查看: 22395|回复: 22
[修仙教程] 【屠龙秘术第一式】青春永驻。0.77获取长期令牌的方法
发表于 2018-8-30 08:38:27 | 显示全部楼层 |阅读模式
Gist连接
暂时解决没有长期生效令牌的方案。适用0.77,至少需要创建一个用户。
执行以下脚本,注意修改配置文件目录。把输出的Bearer Token记录下来。
然后就可以使用这个Token进行API访问了。
import os
from datetime import timedelta
from homeassistant import auth, core, config as conf_util
CLIENT_ID = 'long_lived_client'
LIFE_TIME = timedelta(days=3650)
async def create_refresh_token(auth_mgr: auth.AuthManager,
                               owner: auth.models.User):
    """Create a refresh token for owner."""
    refresh_token = auth.models.RefreshToken(
        user=owner,
        access_token_expiration=LIFE_TIME,
        client_id=CLIENT_ID,
    owner.refresh_tokens[refresh_token.id] = refresh_token
    # hack code to save refresh_token
    await auth_mgr._store._store.async_save(
        auth_mgr._store._data_to_save())
    print('Created a new refresh token for {}: {}'.format(
        CLIENT_ID, refresh_token.id))
    return refresh_token
async def get_long_live_access_token(auth_mgr: auth.AuthManager):
    """Create a bearer token for owner."""
    owner = [u for u in await auth_mgr.async_get_users() if u.is_owner][0]
    print('Owner name is {}\n'.format(owner.name))
    refresh_token = None
    for token in owner.refresh_tokens.values():
        if token.client_id == CLIENT_ID:
            refresh_token = token
            break
    if not refresh_token:
        refresh_token = await create_refresh_token(auth_mgr, owner)
    # get access_token, it won't saved
    access_token = auth_mgr.async_create_access_token(refresh_token)
    print('Add following HTTP header to your REST API'
          ' and Websocket API request:')
    print('Authorization: Bearer {}'.format(access_token))
# change to your config path
config_dir = conf_util.get_default_config_dir()
config_path = conf_util.ensure_config_exists(config_dir)
print('Loading config from {}'.format(config_path))
config_dict = conf_util.load_yaml_config_file(config_path)
core_config = config_dict.get('homeassistant', {})
hass = core.HomeAssistant()
hass.config.config_dir = os.path.abspath(os.path.dirname(config_path))
hass.loop.run_until_complete(
    conf_util.async_process_ha_core_config(
        hass, core_config, False, False))
    get_long_live_access_token(hass.auth))
参与人数 2金钱 +40 收起 理由
Mirukuteii + 20 膜拜官方认证系统缔造者
+ 20 目测楼主是大神,技术达人走起。.
发表于 2018-8-30 09:39:31 | 显示全部楼层
帮LZ顶上去,感谢lz分享精神
发表于 2018-8-30 09:44:54 | 显示全部楼层
GPSlogger,具体应该怎么设置,能给个详细教程吗?
发表于 2018-8-30 09:46:22 | 显示全部楼层
虽然不明所以,还是要顶一下
发表于 2018-8-30 11:08:39 | 显示全部楼层
3650天的期限,哈哈。
发表于 2018-8-30 16:35:14 | 显示全部楼层
66666666666666
发表于 2018-9-2 20:40:30 | 显示全部楼层
执行后报错:
  File "long_live_access_token.py", line 10
SyntaxError: invalid syntax
 楼主| 发表于 2018-9-4 07:45:09 | 显示全部楼层
Python 3.5及以上
发表于 2018-9-4 14:53:31 | 显示全部楼层
  File "long_live_access_token.py", line 4, in <module>
ImportError: No module named 'homeassistant'
这个怎么解?
发表于 2018-9-5 12:00:49 | 显示全部楼层
大神牛逼,刚在gayhub看到你了。
GMT+8, 2025-9-15 03:23 , Processed in 0.710098 second(s), 11 queries , MemCached On.
