查看: 582|回复: 5
[技术探讨] 今日升级 core 2025.9.0 后hassbox无法加载
发表于 2025-9-5 07:31:02 | 显示全部楼层 |阅读模式
今日升级 core 2025.9.0 后 hassbox无法加载,下面是log 麻烦大神看看怎么处理,其它插件现在暂时没有发现不兼容。
日志记录器: homeassistant.setup
来源: setup.py:343
首次出现: 07:28:01 (1 次出现)
上次记录: 07:28:01
Setup failed for custom integration 'hassbox_store': Unable to import component: cannot import name 'json_loads' from 'homeassistant.helpers.json' (/usr/src/homeassistant/homeassistant/helpers/json.py)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1003, in async_get_component
    comp = await self.hass.async_add_import_executor_job(
        self._get_component, True
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1063, in _get_component
    ComponentProtocol, importlib.import_module(self.pkg_path)
  File "/usr/src/homeassistant/homeassistant/util/loop.py", line 201, in protected_loop_func
    return func(*args, **kwargs)
  File "/usr/local/lib/python3.13/importlib/__init__.py", line 88, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 1026, in exec_module
  File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
  File "/config/custom_components/hassbox_store/__init__.py", line 20, in <module>
    from .base import HassBoxStore
  File "/config/custom_components/hassbox_store/base.py", line 39, in <module>
    from .utils.json import json_loads
  File "/config/custom_components/hassbox_store/utils/json.py", line 3, in <module>
    from homeassistant.helpers.json import json_loads
ImportError: cannot import name 'json_loads' from 'homeassistant.helpers.json' (/usr/src/homeassistant/homeassistant/helpers/json.py)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 343, in _async_setup_component
    component = await integration.async_get_component()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1023, in async_get_component
    self._component_future.result()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1015, in async_get_component
    comp = self._get_component()
发表于 2025-9-5 09:37:20 | 显示全部楼层
一样,先退回8.3了
hhh. 手机认证
发表于 2025-9-5 17:26:47 | 显示全部楼层
hassbox_store 自定义组件试图从 Home Assistant 的内部模块 homeassistant.helpers.json 导入 json_loads,但是当前 HA 版本中已经没有这个函数了。
提醒 hassbox 该升级了
 楼主| 发表于 2025-9-5 18:06:52 | 显示全部楼层
hhh. 发表于 2025-9-5 17:26
hassbox_store 自定义组件试图从 Home Assistant 的内部模块 homeassistant.helpers.json 导入 json_loads ...
那我就等等 等hassbox升级
发表于 2025-9-6 20:46:37 | 显示全部楼层
重新安装下就好了
 楼主| 发表于 2025-9-7 10:27:39 | 显示全部楼层
flyzero 发表于 2025-9-6 20:46
重新安装下就好了
不行
删除集成后,无法重新安装。
GMT+8, 2025-10-15 03:59 , Processed in 0.080546 second(s), 11 queries , MemCached On.
