查看: 482|回复: 4
[技术探讨] 大家帮我看看 这个esphome的代码??
发表于 2025-8-18 19:37:58 | 显示全部楼层 |阅读模式
lifesmart 的超级碗,现在已经刷esphome固件
node_project_name: "LifeSmart.irremoteVsLight"
  node_project_version: "esp8266ex-v1.0.0"
  node_build_min_version: "2023.12.0"
esphome:
  friendly_name: ${node_name_friendly}
  project:
    version: ${node_project_version}
  name_add_mac_suffix: ${node_name_add_mac_suffix}
  min_version: ${node_build_min_version}
esp8266:
  board: esp01_1m
  restore_from_flash: false
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "*****************"
ota:
  - platform: esphome
    password: "*************"
wifi:
  ssid: "****"
  password: "*********"
  ap:
    ssid: "***"
    password: "********"
captive_portal:
web_server:
  port: 80
  include_internal: true
  version: 2
remote_receiver:
  pin:
    number: ${ir_receiver_pin}
    inverted: true
    mode: INPUT_PULLUP
  #dump: nec
  dump: all
remote_transmitter:
  pin:
    number: ${ir_transmitter_pin}
  carrier_duty_percent: 50%
switch:
  - platform: output
    output: id_pin_led_red
  - platform: output
    output: id_pin_led_green
  - platform: output
    output: id_pin_led_blue
  - platform: restart
  - platform: factory_reset
  - platform: safe_mode
output:
  #红色led
  - platform: esp8266_pwm
    pin:
      number: ${led_red_pin}
      inverted: false
  #绿色led
    pin:
      number: ${led_green_pin}
      inverted: false
  #蓝色led
    pin:
      number: ${led_blue_pin}
      inverted: false
light:
  - platform: rgb
    red: id_pin_led_red
    green: id_pin_led_green
    blue: id_pin_led_blue
    restore_mode: ALWAYS_ON
    default_transition_length: 0.5s
    effects:
      - random:
          transition_length: 4s
          update_interval: 5s
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: ${button_pin}
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
    - timing:
        - ON for at least 5s
      then:
        - logger.log: "Long press."
        #- 添加长按动作
      invalid_cooldown: 0s
    #双击
    - timing:
        - ON for at most 0.5s
        - OFF for at most 0.5s
        - OFF for at least 0.2s
      then:
        - logger.log: "double click."
        - lambda: |-
              id(id_light_color_lights).turn_off().perform();
    #单击
    - timing:
        - OFF for at least 0.01s
      then:
        - logger.log: "single click."
        - lambda: |-
              int color_type = id(id_color_type_lastvalue) % id(id_color_type_maxvalue);
              ESP_LOGI("main","----current color: type[%d],lastvalue[%d],maxvalue[%d].",color_type,id(id_color_type_lastvalue),id(id_color_type_maxvalue));
              switch(color_type)
                case 0:{
                  auto call = id(id_light_color_lights).turn_on();
                  call.set_brightness(1.0);
                  call.set_rgb(1.0, 0.0, 0.0);
                  call.perform();
                  break;
                case 1: {
                  call.set_rgb(0.0, 1.0, 0.0);
                  call.perform();
                  break;
                case 2: {
                  call.set_rgb(0.0, 0.0, 1.0);
                  call.perform();
                  break;
                case 3: {
                  call.set_rgb(1.0, 1.0, 0.0);
                  call.perform();
                  break;
                case 4: {
                  call.set_rgb(1.0, 0.0, 1.0);
                  call.perform();
                  break;
                case 5: {
                  call.set_rgb(0.0, 1.0, 1.0);
                  call.perform();
                  break;
                case 6: {
                  call.set_rgb(1.0, 1.0, 1.0);
                  call.perform();
                  break;
                case 7: {
                  call.set_effect("Random");
                  call.perform();
                  break;
                case 8: {
                  break;
                default:
