楼主: zorankeinfo
[插件集成] 射频窗帘(同步HK)Broadlink.Cover插件,已支持 HACS
 火.. [复制链接]
 楼主| 发表于 2019-4-28 17:51:33 | 显示全部楼层
更新适应0.921
发表于 2019-4-28 19:21:26 | 显示全部楼层
已经升级到0.92了, 发现原来按照switch的方式无法每次都开启开关了, 偶尔才能开启,不知道为什么。使用以下这个。
发表于 2019-5-3 11:42:52 | 显示全部楼层
新版本,终于能用了,感谢分享!
发表于 2019-5-5 15:22:13 | 显示全部楼层
多谢分享
发表于 2019-5-15 16:06:51 | 显示全部楼层
2019-05-15 16:01:26 ERROR (MainThread) [homeassistant.components.cover] Error while setting up platform broadlink_cover
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
    return fut.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
    result = coro.send(None)
  File "/usr/lib/python3.5/asyncio/coroutines.py", line 210, in coro
    res = func(*args, **kw)
  File "/home/pi/.homeassistant/custom_components/broadlink_cover/cover.py", line 106, in async_setup_platform
    device_config.get(CONF_POS_SENSOR),
  File "/home/pi/.homeassistant/custom_components/broadlink_cover/cover.py", line 141, in __init__
    self._cmd_open = b64decode(cmd_open) if cmd_open else None
  File "/usr/lib/python3.5/base64.py", line 88, in b64decode
    return binascii.a2b_base64(s)
binascii.Error: Incorrect padding
提示这个错误, ha 版本0.92.2, python3.5 。 不确定是哪里错误,上网查是因为编码的原因,请大神指教
补充配置信息:
- platform: broadlink_cover
  host: 192.168.88.166
  mac: '78:0F:77:5A:6C:C2'
  covers:
    banghe:
      travel_time: 30
      command_open: '###'
      command_close: '###'
      command_stop: '###'
发表于 2019-5-15 17:43:34 | 显示全部楼层
修改了cover.py文件 , 大概在143行的位置, 我使用的python是3.5版本,上网查了好像跟python2版本的base64编码差距有点大,
原来配置
        self._cmd_close = b64decode(cmd_close) if cmd_close else None
        if cmd_stop:
            self._cmd_stop = b64decode(cmd_stop)
            self._supported_features=None
修改后的配置
        self._cmd_open = b64decode(cmd_open + "=====") if cmd_open else None
        self._cmd_close = b64decode(cmd_close + "=====") if cmd_close else None
        if cmd_stop:
            self._cmd_stop = b64decode(cmd_stop + "=====")
具体修改内容就是在b64decode(cmd_open) => b64decode(cmd_open + "=====")
具体解释如下:
避免TypeError:使用Python的base64编码填充不正确
上面链接中翻译后的解释看图片
最后希望能帮助到其他人
解决办法
解决办法
我就是六神
活跃会员教程狂人灌水之王
发表于 2019-5-20 19:01:17 | 显示全部楼层
研究了下插件
    covers = []
    for object_id, device_config in devices.items():
        covers.append(
            RMCover(
                hass,
                object_id,
                broadlink_device,
                device_config.get(CONF_NAME,object_id),
                device_config.get(CONF_COMMAND_OPEN),
                device_config.get(CONF_COMMAND_CLOSE),
                device_config.get(CONF_COMMAND_STOP),
                device_config.get(CONF_TRAVEL_TIME),
这个貌似 设置传感器只支持博联 的门磁传感器啊??     有时候 明明current_position = 0 了  但是还是正在closing 而不是closed
发表于 2019-5-23 23:24:48 | 显示全部楼层
[url=]TIM图片20190523232227.png显示不了开关了,怎么改[/url]
发表于 2019-5-24 00:02:08 | 显示全部楼层
Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 363, in _async_add_entity
    await entity.async_added_to_hass()
  File "/config/custom_components/broadlink_cover/cover.py", line 350, in async_added_to_hass
    self._position = last_state.attributes['current_position']
KeyError: 'current_position'
发表于 2019-6-3 23:29:07 | 显示全部楼层
0.93.2 能正常运行吗?测了一下好像有问题
GMT+8, 2025-9-18 03:12 , Processed in 0.638028 second(s), 9 queries , MemCached On.
