查看: 539|回复: 5
[技术探讨] xiaomi home中 小爱音响的文本与播放输入怎么没了
发表于 2026-9-14 20:26:00 | 显示全部楼层 |阅读模式
xiaomi home中 小爱音响的文本与播放输入怎么没了,我记得以前是有的呀
Xiaomi Home[color=var(--secondary-text-color)]版本 v0.4.7  [color=var(--secondary-text-color)]
实体变成了notify类型
实体变为notify
实体变为notify
发表于 2026-9-14 22:14:14 | 显示全部楼层
Xiaomi Miot的有
发表于 2026-9-15 07:11:22 | 显示全部楼层
选“发送通知消息“
然后选择“小爱音箱”,
然后输入文本内容
发表于 2026-9-15 08:36:13 | 显示全部楼层
1、执行指令
action: notify.send_message
metadata: {}
data:
  message: '[''息屏'', true]'
target:
  entity_id: notify.xiaomi_cn_842238162_x4b_execute_text_directive_a_5_4
message: '[''息屏'', true]' 第二个参数true表示静默执行,不语音回复
2、播放文本
metadata: {}
data:
  message: '[''厨房检测到天然气泄露'']'
target:
  entity_id: notify.xiaomi_cn_842238162_x4b_play_text_a_5_3
 楼主| 发表于 2026-9-15 14:10:13 | 显示全部楼层
        "id": "0eac94e504a417e3",
        "type": "tab",
        "label": "流程 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "001eae50dee9741a",
        "type": "inject",
        "z": "0eac94e504a417e3",
        "name": "播报天气很好",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 370,
        "y": 620,
        "wires": [
                "a6bcae5c32e889af"
        "id": "a6bcae5c32e889af",
        "type": "api-call-service",
        "name": "音响增强 播报文本",
        "server": "84b5ec8e1a4c321b",
        "version": 7,
        "debugenabled": false,
        "action": "notify.send_message",
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "notify.xiaomi_cn_586204887_l05c_play_text_a_5_3"
        "labelId": [],
        "data": "{\"message\":\"天气很好\"}",
        "dataType": "json",
        "mergeContext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "blockInputOverrides": false,
        "domain": "notify",
        "service": "send_message",
        "mergecontext": "",
        "x": 630,
        "y": 620,
        "wires": [
        "id": "e94dacf6ec3dcbbf",
        "type": "inject",
        "name": "播报动态消息",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "很好",
        "payloadType": "str",
        "x": 370,
        "y": 480,
        "wires": [
                "38e58a1ed2bbd2aa"
        "id": "38e58a1ed2bbd2aa",
        "version": 7,
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "labelId": [],
        "data": "{\"message\":\"{{payload}}\"}",
        "dataType": "json",
        "mergeContext": "",
        "queue": "none",
        "domain": "notify",
        "mergecontext": "",
        "x": 640,
        "y": 480,
        "wires": [
        "id": "84b5ec8e1a4c321b",
        "type": "server",
        "name": "Home Assistant",
        "version": 6,
        "addon": false,
        "ha_boolean": [
            "y",
            "yes",
            "true",
            "on",
            "home",
            "open"
        "connectionDelay": false,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": "30",
        "areaSelector": "friendlyName",
        "deviceSelector": "friendlyName",
        "entitySelector": "friendlyName",
        "statusSeparator": ": ",
        "statusYear": "hidden",
        "statusMonth": "short",
        "statusDay": "numeric",
        "statusHourCycle": "default",
        "statusTimeFormat": "h:m",
        "enableGlobalContextStore": false
        "id": "60708f50be1c77dd",
        "type": "global-config",
        "env": [],
        "modules": {
            "node-red-contrib-home-assistant-websocket": "0.80.3"
文本播放没问题 ,执行执行不了。还是用Xiaomi Miot
 楼主| 发表于 2026-9-15 14:41:35 | 显示全部楼层
最后还是使用Xiaomi Miot,完成播放完后恢复到初始音量,避免播放音量过大
        "id": "7d449c344928fd41",
        "type": "tab",
        "label": "音箱play增强",
        "disabled": false,
        "info": "",
        "env": []
        "id": "b38b806c881436e6",
        "type": "change",
        "z": "7d449c344928fd41",
        "name": "初始音量设为flow变量",
        "rules": [
                "t": "move",
                "p": "payload",
                "pt": "msg",
                "to": "start_volume",
                "tot": "flow"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1080,
        "y": 140,
        "wires": [
                "e3373265655d58d7"
        "id": "22e58c0a17bef20b",
        "type": "change",
        "name": "音量获取",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "data.attributes.volume_level",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 880,
        "y": 140,
        "wires": [
                "b38b806c881436e6"
        "id": "0a29249b04af37fe",
        "type": "function",
        "name": "function 3",
