr_clk_reg0=ffffff80080fe004,msr_clk_reg2=ffffff800820100c
[    0.855894@1] clkmsr: clkmsr: driver init
[    0.860173@1] aml_aes_dma ff63e000.aml_aes: Aml AES_dma
[    0.865645@1] aml_sha_dma ff63e000.aml_sha: Aml SHA1/SHA224/SHA256 dma
[    0.871674@1] gpio-key gpio_keypad: gpio_key: 0 name(power) pin()
[    0.877444@1] gpio-key gpio_keypad: amlogic_gpio_name_map_num pin 0!::
[    0.883917@1] gpio-key gpio_keypad: gpio_key: 0 power(13)
[    0.889283@1] gpio-key gpio_keypad: start setup_timer
[    0.894260@1] gpio-key gpio_keypad: power key(117) registed.
[    0.900032@1] input: gpio_keypad as /devices/platform/gpio_keypad/input/input0
[    0.907202@1] gpio-key gpio_keypad: gpio keypad register input device completed.
[    0.914357@1] input input0: gpio keypad major:245
[    0.919434@1] efusekeynum: 4
[    0.921871@1] efusekeyname:             mac  offset:     0   size:     6
[    0.928240@1] efusekeyname:          mac_bt  offset:     6   size:     6
[    0.934625@1] efusekeyname:        mac_wifi  offset:    12   size:     6
[    0.941007@1] efusekeyname:            usid  offset:    18   size:    16
[    0.947643@1] efuse efuse: probe OK!
[    0.951785@1] mmc driver version: 3.02, 2017-05-15: New Emmc Host Controller
[    0.958473@1] core->rate: 166666504
[    0.961366@1] core->name: axg_emmc_b
[    0.964907@1] rate: 24000000, name: sd_emmc_p0_B_comp
[    0.969909@1] rate: 999999023, name: fclk_div2
[    0.974288@1] clk_name: ffe05000.sdio#mux
[    0.978310@1] [aml_emmc_clktree_init] clock: 0x0
[    0.982904@1] get property:                ocr_avail, value:0x00200080
[    0.989298@1] get property:                    f_min, value:400000
[    0.995418@1] get property:                    f_max, value:50000000
[    1.001749@1] input input0: key 117 up
[    1.005426@1] get property:             max_req_size, value:0x00020000
[    1.011898@1] get property:                  pinname, str:sdio
[    1.017673@1] get property:                card_type, value:3
[    1.023363@1] get property:              pinmux_base, value:0xff634400
[    1.029859@1] sdio:pdata->caps = 7810f
 楼主| 发表于 2018-11-11 18:29:58 | 显示全部楼层
Starting Nmap 7.70 ( [url]https://nmap.org[/url] ) at 2018-11-11 18:24 CST
NSE: Failed to load '/usr/local/bin/../share/nmap/scripts/http-favicon.nse'.
NSE: Failed to load '/usr/local/bin/../share/nmap/scripts/ipv6-node-info.nse'.
NSE: Failed to load '/usr/local/bin/../share/nmap/scripts/iscsi-info.nse'.
NSE: Failed to load '/usr/local/bin/../share/nmap/scripts/mongodb-databases.nse'.
NSE: Failed to load '/usr/local/bin/../share/nmap/scripts/mongodb-info.nse'.
NSE: Failed to load '/usr/local/bin/../share/nmap/scripts/sip-methods.nse'.
NSE: Failed to load '/usr/local/bin/../share/nmap/scripts/ssh-hostkey.nse'.
NSE: Loaded 141 scripts for scanning.
NSE: Script Pre-scanning.
Initiating NSE at 18:24
Completed NSE at 18:24, 0.00s elapsed
Initiating ARP Ping Scan at 18:24
Scanning 192.168.2.25 [1 port]
Completed ARP Ping Scan at 18:24, 0.08s elapsed (1 total hosts)
Initiating Parallel DNS resolution of 1 host. at 18:24
Completed Parallel DNS resolution of 1 host. at 18:24, 0.00s elapsed
Initiating SYN Stealth Scan at 18:24
Scanning Xiaodu-AudioSpeaker.lan (192.168.2.25) [65535 ports]
Discovered open port 8600/tcp on 192.168.2.25
Discovered open port 8883/tcp on 192.168.2.25
Discovered open port 4369/tcp on 192.168.2.25
Discovered open port 1883/tcp on 192.168.2.25
Discovered open port 8000/tcp on 192.168.2.25
Completed SYN Stealth Scan at 18:25, 49.98s elapsed (65535 total ports)
Initiating Service scan at 18:25
Scanning 5 services on Xiaodu-AudioSpeaker.lan (192.168.2.25)
Completed Service scan at 18:26, 25.99s elapsed (5 services on 1 host)
Initiating OS detection (try #1) against Xiaodu-AudioSpeaker.lan (192.168.2.25)
NSE: Script scanning 192.168.2.25.
Initiating NSE at 18:26
Completed NSE at 18:26, 0.46s elapsed
Completed NSE at 18:26, 0.00s elapsed
Nmap scan report for Xiaodu-AudioSpeaker.lan (192.168.2.25)
Host is up (0.0069s latency).
