楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2018-9-23 12:07:51 | 显示全部楼层
聚聚,树莓派3B+出现这个错误
装之前已经update upgrade过了
   Active: activating (auto-restart) (Result: exit-code) since Sun 2018-09-23 12:04:32 CST; 64ms ago
     Docs: [url]https://docs.docker.com[/url]
  Process: 31888 ExecStart=/usr/bin/dockerd -H fd:// (code=exited, status=1/FAILURE)
 Main PID: 31888 (code=exited, status=1/FAILURE)
      CPU: 1.065s
Sep 23 12:04:32 raspberrypi systemd[1]: docker.s…e.
Sep 23 12:04:32 raspberrypi systemd[1]: docker.s…'.
Hint: Some lines were ellipsized, use -l to show in full.
dpkg: error processing package docker-ce (--configure):
 subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
 docker-ce
E: Sub-process /usr/bin/dpkg returned an error code (1)
发表于 2018-9-24 12:26:14 | 显示全部楼层
hassio.io无法连接源
发表于 2018-9-30 20:41:06 | 显示全部楼层
谢谢楼主分享!
发表于 2018-10-3 19:57:08 | 显示全部楼层
收藏收藏收藏
发表于 2018-10-8 15:37:22 | 显示全部楼层
[info]: 安装 Docker 引擎.....
# Executing docker install script, commit: 36b78b2
+ sh -c apt-get update -qq >/dev/null
+ sh -c apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
+ sh -c curl -fsSL "https://download.docker.com/linux/raspbian/gpg" | apt-key add -qq - >/dev/null
Warning: apt-key output should not be parsed (stdout is not a terminal)
+ sh -c echo "deb [arch=armhf] https://download.docker.com/linux/raspbian stretch edge" > /etc/apt/sources.list.d/docker.list
+ [ raspbian = debian ]
+ sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
[ERROR]: Docker 安装失败,请检查上方安装错误信息。
pi3 出的报错
 楼主| 发表于 2018-10-8 22:01:47 | 显示全部楼层
ptkid 发表于 2018-10-8 15:37
: 安装 Docker 引擎.....
+ sh -c apt-get update -q ...
因我没有树莓派,没法拍错,自行安装 docker 后运行脚本吧。
发表于 2018-10-9 09:04:13 | 显示全部楼层
重启一下,再安装好了,谢谢大佬的一键包
发表于 2018-10-10 00:04:38 | 显示全部楼层
厉害
发表于 2018-10-10 10:49:19 | 显示全部楼层
谢谢楼主分享
发表于 2018-10-12 12:02:55 | 显示全部楼层
谢谢版主啊,就是问下,要是有更新,是直接点更新还是怎么弄?
GMT+8, 2025-9-19 05:31 , Processed in 1.345080 second(s), 11 queries , MemCached On.