        "func": "//获取初始音量\nlet temp_start_volume = flow.get('start_volume');\nmsg.payload = temp_start_volume;   // 将读取到的值赋给 msg.payload\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1120,
        "y": 500,
        "wires": [
                "c4e4087c483bbfca"
        "id": "872892c72846e0a9",
        "type": "trigger",
        "name": "",
        "op1": "",
        "op2": "0",
        "op1type": "nul",
        "op2type": "str",
        "duration": "20",
        "extend": false,
        "overrideDelay": false,
        "units": "s",
        "reset": "",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 940,
        "y": 500,
        "wires": [
                "0a29249b04af37fe"
        "id": "322d3423da1cb070",
        "type": "trigger",
        "name": "",
        "op1": "",
        "op2": "0",
        "op1type": "nul",
        "op2type": "str",
        "duration": "500",
        "extend": true,
        "units": "ms",
        "reset": "",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 430,
        "y": 460,
        "wires": [
                "5c7aad1a210d3fb8"
        "id": "b3d4464c26f31338",
        "type": "comment",
        "name": "node flow global 作用域",
        "info": "作用域\t设置值\t读取值\nnode(节点级)\tnode.set(\"key\", value)\tnode.get(\"key\")\nflow(流程级)\tflow.set(\"key\", value)\tflow.get(\"key\")\nglobal(全局级)\tglobal.set(\"key\", value)\tglobal.get(\"key\")\n推荐始终使用 get() / set() 方法,这样代码更清晰、更健壮,也避免了与同名的节点或函数属性冲突。",
        "x": 1120,
        "y": 440,
        "wires": []
        "id": "28f9b0e0db1d5cae",
        "type": "change",
        "name": "payload转移到 flow.temp",
        "rules": [
                "t": "move",
                "p": "payload",
                "pt": "msg",
                "to": "temp_payload",
                "tot": "flow"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 550,
        "y": 300,
        "wires": [
                "beb4082e4041b99d"
        "id": "5c7aad1a210d3fb8",
        "type": "function",
        "name": "flowl.temp 赋值给msg",
        "func": "let temp=flow.get(\"temp_payload\");\nmsg.payload=temp;\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 680,
        "y": 460,
        "wires": [
                "43e1970410c3758f"
        "id": "b93b3f21c6dff9ef",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "v": "0.7",
                "vt": "num"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "今天天气",
        "x": 160,
        "y": 260,
        "wires": [
                "14e63a1a8888d16b"
        "id": "dd0f6fe4d6cc4259",
        "type": "comment",
        "name": "执行文本",
        "info": "",
        "x": 120,
        "y": 200,
        "wires": []
        "id": "ed691d4483e101b8",
        "type": "comment",
        "name": "需要传送2个参数",
        "info": "需要传送2个参数\n\nglobalt.set_volume 用于设置音量\nmsg.payload  用于执行内容",
        "x": 120,
        "y": 120,
        "wires": []
        "id": "caa220d449abb3f9",
        "type": "comment",
        "name": "设定声音大小",
        "info": "",
        "x": 910,
        "y": 280,
        "wires": []
        "id": "e3373265655d58d7",
        "type": "function",
        "name": "设定音量为global.set_volume",
        "func": "//获取初始音量\nlet temp_set_volume = global.get('set_volume');\nmsg.payload = temp_set_volume;   // 将读取到的值赋给 msg.payload\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 860,
        "y": 240,
        "wires": [
                "b26743bf8bf1991c"
        "id": "f880c306acd67907",
        "type": "comment",
        "name": "音箱play增强",
        "info": "",
        "x": 90,
        "y": 60,
        "wires": []
        "id": "36fcf569d7481831",
        "type": "change",
        "rules": [
                "t": "move",
                "p": "payload",
                "pt": "msg",
                "tot": "flow"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1120,
        "y": 720,
        "wires": [
                "cd582671e44c0d19"
        "id": "1cbc88da8ec9fc63",
        "type": "change",
        "name": "音量获取",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 920,
        "y": 720,
        "wires": [
                "36fcf569d7481831"
        "id": "c5c01d42d789dfea",
        "type": "function",
        "name": "function 5",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1160,
        "y": 1080,
        "wires": [
                "5dd8f7a8a4831274"
        "id": "964b227031e5c39e",
        "type": "trigger",
        "name": "",
        "op1": "",
        "op2": "0",
        "op1type": "nul",
        "op2type": "str",
        "duration": "20",
        "extend": false,
        "units": "s",
