楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2021-3-14 21:35:48 | 显示全部楼层
21-03-14 13:17:28 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching t                             o Supervisor homeassistant/aarch64-hassio-supervisor with version 2021.03.4
21-03-14 13:17:28 INFO (MainThread) [supervisor.resolution.evaluate] Starting sy                             stem evaluation with state CoreState.INITIALIZE
21-03-14 13:17:28 INFO (MainThread) [supervisor.resolution.evaluate] System eval                             uation complete
21-03-14 13:17:28 INFO (MainThread) [__main__] Setting up Supervisor
21-03-14 13:17:28 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
21-03-14 13:17:29 INFO (MainThread) [supervisor.hardware.monitor] Started Superv                             isor hardware monitor
21-03-14 13:17:29 ERROR (MainThread) [supervisor.dbus.network] Version '1.10.6'                              of NetworkManager is not supported!
21-03-14 13:26:55 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc s                             upport. OTA updates have been disabled.
21-03-14 13:26:55 INFO (MainThread) [supervisor.host.info] Updating local host i                             nformation
21-03-14 13:26:55 INFO (MainThread) [supervisor.host.services] Updating service                              information
21-03-14 13:26:55 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio                              information
21-03-14 13:26:55 INFO (MainThread) [supervisor.host] Host information reload co                             mpleted
大佬这是咋回事啊?
发表于 2021-3-14 21:36:55 | 显示全部楼层
N1
系统信息如下:
Welcome to ARMBIAN 5.77 user-built Ubuntu 18.04.5 LTS 5.0.2-aml-s905
System load:   1.12 0.32 0.11   Up time:       0 min
Memory usage:  20 % of 1838MB   IP:            192.168.123.49
CPU temp:      56°C
Usage of /:    4% of 114G
 楼主| 发表于 2021-3-15 07:15:24 | 显示全部楼层
smldm 发表于 2021-3-14 21:36
N1
系统信息如下:
ubunut 只支持 20.04了
发表于 2021-3-17 17:31:04 | 显示全部楼层
没有用WIFI,我的树莓派都是插着网线的
发表于 2021-3-19 22:36:13 | 显示全部楼层
neroxps 发表于 2021-3-15 07:15
ubunut 只支持 20.04了
虽然提示错误,但是网页能进hass,hass log里好像有提示错误。
大佬,我得把N1 刷成ubunut 20.04 对应的armbian版本吗?
 楼主| 发表于 2021-3-20 13:03:03 | 显示全部楼层
大佬,我得把N1 刷成ubunut 20.04 对应的a ...
armbian 10 也行(也就是 debian10)
发表于 2021-3-21 01:09:16 | 显示全部楼层
[info] 跳过切换系统源。
[info] 更新系统至最新.....
[info] 安装 hassio 必要依赖.....
Ign:1 https://mirrors.tuna.tsinghua.edu.cn/debian stretch InRelease
Hit:2 https://mirrors.tuna.tsinghua.edu.cn/debian stretch-updates InRelease
Hit:3 https://mirrors.tuna.tsinghua.edu.cn/debian stretch-backports InRelease
Hit:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security stretch/updates InRelease
Hit:5 http://packages.openmediavault.org/public usul InRelease
Hit:7 https://mirrors.tuna.tsinghua.edu.cn/debian stretch Release
Hit:6 https://mirrors.tuna.tsinghua.edu.cn/armbian buster InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
curl is already the newest version (7.64.0-4+deb10u1).
jq is already the newest version (1.5+dfsg-2+b1).
net-tools is already the newest version (1.60+git20180626.aebd88e-1).
network-manager is already the newest version (1.14.6-2+deb10u1).
qrencode is already the newest version (4.0.2-1).
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
apparmor : Depends: libapparmor-perl but it is not going to be installed
apparmor-utils : Depends: libapparmor-perl but it is not going to be installed
                  Depends: python3-apparmor (= 2.11.0-3+deb9u2) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
大佬,N1更换了debian10 的版本后,脚本跑不通了......
发表于 2021-3-21 15:50:13 | 显示全部楼层
你好,安装时报这样的错,没得插件仓库,该怎么破,谢谢!!!
21-03-21 03:19:52 ERROR (MainThread) [supervisor.store] Can't load data from repository core
21-03-21 03:19:54 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
  stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': OpenSSL SSL_connect: Connection reset by peer in connection to github.com:443
 楼主| 发表于 2021-3-21 15:54:09 | 显示全部楼层
21-03-21 03:19:52 ERROR (MainThread) [su ...
买张飞机票~带上机器,飞到国外,找家机场附近的网吧,装好一切,再飞回来~
参考古巴人民的办法http://roll.sohu.com/20150928/n422268465.shtml
发表于 2021-3-21 16:59:18 | 显示全部楼层
参考古巴人民的办法http://r ...
哈哈哈,已搭了梯子,还要买机票吗?
GMT+8, 2025-9-16 02:54 , Processed in 0.993898 second(s), 11 queries , MemCached On.
