260731 11:40:37[0.9.2_00000000000000][core.providers.asr.base]-INFO-识别文本: 你会什么
260731 11:40:37[0.9.2_SiDoDoDonocaCh][core.connection]-INFO-大模型收到用户消息: 你会什么
260731 11:40:39[0.9.2_SiDoDoDonocaCh][core.connection]-ERROR-LLM stream processing error: Error code: 404 - {'error': {'code': 'InvalidEndpointOrModel.NotFound', 'message': 'The model or endpoint doubao-pro-32k-241215 does not exist or you do not have access to it. Request id: 0217854692394205fc9fc3c0c40d4ed9ed09f6d5661eacce351c8', 'param': '', 'type': 'Not Found'}}
260731 11:40:40[0.9.2_SiDoDoDonocaCh][core.handle.sendAudioHandle]-INFO-发送第一段语音: 主人,小智现在有点忙
260731 11:40:40[0.9.2_SiDoDoDonocaCh][core.handle.sendAudioHandle]-INFO-发送音频消息: SentenceType.FIRST, 主人,小智现在有点忙
260731 11:40:40[0.9.2_00000000000000][core.providers.tts.base]-INFO-语音生成成功: 主人,小智现在有点忙,重试0次
260731 11:40:40[0.9.2_SiDoDoDonocaCh][core.handle.sendAudioHandle]-INFO-发送音频消息: SentenceType.FIRST, 我们稍后再试吧
260731 11:40:40[0.9.2_00000000000000][core.providers.tts.base]-INFO-语音生成成功: 我们稍后再试吧,重试0次
260731 11:40:40[0.9.2_SiDoDoDonocaCh][core.handle.sendAudioHandle]-INFO-发送音频消息: SentenceType.LAST, None
260731 11:40:44[0.9.2_SiDoDoDonocaCh][core.handle.textMessageProcessor]-INFO-收到listen消息:{"session_id":"","type":"listen","state":"start","mode":"auto"}
260731 11:42:43[0.9.2_SiDoDoDonocaCh][core.connection]-INFO-大模型收到用户消息: 请你以"时间过得真快"未来头,用富有感情、依依不舍的话来结束这场对话吧!
260731 11:42:43[0.9.2_SiDoDoDonocaCh][core.connection]-ERROR-LLM stream processing error: Error code: 404 - {'error': {'code': 'InvalidEndpointOrModel.NotFound', 'message': 'The model or endpoint doubao-pro-32k-241215 does not exist or you do not have access to it. Request id: 021785469363786b930e48eba27b99ef955dcd4c43e083d395237', 'param': '', 'type': 'Not Found'}}
260731 11:42:44[0.9.2_SiDoDoDonocaCh][core.handle.sendAudioHandle]-INFO-发送第一段语音: 主人,小智现在有点忙
260731 11:42:44[0.9.2_SiDoDoDonocaCh][core.handle.sendAudioHandle]-INFO-发送音频消息: SentenceType.FIRST, 主人,小智现在有点忙
260731 11:42:44[0.9.2_00000000000000][core.providers.tts.base]-INFO-语音生成成功: 主人,小智现在有点忙,重试0次
260731 11:42:45[0.9.2_SiDoDoDonocaCh][core.handle.sendAudioHandle]-INFO-发送音频消息: SentenceType.FIRST, 我们稍后再试吧
260731 11:42:45[0.9.2_00000000000000][core.providers.tts.base]-INFO-语音生成成功: 我们稍后再试吧,重试0次
260731 11:42:45[0.9.2_SiDoDoDonocaCh][core.handle.sendAudioHandle]-INFO-发送音频消息: SentenceType.LAST, None
260731 11:42:48[0.9.2_SiDoDoDonocaCh][core.connection]-INFO-超时检查任务已退出
260731 11:42:48[0.9.2_00000000000000][core.providers.tools.unified_tool_handler]-INFO-工具处理器清理完成
260731 11:42:48[0.9.2_SiDoDoDonocaCh][core.connection]-INFO-客户端断开连接
260731 11:42:48[0.9.2_SiDoDoDonocaCh][core.connection]-INFO-连接资源已释放
大家帮我看看是什么原因造成的问题