        "reset": "",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 980,
        "y": 1080,
        "wires": [
                "c5c01d42d789dfea"
        "id": "74718bbb33e355f3",
        "type": "trigger",
        "name": "",
        "op1": "",
        "op2": "0",
        "op1type": "nul",
        "op2type": "str",
        "duration": "500",
        "extend": true,
        "units": "ms",
        "reset": "",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 450,
        "y": 1000,
        "wires": [
                "cbcafdfc27dba3c0"
        "id": "2e7306662ccd9ba1",
        "type": "comment",
        "x": 1160,
        "y": 1020,
        "wires": []
        "id": "df892a501304fe2c",
        "type": "change",
        "rules": [
                "t": "move",
                "p": "payload",
                "pt": "msg",
                "tot": "flow"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 510,
        "y": 860,
        "wires": [
                "6e6321fe17606b16"
        "id": "cbcafdfc27dba3c0",
        "type": "function",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 740,
        "y": 1000,
        "wires": [
                "d364a13c4101eabf"
        "id": "109801024981b025",
        "type": "comment",
        "name": "播报文本",
        "info": "",
        "x": 100,
        "y": 780,
        "wires": []
        "id": "a128f1b72914532d",
        "type": "comment",
        "name": "设定声音大小",
        "info": "",
        "x": 970,
        "y": 860,
        "wires": []
        "id": "cd582671e44c0d19",
        "type": "function",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1000,
        "y": 820,
        "wires": [
                "ca318184c3ed06bc"
        "id": "0ee76b26f338a9b0",
        "type": "comment",
        "name": "需要传送2个参数",
        "x": 100,
        "y": 720,
        "wires": []
        "id": "012983a4a5610ea6",
        "type": "change",
        "name": "音量获取",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 640,
        "y": 1320,
        "wires": [
                "a488c75bb4e80646"
        "id": "f75af771d31c84b2",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 210,
        "y": 1320,
        "wires": [
                "3eb3cceb0bba90dc"
        "id": "a488c75bb4e80646",
        "type": "debug",
        "name": "debug 15",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 840,
        "y": 1320,
        "wires": []
        "id": "4ace0e6d768d6e7a",
        "type": "comment",
        "name": "检测音量有延迟,需网络同步过来",
        "info": "",
        "x": 150,
        "y": 1260,
        "wires": []
        "id": "301d7d108a26319d",
        "type": "link in",
        "name": "小爱音箱play增强 执行文本 in",
        "links": [],
        "x": 115,
        "y": 360,
        "wires": [
                "28f9b0e0db1d5cae"
        "id": "f05c303b5dba474e",
        "type": "link in",
        "name": "小爱音箱play增强 播报 文本 in",
        "links": [
            "d11d90c8423523c5"
        "x": 155,
        "y": 840,
        "wires": [
                "df892a501304fe2c"
        "id": "b26743bf8bf1991c",
        "name": "设定播报音量",
        "version": 7,
        "action": "media_player.volume_set",
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "media_player.xiaomi_l05c_5377_play_control"
        "labelId": [],
        "data": "{ \"volume_level\": payload }",
        "dataType": "jsonata",
        "mergeContext": "",
        "queue": "none",
        "blockInputOverrides": true,
        "domain": "media_player",
        "service": "volume_set",
        "x": 1120,
        "y": 240,
        "wires": [
                "322d3423da1cb070"
        "id": "43e1970410c3758f",
        "name": "执行内容",
        "version": 7,
        "action": "text.set_value",
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "text.xiaomi_l05c_5377_execute_text_directive"
        "labelId": [],
        "data": "{\"value\": payload}",
        "mergeContext": "",
        "queue": "none",
        "domain": "text",
        "service": "set_value",
        "x": 720,
        "y": 540,
        "wires": [
                "872892c72846e0a9"
        "id": "c4e4087c483bbfca",
        "name": "载入初始音量",
        "version": 7,
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "labelId": [],
        "mergeContext": "",
        "queue": "none",
        "x": 1220,
        "y": 600,
        "wires": [
        "id": "ca318184c3ed06bc",
        "name": "设定播报音量",
        "version": 7,
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "labelId": [],
        "mergeContext": "",
