楼主: neroxps
【hassio 降级升级】 homeassistant 版本切换
发表于 2019-2-14 13:00:32 | 显示全部楼层
neroxps 发表于 2019-2-14 09:08
可以的,不行的话跟我操作
[md]
大神,这是反馈的信息,ha能显示输入账号密码的界面,但是输了密码一直正在用 Home Assistant Local 登录。
19-02-14 04:37:48 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.79.0
19-02-14 04:37:48 INFO (SyncWorker_19) [hassio.docker.interface] Update Docker homeassistant/raspberrypi3-homeassistant:0.87.1 to homeassistant/raspberrypi3-homeassistant:0.79.0
19-02-14 04:37:48 INFO (SyncWorker_19) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.79.0.
19-02-14 04:46:38 INFO (SyncWorker_19) [hassio.docker.interface] Tag image homeassistant/raspberrypi3-homeassistant with version 0.79.0 as latest
19-02-14 04:46:38 INFO (SyncWorker_19) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
19-02-14 04:46:53 INFO (SyncWorker_19) [hassio.docker.interface] Clean homeassis tant/raspberrypi3-homeassistant Docker application
19-02-14 04:46:54 INFO (SyncWorker_19) [hassio.docker.interface] Cleanup Dockerimages: ['homeassistant/raspberrypi3-homeassistant:0.87.1']
19-02-14 04:47:15 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.79.0
19-02-14 04:47:45 INFO (MainThread) [hassio.homeassistant] Detect a running HomeAssistant instance
19-02-14 04:47:45 INFO (MainThread) [hassio.homeassistant] Successful run Home A ssistant 0.79.0
19-02-14 04:51:09 ERROR (MainThread) [hassio.homeassistant] Can't update Home Assistant access token!
19-02-14 04:51:09 WARNING (MainThread) [hassio.tasks] Watchdog miss API response  from Home Assistant
19-02-14 04:56:09 ERROR (MainThread) [hassio.homeassistant] Can't update Home Assistant access token!
19-02-14 04:56:09 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant API!
 楼主| 发表于 2019-2-14 15:03:16 | 显示全部楼层
chenlang2361239 发表于 2019-2-14 13:00
大神,这是反馈的信息,ha能显示输入账号密码的界面,但是输了密码一直正在用 Home Assistant Local 登录 ...
这里已经显示降级开始了啊
不过hassio 版本没法降级,hassio 版本要和homeassistant版本匹配使用。否则hassio会有问题。
发表于 2019-2-14 15:07:37 | 显示全部楼层
neroxps 发表于 2019-2-14 15:03
Update Docker homeassistant/raspberrypi3-homeassistant:0.87.1 to homeassistant/raspberrypi3-homeas ...
好吧,大神有啥办法吗?我折腾几天了,一直搞不出来
 楼主| 发表于 2019-2-14 15:20:31 | 显示全部楼层
没~
发表于 2019-2-20 15:38:11 | 显示全部楼层
大神  HASSIO 安装一键脚本 安装的时候能选择版本就好了
 楼主| 发表于 2019-2-20 15:45:40 | 显示全部楼层
不行,会有问题。
因为homeassistant版本有时候需要和hassio 版本配合,而hassio 的更新是没法阻止,hassio自动运作,如果用旧版的homeassistant和新版的hassio,就会出现问题。
我的建议还是直接使用新版homeassistant~
我现在每次更新都立即更新,很少崩,不过88估计又要崩一大批
发表于 2019-2-25 01:55:33 来自手机 | 显示全部楼层
mark,谢谢了
发表于 2019-4-28 08:50:06 | 显示全部楼层
点了执行没反应,也没有日志
发表于 2019-5-1 03:22:35 | 显示全部楼层
liuxinsc 发表于 2019-4-28 08:50
点了执行没反应,也没有日志
一样不可以降级
 楼主| 发表于 2019-7-1 09:08:20 | 显示全部楼层
点了执行没反应,也没有日志
请看 /config/home-assistant.log
或者安装 https://github.com/hassio-addons/addon-log-viewer 这个插件来看日志,谢谢~
GMT+8, 2025-9-14 03:05 , Processed in 0.937071 second(s), 12 queries , MemCached On.
