楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2021-3-21 23:02:51 | 显示全部楼层
asdasdqqq 发表于 2021-3-7 04:09
Armbian_20.10_Arm-64_bionic_current_5.9.0.img.xz
Armbian_20.10_Arm-64_bullseye_current_5.9.0.img.x ...
我也下载了这个版本,安装完跑脚本的时候为啥第一步换源就说不识别系统版本呢?
发表于 2021-3-23 19:04:45 | 显示全部楼层
这个帖子写的好,对新手相当的友好。
发表于 2021-3-25 10:13:02 | 显示全部楼层
21-03-25 01:52:38 ERROR (SyncWorker_1) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error for http+docker://localhost/v1.41/containers/create?name=hassio_dns: Bad Request ("create yes/dns: "yes/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")
21-03-25 01:52:38 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin
21-03-25 01:52:38 ERROR (MainThread) [supervisor.misc.tasks] CoreDNS watchdog reanimation failed!
21-03-25 01:53:23 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with PulseAudio plugin!
21-03-25 01:53:23 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
21-03-25 01:53:23 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with CoreDNS plugin!
21-03-25 01:53:23 ERROR (SyncWorker_2) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error for http+docker://localhost/v1.41/containers/create?name=hassio_audio: Bad Request ("create yes/audio: "yes/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")
21-03-25 01:53:23 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin
21-03-25 01:53:23 ERROR (MainThread) [supervisor.misc.tasks] PulseAudio watchdog reanimation failed!
21-03-25 01:53:23 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
21-03-25 01:53:23 ERROR (SyncWorker_3) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error for http+docker://localhost/v1.41/containers/create?name=hassio_dns: Bad Request ("create yes/dns: "yes/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")
21-03-25 01:53:23 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin
21-03-25 01:53:23 ERROR (MainThread) [supervisor.misc.tasks] CoreDNS watchdog reanimation failed!
21-03-25 01:53:53 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with CoreDNS plugin!
21-03-25 01:53:53 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
21-03-25 01:53:53 ERROR (SyncWorker_2) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error for http+docker://localhost/v1.41/containers/create?name=hassio_dns: Bad Request ("create yes/dns: "yes/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")
21-03-25 01:53:53 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin
21-03-25 01:53:53 ERROR (MainThread) [supervisor.misc.tasks] CoreDNS watchdog reanimation failed!
21-03-25 01:54:23 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with PulseAudio plugin!
n大,自动安装老提示这个,不明原因
发表于 2021-3-28 07:55:07 | 显示全部楼层
21-03-27 23:45:11 INFO (MainThread) [supervisor.hassos] No Home Assistant Operating System found21-03-27 23:45:11 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository21-03-27 23:45:11 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository21-03-27 23:47:11 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/home-assistant/addons /data/addons/core  stderr: 'Cloning into '/data/addons/core'...fatal: unable to access 'https://github.com/home-assistant/addons/': Empty reply from server'.21-03-27 23:47:11 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core21-03-27 23:47:11 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / core21-03-27 23:47:11 ERROR (MainThread) [supervisor.store] Can't load data from repository core21-03-27 23:47:11 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/hassio-addons/repository /data/addons/git/a0d7b954  stderr: 'Cloning into '/data/addons/git/a0d7b954'...fatal: unable to access 'https://github.com/hassio-addons/repository/': Empty reply from server'.21-03-27 23:47:11 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / a0d7b95421-03-27 23:47:11 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / a0d7b95421-03-27 23:47:11 ERROR (MainThread) [supervisor.store] Can't load data from repository https://github.com/hassio-addons/repository21-03-27 23:47:11 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove21-03-27 23:47:11 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons21-03-27 23:47:11 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files21-03-27 23:47:11 INFO (MainThread) [supervisor.discovery] Loaded 0 messages21-03-27 23:47:11 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions21-03-27 23:47:11 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP21-03-27 23:47:11 INFO (MainThread) [supervisor.resolution.check] System checks complete21-03-27 23:47:11 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP21-03-27 23:47:11 WARNING (MainThread) [supervisor.resolution.evaluations.base] Detected unsupported OS: Raspbian GNU/Linux 10 (buster) (more-info: https://www.home-assistant.io/more-info/unsupported/os)21-03-27 23:47:11 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete21-03-27 23:47:11 INFO (MainThread) [__main__] Running Supervisor21-03-27 23:47:11 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!
发表于 2021-4-2 14:38:43 | 显示全部楼层
请教个问题,N1刷的openwrt,里面docker安装的hassio。以前没有问题,估计中间升级了,突然上周出现开机一会就登录不是ha和openwrt了,一度怀疑固件问题,反复重刷找问题,最终发现,hassio_audio只要开着一直把内存拉到飙升,最终导致死机,docker里删除了audio就可以了,但是ha里日志一直报错,是这个版本的问题吗,具体怎么解决
21-04-02 06:34:00 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with PulseAudio plugin!
21-04-02 06:34:00 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
21-04-02 06:34:00 ERROR (SyncWorker_4) [supervisor.docker] Image homeassistant/aarch64-hassio-audio not exists for hassio_audio
21-04-02 06:34:00 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin
21-04-02 06:34:00 ERROR (MainThread) [supervisor.misc.tasks] PulseAudio watchdog reanimation failed!
 楼主| 发表于 2021-4-2 15:46:53 | 显示全部楼层
chucheng 发表于 2021-4-2 14:38
请教个问题,N1刷的openwrt,里面docker安装的hassio。以前没有问题,估计中间升级了,突然上周出现开机一 ...
不支持 openwrt
jjcs 手机认证
57
发表于 2021-4-2 20:39:24 | 显示全部楼层
请问出现add-one插件不全如何解决
发表于 2021-4-5 00:36:08 | 显示全部楼层
还是很高深的,看不大懂。。。。。。。。。
发表于 2021-4-6 17:22:18 | 显示全部楼层
[warn] 开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[warn] If you want to abort, hit ctrl+c within 10 seconds...
[warn]
[info] Creating NetworkManager configuration
[warn] Changes are needed to the /etc/network/interfaces file
[info] If you have modified the network on the host manualy, those can now be overwritten
[info] If you do not overwrite this now you need to manually adjust it later
[info] Do you want to proceed with overwriting the /etc/network/interfaces file? [N/y]
[info] Restarting NetworkManager
[info] Wait for networkmanages to start.
[info] Install supervisor Docker container
Error response from daemon: Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io: no such host
Unit hassio-supervisor.service could not be found.
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
########################### Script Version: 2021.02.23.0###########################
Distributor ID:        Debian
Description:        Debian GNU/Linux 9.13 (stretch)
Release:        9.13
Codename:        stretch
Linux version 5.0.2-aml-s905 (root@vbox) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05)) #5.77 SMP PREEMPT Mon Apr 1 17:41:33 MSK 2019
Linux aml 5.0.2-aml-s905 #5.77 SMP PREEMPT Mon Apr 1 17:41:33 MSK 2019 aarch64 GNU/Linux
安装 hassio 失败,请将上方安装信息发送到论坛询问。脚本退出...
 楼主| 发表于 2021-4-6 17:28:44 | 显示全部楼层
[warn]
[warn] If you want more con ...
1. 插网线,不要用wifi
2. 设法升级系统到 debian10
GMT+8, 2025-9-16 02:54 , Processed in 0.878221 second(s), 18 queries , MemCached On.
