楼主: neroxps
【hassio 降级升级】 homeassistant 版本切换
发表于 2018-12-15 14:01:49 | 显示全部楼层
好像用不了,报下面的错误, 是RASPBERRY+DOCKER+HASSIO, 现在是0.84.1, 想降回去, 好多都报错了, 没法用了
2018-12-15 13:51:50 INFO (MainThread) [homeassistant.helpers.script] Script ha_version_change: Running script
2018-12-15 13:51:50 INFO (MainThread) [homeassistant.helpers.script] Script ha_version_change: Executing step call service
2018-12-15 13:51:50 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall script.ha_version_change (c:a3a3740442304916aa0d321140af92d4)>
  File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1130, in _safe_execute
    await self._execute_service(handler, service_call)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1143, in _execute_service
    await handler.func(service_call)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/script.py", line 123, in service_handler
    context=service.context)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/script.py", line 181, in async_turn_on
    kwargs.get(ATTR_VARIABLES), context)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 130, in async_run
    await self._handle_action(action, variables, context)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 172, in _handle_action
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 261, in _async_call_service
    context=context
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 81, in async_call_from_config
    domain, service_name, service_data, blocking=blocking, context=context)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1121, in async_call
    self._execute_service(handler, service_call))
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/shell_command.py", line 86, in async_service_handler
    process = await create_process
  File "/usr/local/lib/python3.6/asyncio/subprocess.py", line 225, in create_subprocess_exec
    stderr=stderr, **kwds)
  File "uvloop/loop.pyx", line 2601, in subprocess_exec
  File "uvloop/loop.pyx", line 2561, in __subprocess_run
  File "uvloop/handles/process.pyx", line 588, in uvloop.loop.UVProcessTransport.new
  File "uvloop/handles/process.pyx", line 95, in uvloop.loop.UVProcess._init
PermissionError: [Errno 13] Permission denied
发表于 2018-12-20 10:03:06 | 显示全部楼层
我来瀚思就为看你!
 楼主| 发表于 2018-12-20 10:16:24 | 显示全部楼层
没权限~
发表于 2018-12-25 13:57:28 | 显示全部楼层
那要怎么修改?
卓越贡献
发表于 2019-1-3 09:17:38 | 显示全部楼层
19-01-03 01:05:18 ERROR (MainThread) [hassio.homeassistant] Can't update Home Assistant access token!
19-01-03 01:05:18 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home Assistant
19-01-03 01:09:59 INFO (MainThread) [hassio.addons.addon] Create Home Assistant add-on data folder /data/addons/data/a0d7b954_logviewer
19-01-03 01:09:59 INFO (SyncWorker_13) [hassio.docker.interface] Pull image hassioaddons/log-viewer tag 0.3.0.
19-01-03 01:10:18 ERROR (MainThread) [hassio.homeassistant] Can't update Home Assistant access token!
19-01-03 01:10:18 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant API!
19-01-03 01:10:18 INFO (SyncWorker_9) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
19-01-03 01:10:19 ERROR (MainThread) [hassio.utils] Can't execute install while a task is in progress
19-01-03 01:10:37 INFO (SyncWorker_9) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
19-01-03 01:10:40 INFO (SyncWorker_3) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.71.0
19-01-03 01:10:43 INFO (SyncWorker_13) [hassio.docker.interface] Tag image hassioaddons/log-viewer with version 0.3.0 as latest
19-01-03 01:11:31 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
最新版退回0.71.0每隔10分钟就会自动重启,怎么解决?
 楼主| 发表于 2019-1-3 09:28:32 | 显示全部楼层
step0766 发表于 2019-1-3 09:17
19-01-03 01:05:18 ERROR (MainThread) [hassio.homeassistant] Can't update Home Assistant access token ...
无法解决,hassio 是配合ha版本使用的,而hassio无法控制其不升级。所以无法解决。除非自己fork一个hassio,改掉版本信息json。
卓越贡献
发表于 2019-1-3 09:40:39 | 显示全部楼层
neroxps 发表于 2019-1-3 09:28
无法解决,hassio 是配合ha版本使用的,而hassio无法控制其不升级。所以无法解决。除非自己fork一个hassi ...
所以降级是无法完美实现的吗?
 楼主| 发表于 2019-1-3 12:17:31 | 显示全部楼层
step0766 发表于 2019-1-3 09:40
所以降级是无法完美实现的吗?
只能改hassio 的代码,然后自己编译hassio镜像,配合 homeassistant 71版本自己用自己的。
发表于 2019-2-14 08:55:58 | 显示全部楼层
大神,这个脚本针对树莓派+docker+hassio可以降级吗,我试了一下,好像不行,望大神指点一下哈,ha版本更新每次都有不能用的配置
 楼主| 发表于 2019-2-14 09:08:52 | 显示全部楼层
chenlang2361239 发表于 2019-2-14 08:55
大神,这个脚本针对树莓派+docker+hassio可以降级吗,我试了一下,好像不行,望大神指点一下哈,ha版本更新 ...
可以的,不行的话跟我操作
docker exec -it homeassistant bash
/config/packages/ha_ver_change/ha_ver_change.sh 0.87.0
看看有什么回显,另可以
docker logs -f hassio_supervisor
输出 hassio 的日志看看有什么错误提示
GMT+8, 2025-9-14 03:04 , Processed in 0.569988 second(s), 8 queries , MemCached On.
