楼主: East
Ai Light RGB灯完美接入HA和HomeKit
East
 楼主| 发表于 2018-6-21 22:46:58 | 显示全部楼层
wanyakui520 发表于 2018-6-20 15:33
灯泡买回来我发现灯罩安装方式不一样了,完全拆不下来。。。
卡进去的慢慢敲..
发表于 2018-7-26 21:26:14 | 显示全部楼层
这个可以有啊!!
发表于 2018-8-12 20:50:53 | 显示全部楼层
East 发表于 2018-6-21 22:46
卡进去的慢慢敲..
请教楼主刷固件已刷好
00:00:00 Project sonoff Sonoff (Topic sonoff, Fallback DVES_79818A, GroupTopic sonoffs) Version 5.13.1-2_4_0
00:00:00 WIF: Connecting to AP1  in mode 11N as sonoff-0394...
00:00:20 WIF: Connect failed with AP timeout
00:00:20 WIF: Connecting to AP1  in mode 11N as sonoff-0394...
00:00:40 WIF: Connect failed with AP timeout
00:00:40 WIF: WPSConfig active for 3 minutes
发表于 2018-8-12 21:14:52 | 显示全部楼层
用wps模式连入wifi 请教楼主 多个LED 如何搞定?
wktm
发表于 2018-8-17 00:00:21 来自手机 | 显示全部楼层
好有心很耐心,学习了
发表于 2018-8-18 20:59:16 | 显示全部楼层
请教多个AI light 如何 配置
- platform: mqtt
    retain: true
    state_topic: "stat/led/POWER"
    command_topic: "cmnd/led/POWER"
    availability_topic: "tele/led/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
    optimistic: false
    brightness_state_topic: "stat/led/Dimmer"
    brightness_command_topic: "cmnd/led/Dimmer"
    brightness_value_template: "{{ value_json.Dimmer }}"
    brightness_scale: 100
    rgb_state_topic: "stat/led/Color"
    rgb_command_topic: "cmnd/led/Color2"
    rgb_command_mode: hex
    rgb_command_template: "{{ '%02x%02x%02x' | format(red, green, blue)}}"
    effect_state_topic: "stat/led/Scheme"
    effect_command_topic: "cmnd/led/Scheme"
    effect_value_template: "{{ value_json.Scheme }}"
    effect_list:
          - 0
          - 1
          - 2
          - 3
          - 4
          - 5
          - 6
          - 7
          - 8
          - 9
          - 10
          - 11
          - 12
发表于 2018-8-18 21:10:10 | 显示全部楼层
个人觉得应该再复制一个你的配置,改名,改这些state_topic: "stat/led/POWER", command_topic: "cmnd/led/POWER", availability_topic: "tele/led/LWT" 等等
发表于 2018-8-18 21:12:26 | 显示全部楼层
swau221 发表于 2018-8-18 21:10
个人觉得应该再复制一个你的配置,改名,改这些state_topic: "stat/led/POWER", command_topic: "cmnd/led ...
你觉得三个灯用一样的配置 他们会一起受控制吗?
发表于 2018-8-18 22:31:36 | 显示全部楼层
neroxps 发表于 2018-5-21 09:00
50一个,我大厅的吊灯12个灯,600块。没钱。。。。
有买吗 现在 25一个吧 买了四个 我一直搞不定控制多个AI light
发表于 2018-8-18 22:37:57 | 显示全部楼层
没买,穷,没钱装修
GMT+8, 2025-9-11 03:18 , Processed in 0.154803 second(s), 7 queries , MemCached On.
