查看: 4975|回复: 4
人体红外传感器
发表于 2018-6-7 21:53:36 | 显示全部楼层 |阅读模式
import json
from urllib import request, parse
import logging
from datetime import timedelta
import voluptuous as vol
import threading
import RPi.GPIO as GPIO
import time
import datetime
import random
from homeassistant.components.sensor import PLATFORM_SCHEMA
from homeassistant.const import (
    ATTR_ATTRIBUTION, ATTR_FRIENDLY_NAME, TEMP_CELSIUS)
from homeassistant.helpers.entity import Entity
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.event import track_time_interval
import homeassistant.util.dt as dt_util
# 配置文件中三个配置项的名称
CONF_GPIOPINS  = "gpiopins"
CONF_INTERVAL  = "interval"
_LOGGER = logging.getLogger(__name__)
TIME_BETWEEN_UPDATES = timedelta(seconds=3)
ATTR_UPDATE_TIME = "更新时间"
ATTRIBUTION      = "来自FOX007数据"
_GPIOPINS = [16,12,1,7,8,18]
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
    vol.Required(CONF_INTERVAL): cv.string,
    # 配置项的options是一个列表,列表内容只能是OPTIONS中定义的三个可选项
    vol.Optional(CONF_GPIOPINS, default=[]):
        vol.All(cv.ensure_list, [vol.In(_GPIOPINS)]), #需要判断 读出来的数据是否在 已知数组 _GPIOPINS 里面,可以不判断
def setup_platform(hass, config, add_devices, discovery_info=None):
    """根据配置文件,setup_platform函数会自动被系统调用."""
    interval = config.get(CONF_INTERVAL)
    # 根据配置文件options中的内容,添加若干个设备
    dev = []
    for gpiopin in config[CONF_GPIOPINS]:
        # 定义一个新的数据对象,
        data = Infrared(hass,gpiopin)
        dev.append(InfraredSensor(data, gpiopin))
    add_devices(dev, True)
class InfraredSensor(Entity):
    """定义一个温度传感器的类,继承自HomeAssistant的Entity类."""
    def __init__(self, data, pin):
        """初始化."""
        self._data   = data
        self._ledpin = pin
        #定义图标
        self._object_id           = format("infrared_%d" % pin)   #唯一ID
        self._friendly_name       = "人体红外"          #名称
        self._icon                = "mdi:walk"       #图标
        self._unit_of_measurement = ""          #显示的:单位
        self._state = None
        self._updatetime = None
        self._updatecount = 0
    @property
    def name(self):
        """返回实体的名字."""
        return self._object_id
    @property
    def registry_name(self):
        """返回实体的friendly_name属性."""
        return self._friendly_name
    @property
    def state(self):
        """返回当前的状态."""
        return self._state
    @property
    def icon(self):
        """返回icon属性."""
        return self._icon
    @property
    def unit_of_measurement(self):
        """返回unit_of_measuremeng属性."""
        return self._unit_of_measurement
    @property
    def device_state_attributes(self):
        """设置其它一些属性值."""
        if self._state is not None:
            return {
                ATTR_ATTRIBUTION: ATTRIBUTION,
                ATTR_UPDATE_TIME: self._updatetime
    def update(self):
        """更新函数,在sensor组件下系统会定时自动调用(时间间隔在配置文件中可以调整,缺省为30秒)."""
        self._updatetime = 0
        self._updatecount+=1
        self._state      = self._updatecount
#定义人体红外
class Infrared(object):
    def __init__(self,hass,gpiopin):
        self._gpiopin     = gpiopin
        self._led         = 1
        GPIO.setmode(GPIO.BCM)
        GPIO.setup(self._gpiopin, GPIO.IN)
        GPIO.setup(self._led,GPIO.OUT)
        GPIO.output(self._led,GPIO.HIGH)
        GPIO.add_event_detect(self._gpiopin, GPIO.BOTH, callback=self.callback,bouncetime=200)
    def callback(channel):
        if GPIO.input(channel):
            print("Rising edge detected on %s"%channel)
            #调用服务
            #entity_id = 'light.gateway_light_7811dce1e849'
            #rgb_color = [255, 0, 0]
            #service_data = {'entity_id': entity_id, 'rgb_color': rgb_color, 'brightness': 255 }
            #hass.services.call('light', 'turn_on', service_data, False)
        else:
            GPIO.output(self._led,GPIO.LOW)
            print("Falling edge detected on %s"%channel)
问题来了
   怎么样才能做到,传感器发送上升沿或下降沿时,触发HA,
发表于 2018-6-7 22:44:15 | 显示全部楼层
你这贴们,太像灌水了!能不能像个样子的发呀
发表于 2018-6-7 23:23:12 | 显示全部楼层
没看明白最后的问题,代码里面不已经是GPIO.BOTH,双边沿触发了么,想干啥直接写呗
发表于 2018-6-10 14:25:29 | 显示全部楼层
云里雾里……
发表于 2018-9-9 22:25:26 | 显示全部楼层
能发一下配置文件里的配置吗?兄弟
GMT+8, 2025-7-9 13:25 , Processed in 0.633292 second(s), 13 queries , MemCached On.