Not shown: 65530 closed ports
PORT     STATE SERVICE VERSION
1883/tcp open  mqtt
|_mqtt-subscribe: Connection rejected: Not Authorized
4369/tcp open  epmd    Erlang Port Mapper Daemon
| epmd-info:
|   epmd_port: 4369
|_  nodes:
8000/tcp open  upnp
| fingerprint-strings:
|   FourOhFourRequest, HTTPOptions:
|     HTTP/1.1 404 Not Found
|     connection: close
|     content-length: 9
|     date: Sun, 11 Nov 2018 10:25:53 GMT
|     server: Posix/200809.0 UPnP/1.0 rock/1.0
|     found
|   GetRequest:
|     connection: close
|     content-length: 9
|     date: Sun, 11 Nov 2018 10:25:52 GMT
|     found
|   RTSPRequest:
|     HTTP/1.1 505 HTTP Version Not Supported
|     connection: close
|     content-length: 0
|   SIPOptions:
|     HTTP/1.1 400 Bad Request
|     connection: close
|_    content-length: 0
|_http-server-header: Posix/200809.0 UPnP/1.0 rock/1.0
|_http-title: Site doesn't have a title.
8600/tcp open  webdav
|   GenericLines, SIPOptions:
|     Cache-Control: no-cache, no-store, must-revalidate, private, max-age=0
|     Pragma: no-cache
|     Expires: 0
|     Content-Type: text/plain; charset=utf-8
|     Date: Sun, 11 Nov 2018 10:25:48 GMT
|     Connection: close
|     Error 400: Bad Request
|     request
|   GetRequest:
|     HTTP/1.1 200 OK
|     Cache-Control: max-age=3600
|     Last-Modified: Fri, 07 Sep 2018 06:27:47 GMT
|     Etag: "5b921a63.0"
|     Content-Type: text/html
|     Content-Length: 0
|     Connection: close
|     Accept-Ranges: bytes
|   HTTPOptions:
|     HTTP/1.1 200 OK
|     Connection: close
|     Allow: GET, POST, HEAD, CONNECT, PUT, DELETE, OPTIONS, PROPFIND, MKCOL
|_    DAV: 1
|_http-cors: HEAD GET POST PUT DELETE TRACE OPTIONS CONNECT PATCH
| http-methods:
|   Supported Methods: GET POST HEAD CONNECT PUT DELETE OPTIONS PROPFIND MKCOL
|_  Potentially risky methods: CONNECT PUT DELETE PROPFIND MKCOL
|_http-svn-info: ERROR: Script execution failed (use -d to debug)
|_http-title: Site doesn't have a title (text/html).
| http-webdav-scan:
|   Allowed Methods: GET, POST, HEAD, CONNECT, PUT, DELETE, OPTIONS, PROPFIND, MKCOL
|   WebDAV type: Unkown
|_  Server Date: Sun, 11 Nov 2018 10:26:09 GMT
8883/tcp open  ssl
|_mqtt-subscribe: sorry, you don't have OpenSSL
|_ssl-date: TLS randomness does not represent time
2 services unrecognized despite returning data. If you know the service/version, please submit the following fingerprints at [url]https://nmap.org/cgi-bin/submit.cgi?new-service[/url] :
==============NEXT SERVICE FINGERPRINT (SUBMIT INDIVIDUALLY)==============
SF-Port8000-TCP:V=7.70%I=7%D=11/11%Time=5BE803B1%P=x86_64-apple-darwin17.7
SF:.0%r(GetRequest,98,"HTTP/1\.1\x20404\x20Not\x20Found\r\nconnection:\x20
SF:close\r\ncontent-length:\x209\r\ndate:\x20Sun,\x2011\x20Nov\x202018\x20
SF:10:25:52\x20GMT\r\nserver:\x20Posix/200809\.0\x20UPnP/1\.0\x20rock/1\.0
SF:\r\n\r\nnot\x20found")%r(FourOhFourRequest,98,"HTTP/1\.1\x20404\x20Not\
SF:x20Found\r\nconnection:\x20close\r\ncontent-length:\x209\r\ndate:\x20Su
SF:n,\x2011\x20Nov\x202018\x2010:25:53\x20GMT\r\nserver:\x20Posix/200809\.
