查看: 8021|回复: 5
小米窗帘在homekit中找不到,望高人指点下
发表于 2018-4-22 22:07:48 | 显示全部楼层 |阅读模式
用的是hass.io,可以正常识别和控制小米智能窗帘电机。但是在手机家庭APP里面,却始终找不到设备,在home bridge插件的log栏,查到如下信息:'cover.curtain_158d0001ef4ad1' is a cover but does not have a 'homebridge_cover_type' property set. You must set it to either 'rollershutter' or 'garage_door' in the customize section of your Home Assistant configuration. It will not be available to Homebridge until you do. See the README.md for more information. The attributes that were found are: {"battery_level":100,"current_position":100,"friendly_name":"阳台窗帘","icon":"mdi: view-array","supported_features":15
config.json里面是有cover类型的,苹果家庭APP也是支持窗帘的,为什么Hass能添加的窗帘,在家庭app里面就找不到设备呢。
发表于 2018-4-26 18:15:03 | 显示全部楼层
你的无线开关···HomeKit·直接能识别?
 楼主| 发表于 2018-4-27 14:03:42 来自手机 | 显示全部楼层
用不了,我打算给隐藏掉
发表于 2018-8-19 12:40:58 | 显示全部楼层
同求啊,网上有siri控制小米窗帘的视频,大神请指点1.2
 楼主| 发表于 2018-8-20 13:40:51 | 显示全部楼层
cover.curtain_158d0001ef4ad1:
  homebridge_cover_type: rollershutter
  friendly_name: 阳台窗帘
我搞定了,参考我上面的,在customize.yaml中添加。我也不大清楚,为什么cover类型就不行,非得指定为rollershutter类型。反正这么搞homekit就可以识别小米的窗帘了,不过家庭APP里显示的中文是:卷帘门
发表于 2018-10-6 16:20:23 | 显示全部楼层
  friendly_name: 阳台窗帘
感謝大神分享!
GMT+8, 2025-9-11 03:58 , Processed in 0.097974 second(s), 14 queries , MemCached On.
