楼主: Yonsm
[插件集成] ZhiModBus -通用 ModBus 空调组件(及中央空调接入方案简述)
发表于 2021-1-24 16:15:43 来自手机 | 显示全部楼层
大佬…我根据你的思路买来485转WiFi控制器…但是ip地址设置好信号灯一直不亮…电源也不知道要不要接两个…感觉好像哪里都不对…请您帮我看一下…谢谢
发表于 2021-1-27 08:36:37 来自手机 | 显示全部楼层
大佬我是日立的中央空调…界面已经能跳出空调调试界面…RS485转WiFi的转换器设置了ip和波特率…其他还要设置什么工作?是不是还有什么信号代码需要自己设置?
 楼主| 发表于 2021-3-4 22:20:46 | 显示全部楼层
老帖翻新,更新了代码和文档
发表于 2021-3-15 22:27:46 | 显示全部楼层
ccm15貌似可以接入了,才100+
发表于 2021-3-19 16:30:30 | 显示全部楼层
chenggangyaan 发表于 2021-3-15 22:27
ccm15貌似可以接入了,才100+
我试过,可以接入,但我的是海信空调,控制不了。
发表于 2021-4-21 09:49:00 | 显示全部楼层
楼主有协议doc吗 有的话发一份 谢谢
发表于 2021-5-29 21:41:02 | 显示全部楼层
报错详情:
Logger: homeassistant.components.websocket_api.http.connection
Source: custom_components/zhimodbus/climate.py:428
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 下午8:33:31 (1 occurrences)
Last logged: 下午8:33:31
[140609311453776] 'ZhiModbusClimate' object has no attribute '_fan_modes'
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 136, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1455, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1490, in _execute_service
    await handler.job.target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
    await self.hass.helpers.service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 595, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 664, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 632, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 422, in async_set_fan_mode
    await self.hass.async_add_executor_job(self.set_fan_mode, fan_mode)
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/config/custom_components/zhimodbus/climate.py", line 428, in set_fan_mode
    self.set_mode(self._fan_modes, REG_FAN_MODE, fan_mode)
AttributeError: 'ZhiModbusClimate' object has no attribute '_fan_modes'
下面是我的配置信息:
climate:
    - platform: zhimodbus
      name: [影音厅, 负一楼, 三楼书房]
      #风速设定:1低速,2中速,3高速,4自动
      fan_modes: { 自动: 4, 一档: 1, 二档: 2, 三档: 3 }
      #模式设定:1制热,3制冷,9通风
      hvac_modes: { 'off': 0, cool: 3, heat: 1, fan_only: 9 }
      #设定温度
      target_temperature: { registers: [1, 601, 901], register_type: holding, scale: 0.1 }
      #室内当前温度
      temperature: { registers: [0, 600, 900], register_type: holding, scale: 0.1 }
      #风速设定
      fan_mode: { registers: [5, 605, 905], register_type: holding }
      #模式设定
      hvac_mode: { registers: [3, 603, 903], register_type: holding }
      #开关控制
      hvac_off: { registers: [2, 602, 902], register_type: holding }
发表于 2021-9-11 14:05:51 来自手机 | 显示全部楼层
找到IP地址了,可是端口号怎么看啊,求告知
发表于 2021-10-24 11:39:40 | 显示全部楼层
我也是海信空调一拖一风管机
HUR-75KFWH/R2FZBp/Pd
用楼主的方法可以吗?还是说其它方案?
发表于 2021-10-26 21:19:32 | 显示全部楼层
maoziping 发表于 2018-10-28 13:09
跟着大神购入了一样的设备,目前卡在有人的设置,用modbuspoll调试一直都提示Insufficient bytes received ...
老哥,你也是约克多管机吗?
GMT+8, 2025-9-14 03:00 , Processed in 0.694382 second(s), 13 queries , MemCached On.
