查看: 46189|回复: 26
[基础教程] Ubuntu + Docker + HASSIO安装教程(更新18.04.4)
发表于 2018-8-3 21:43:06 | 显示全部楼层 |阅读模式
20200223更新:
最近安装了Ubuntu 18.04.4,教程与原来没多大区别,主要是源地址变了,最后安装时也有点变动,其他与原教程一致。
#必选项!更换国内源(这次是163的)!如果不更换,sudo apt-get update会非常慢
#首先是备份原源地址,然后将虚线间的代码加入sources.list,contrl + x, y 退出
sudo mv /etc/apt/sources.list /etc/apt/sources.list.bak
sudo nano /etc/apt/sources.list
deb http://mirrors.163.com/ubuntu/ bionic main restricted universe multiverse
deb http://mirrors.163.com/ubuntu/ bionic-security main restricted universe multiverse
deb http://mirrors.163.com/ubuntu/ bionic-updates main restricted universe multiverse
deb http://mirrors.163.com/ubuntu/ bionic-proposed main restricted universe multiverse
deb http://mirrors.163.com/ubuntu/ bionic-backports main restricted universe multiverse
#安装hass.io
sudo apt-get install -y apparmor-utils apt-transport-https avahi-daemon jq socat network-manager
sudo systemctl disable ModemManager
sudo apt-get purge modemmanager
curl -sL "https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh" | sudo bash -s
========================以下是原教程========================
无坑系列教程再度走起!
看教程前,默认你已经通过虚拟机或是实体安装了Ubuntu 17.10 server版。
#首先改一下sudoer设置,省得sudo时总要求输密码
sudo nano /etc/sudoers
#在最下面(看好,是此文件的最下方,否则会被下面的设置所覆盖而无效!)添加以下内容(jones改为你的用户名):
jones ALL=NOPASSWD: ALL
#可选项,如果在安装ubuntu时没有更改时区的,使用下面的代码更改时区
sudo dpkg-reconfigure tzdata
deb http://mirrors.163.com/ubuntu/ artful main restricted universe multiverse
deb http://mirrors.163.com/ubuntu/ artful-security main restricted universe multiverse
deb http://mirrors.163.com/ubuntu/ artful-updates main restricted universe multiverse
deb http://mirrors.163.com/ubuntu/ artful-proposed main restricted universe multiverse
deb http://mirrors.163.com/ubuntu/ artful-backports main restricted universe multiverse
#更新源信息,安装更新
sudo apt-get update && sudo apt-get upgrade -y
#做一些清理工作
sudo apt-get autoclean
sudo apt-get clean
####安装docker-ce####
#首先添加gpg密钥
curl -fsSL https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu/gpg | sudo apt-key add -
#添加软件源,运行第一行命令,将第二行添加到文件末尾,ctrl + x,y保存退出
sudo nano /etc/apt/sources.list.d/docker.list
deb [arch=amd64] https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu artful edge
#正式安装docker-ce
sudo apt-get update
sudo apt-get install docker-ce
#将当前用户加入docker用户组,避免使用root用户运行
sudo usermod -aG docker $USER
#注册并应用加速器https://cr.console.aliyun.com/#/accelerator
#加速器添加方法一,记得把xxxxx那些替换为你自己注册得到的加速器地址
sudo nano /etc/systemd/system/multi-user.target.wants/docker.service
#找到以下行,把加速器地址粘在后面
ExecStart=/usr/bin/dockerd --registry-mirror=https://xxxxxxxxx.mirror.aliyuncs.com
#加速器添加方法二
sudo mkdir -p /etc/docker
sudo tee /etc/docker/daemon.json <<-'EOF'
  "registry-mirrors": ["https://xxxxxxxxx.mirror.aliyuncs.com"]
EOF
#重载systemctl,重启docker
sudo systemctl daemon-reload
sudo systemctl restart docker
sudo systemctl enable docker
#重启系统
sudo reboot
#安装hass.io,安装需要一些时间,等大概10几分钟后,尝试打开ip:8123,如果出现HASS界面,表示安装成功。
sudo apt-get install -y socat jq avahi-daemon
curl -sL https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install | sudo bash -
参与人数 1金钱 +20 收起 理由
Mirukuteii + 20 百忙之中还写这么给力的教程,必须支持.
发表于 2018-8-3 21:49:33 | 显示全部楼层
来个一键脚本得了。
 楼主| 发表于 2018-8-3 21:55:17 | 显示全部楼层
neroxps 发表于 2018-8-3 21:49
来个一键脚本得了。
支持,来吧!
发表于 2018-8-3 22:57:10 | 显示全部楼层
来个一键脚本得了。
大神可以搞个哈
流水无味
灌水之王
发表于 2018-8-4 08:34:46 | 显示全部楼层
定,这个要站位支持
发表于 2018-8-4 08:49:28 | 显示全部楼层
sudo apt-get install -y socat jq avahi-daemon,,,这条命令里的-y是什么意思?
 楼主| 发表于 2018-8-4 09:15:49 | 显示全部楼层
帮你按y的意思。
流水无味
灌水之王
发表于 2018-8-4 09:31:46 | 显示全部楼层
Last login: Sat Aug  4 09:28:49 2018 from 192.168.1.8
xieahui@ubuntu:~$ sudo apt-get install -y socat jq avahi-daemon
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
jq 已经是最新版 (1.5+dfsg-2)。
socat 已经是最新版 (1.7.3.2-1)。
avahi-daemon 已经是最新版 (0.6.32-1ubuntu1.1)。
升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 72 个软件包未被升级。
xieahui@ubuntu:~$ curl -sL [url=https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install]https://raw.githubusercontent.co ... tall/hassio_install[/url] | sudo bash -
[Warning] No NetworkManager support on Host.
[Info] Install supervisor docker
囤帅 有坑啊!!
重启+重试最后的命令N次后 可以进xxx:8123了
发表于 2018-8-4 14:55:20 | 显示全部楼层
前两天刚找着来了一遍,要是早点发就不费劲了,支持囧帅~收藏了先/
 楼主| 发表于 2018-8-4 18:46:45 | 显示全部楼层
xieahui 发表于 2018-8-4 09:31
[code]Last login: Sat Aug  4 09:28:49 2018 from 192.168.1.8
xieahui@ubuntu:~ ...
你网络的问题吧。。。
GMT+8, 2025-9-15 03:20 , Processed in 0.674837 second(s), 6 queries , MemCached On.