SF:0\x20UPnP/1\.0\x20rock/1\.0\r\n\r\nnot\x20found")%r(HTTPOptions,98,"HTT
SF:P/1\.1\x20404\x20Not\x20Found\r\nconnection:\x20close\r\ncontent-length
SF::\x209\r\ndate:\x20Sun,\x2011\x20Nov\x202018\x2010:25:53\x20GMT\r\nserv
SF:er:\x20Posix/200809\.0\x20UPnP/1\.0\x20rock/1\.0\r\n\r\nnot\x20found")%
SF:r(RTSPRequest,51,"HTTP/1\.1\x20505\x20HTTP\x20Version\x20Not\x20Support
SF:ed\r\nconnection:\x20close\r\ncontent-length:\x200\r\n\r\n")%r(SIPOptio
SF:ns,42,"HTTP/1\.1\x20400\x20Bad\x20Request\r\nconnection:\x20close\r\nco
SF:ntent-length:\x200\r\n\r\n");
SF-Port8600-TCP:V=7.70%I=7%D=11/11%Time=5BE803AC%P=x86_64-apple-darwin17.7
SF:.0%r(GenericLines,105,"HTTP/1\.1\x20400\x20Bad\x20Request\r\nCache-Cont
SF:rol:\x20no-cache,\x20no-store,\x20must-revalidate,\x20private,\x20max-a
SF:ge=0\r\nPragma:\x20no-cache\r\nExpires:\x200\r\nContent-Type:\x20text/p
SF:lain;\x20charset=utf-8\r\nDate:\x20Sun,\x2011\x20Nov\x202018\x2010:25:4
SF:8\x20GMT\r\nConnection:\x20close\r\n\r\nError\x20400:\x20Bad\x20Request
SF:\nBad\x20request")%r(GetRequest,EC,"HTTP/1\.1\x20200\x20OK\r\nDate:\x20
SF:Sun,\x2011\x20Nov\x202018\x2010:25:48\x20GMT\r\nCache-Control:\x20max-a
SF:ge=3600\r\nLast-Modified:\x20Fri,\x2007\x20Sep\x202018\x2006:27:47\x20G
SF:MT\r\nEtag:\x20"5b921a63\.0"\r\nContent-Type:\x20text/html\r\nContent
SF:-Length:\x200\r\nConnection:\x20close\r\nAccept-Ranges:\x20bytes\r\n\r\
SF:n")%r(HTTPOptions,9B,"HTTP/1\.1\x20200\x20OK\r\nDate:\x20Sun,\x2011\x20
SF:Nov\x202018\x2010:25:48\x20GMT\r\nConnection:\x20close\r\nAllow:\x20GET
SF:,\x20POST,\x20HEAD,\x20CONNECT,\x20PUT,\x20DELETE,\x20OPTIONS,\x20PROPF
SF:IND,\x20MKCOL\r\nDAV:\x201\r\n\r\n")%r(SIPOptions,105,"HTTP/1\.1\x20400
SF:\x20Bad\x20Request\r\nCache-Control:\x20no-cache,\x20no-store,\x20must-
SF:revalidate,\x20private,\x20max-age=0\r\nPragma:\x20no-cache\r\nExpires:
SF:\x200\r\nContent-Type:\x20text/plain;\x20charset=utf-8\r\nDate:\x20Sun,
SF:\x2011\x20Nov\x202018\x2010:25:48\x20GMT\r\nConnection:\x20close\r\n\r\
SF:nError\x20400:\x20Bad\x20Request\nBad\x20request");
MAC Address: 88:2D:53:1B:9A:7C (Unknown)
Device type: general purpose
Running: Linux 3.X|4.X
OS CPE: cpe:/o:linux:linux_kernel:3 cpe:/o:linux:linux_kernel:4
OS details: Linux 3.2 - 4.9
Uptime guess: 0.000 days (since Sun Nov 11 18:25:56 2018)
Network Distance: 1 hop
TCP Sequence Prediction: Difficulty=261 (Good luck!)
IP ID Sequence Generation: All zeros
TRACEROUTE
HOP RTT     ADDRESS
1   6.92 ms Xiaodu-AudioSpeaker.lan (192.168.2.25)
NSE: Script Post-scanning.
Read data files from: /usr/local/bin/../share/nmap
OS and Service detection performed. Please report any incorrect results at [url]https://nmap.org/submit/[/url] .
Nmap done: 1 IP address (1 host up) scanned in 79.25 seconds
           Raw packets sent: 70252 (3.092MB) | Rcvd: 68704 (2.749MB)
突出贡献
发表于 2018-11-11 19:21:40 | 显示全部楼层
未完待续?
流水无味
灌水之王
发表于 2018-11-11 21:30:12 | 显示全部楼层
我昨天到手的pro,期待
流水无味
灌水之王
发表于 2018-11-11 21:32:35 | 显示全部楼层
楼主总结下啊,我等小白看不懂,给点期待啊
 楼主| 发表于 2018-11-11 22:13:42 | 显示全部楼层
进不去系统
发表于 2018-11-12 09:09:05 | 显示全部楼层
没shell?
 楼主| 发表于 2018-11-12 09:25:18 来自手机 | 显示全部楼层
neroxps 发表于 2018-11-12 09:09
没shell?
嗯嗯,是的
发表于 2018-11-12 11:52:24 | 显示全部楼层
我也是昨天刚到手, 弄了一天, 通过百度开放的接口, 接入了ha, 目前已实现窗帘, aqara开关, 小米扫地机器人, 晚点完善一下把插件发出来.
发表于 2018-11-12 13:30:54 | 显示全部楼层
zhkufish 发表于 2018-11-12 11:52
我也是昨天刚到手, 弄了一天, 通过百度开放的接口, 接入了ha, 目前已实现窗帘, aqara开关, 小米扫地机器人, ...
大神 小度在家不知支持不 应该用的一个系统
GMT+8, 2025-8-2 19:09 , Processed in 0.333192 second(s), 12 queries , MemCached On.