        "queue": "none",
        "x": 1320,
        "y": 840,
        "wires": [
                "74718bbb33e355f3"
        "id": "5dd8f7a8a4831274",
        "name": "载入初始音量",
        "version": 7,
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "labelId": [],
        "mergeContext": "",
        "queue": "none",
        "x": 1260,
        "y": 1180,
        "wires": [
        "id": "d364a13c4101eabf",
        "name": "播放内容",
        "version": 7,
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "text.xiaomi_l05c_5377_play_text"
        "labelId": [],
        "data": "{\"value\":payload}",
        "mergeContext": "",
        "queue": "none",
        "domain": "text",
        "x": 800,
        "y": 1100,
        "wires": [
                "964b227031e5c39e"
        "id": "beb4082e4041b99d",
        "type": "api-current-state",
        "name": "小爱音响增强",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "media_player.xiaomi_l05c_5377_play_control",
        "state_type": "str",
                "property": "payload",
                "propertyType": "msg",
                "value": "string",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "entity"
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 700,
        "y": 140,
        "wires": [
                "22e58c0a17bef20b"
        "id": "6e6321fe17606b16",
        "name": "小爱音响增强",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
                "value": "string",
                "property": "data",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 740,
        "y": 720,
        "wires": [
                "1cbc88da8ec9fc63"
        "id": "3eb3cceb0bba90dc",
        "name": "小爱音箱play增强",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
                "value": "string",
                "property": "data",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 430,
        "y": 1320,
        "wires": [
                "012983a4a5610ea6"
        "type": "inject",
        "name": "播报天气很好",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 310,
        "y": 1640,
        "wires": [
                "a6bcae5c32e889af"
        "version": 7,
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "labelId": [],
        "dataType": "json",
        "mergeContext": "",
        "queue": "none",
        "domain": "notify",
        "mergecontext": "",
        "x": 570,
        "y": 1640,
        "wires": [
        "type": "inject",
        "name": "播报动态消息",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "很好",
        "x": 310,
        "y": 1560,
        "wires": [
                "38e58a1ed2bbd2aa"
        "version": 7,
        "floorId": [],
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "labelId": [],
        "dataType": "json",
        "mergeContext": "",
        "queue": "none",
        "domain": "notify",
        "mergecontext": "",
        "x": 580,
        "y": 1560,
        "wires": [
        "id": "b9cc1cd7079f9f7d",
        "type": "comment",
        "name": "使用xiaomi home插件",
        "info": "",
        "x": 240,
        "y": 1500,
        "wires": []
        "id": "b1ef9351fa59b94e",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "0.7",
        "payload": "天气",
        "x": 300,
        "y": 700,
        "wires": [
                "9075dab7e5300e02"
        "id": "9075dab7e5300e02",
        "type": "change",
        "name": "",
        "rules": [
                "t": "move",
                "p": "topic",
                "pt": "msg",
                "to": "set_volume",
                "tot": "global"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 480,
        "y": 700,
        "wires": [
                "df892a501304fe2c"
        "id": "14e63a1a8888d16b",
        "type": "change",
        "name": "",
        "rules": [
                "t": "move",
                "p": "topic",
                "pt": "msg",
                "to": "set_volume",
                "tot": "global"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 400,
        "y": 180,
        "wires": [
                "28f9b0e0db1d5cae"
        "type": "server",
        "version": 6,
        "addon": false,
        "ha_boolean": [
            "y",
            "yes",
            "true",
            "on",
            "home",
            "open"
        "cacheJson": true,
        "heartbeat": false,
        "id": "016d100c6083c227",
        "env": [],
        "modules": {
flows (1).rar
3.6 KB, 下载次数: 1
GMT+8, 2026-10-7 20:19 , Processed in 0.016598 second(s), 5 queries , Redis On.