                  break;
              id(id_color_type_lastvalue) += 1;
              if(id(id_color_type_lastvalue) == 9 )
                id(id_color_type_lastvalue) = 0;
globals:
  - id: id_color_type_lastvalue
    type: int
    restore_value: no
    initial_value: '0'
  - id: id_color_type_maxvalue
    type: int
    restore_value: no
    initial_value: '9'
debug:
  update_interval: 10s
text_sensor:
  - platform: debug
    device:
    reset_reason:
  - platform: wifi_info
    ip_address:
      update_interval: 30s
    ssid:
    bssid:
    mac_address:
  - platform: debug
    free:
#    fragmentation:
#      name: "Heap Fragmentation"
#    block:
#      name: "Heap Max Block"
#    loop_time:
#      name: "Loop Time"
  - platform: uptime
    entity_category: diagnostic
    update_interval: 60s
    internal: false
    #on_raw_value:
    #  then:
    #    - text_sensor.template.publish:
    #        id: id_sensor_uptime
    #        state: !lambda |-
    #          int seconds = round(id(id_sensor_uptime_raw).raw_state);
    #          int days = seconds / (24 * 3600);
    #          seconds = seconds % (24 * 3600);
    #          int hours = seconds / 3600;
    #          seconds = seconds % 3600;
    #          int minutes = seconds /  60;
    #          seconds = seconds % 60;
    #          return (
    #            (days ? String(days) + "d " : "") +
    #            (hours ? String(hours) + "h " : "") +
    #            (minutes ? String(minutes) + "m " : "") +
    #            (String(seconds) + "s")
    #          ).c_str();
  - platform: wifi_signal
现在这些代码编译后 有实体正常识别
button:
  - platform: template
    icon: mdi:投影机开关
    on_press:
      - remote_transmitter.transmit_nec:
          address: 0x3000
          command: 0xFD02
          command_repeats: 1
    icon: mdi:SmartEco
    on_press:
          address: 0x3000
          command: 0xCF30
          command_repeats: 1
    icon: mdi:Meun
    on_press:
          address: 0x3000
          command: 0xF00F
          command_repeats: 1
    icon: mdiower
    on_press:
          address: 0x4CB3
          command: 0x23DC
          command_repeats: 1
    icon: mdi:Enter
    on_press:
          address: 0x4CB3
          command: 0x31CE
          command_repeats: 1
    icon: mdi:CH_UP
    on_press:
          address: 0x4CB3
          command: 0x7A85
          command_repeats: 1
    icon: mdi:CH_DOWN
    on_press:
          address: 0x4CB3
          command: 0x7986
          command_repeats: 1
    icon: mdi:HK1_POWER
    on_press:
          address: 0xFE01
          command: 0xBF40
          command_repeats: 1
    icon: mdi:HK1_HOME
    on_press:
          address: 0xFE01
          command: 0xEE11
          command_repeats: 1
    icon: mdi:HK1_ENTER
    on_press:
          address: 0xFE01
          command: 0xEC13
          command_repeats: 1
    icon: mdi:HK1_BACK
    on_press:
          address: 0xFE01
          command: 0xE619
          command_repeats: 1
    icon: mdi:HK1_OPTION
    on_press:
          address: 0xFE01
          command: 0xB34C
          command_repeats: 1
    icon: mdi:HK1_VOL_UP
    on_press:
          address: 0xFE01
          command: 0xE718
          command_repeats: 1
    icon: mdi:HK1_VOL_DOWN
    on_press:
          address: 0xFE01
          command: 0xEF10
          command_repeats: 1
    icon: mdiENON_ON
    on_press:
      - remote_transmitter.transmit_aeha:
          address: 0x2A4C
          data: [0x02,0x84,0x00,0x86]
    icon: mdiENON_STANDBY
    on_press:
          address: 0x2A4C
          data: [0x02,0x8C,0x00,0x8E]
    icon: mdiENON_VOL_UP
    on_press:
          address: 0x2A4C
          data: [0x02,0x80,0xE8,0x6A]
    icon: mdiENON_VOL_DOWN
    on_press:
          address: 0x2A4C
          data: [0x02,0x88,0xE8,0x62]
    icon: mdiENON_HDMI1
    on_press:
          address: 0x2A4C
          data: [0x02,0x88,0xB4,0x3E]
    icon: mdiENON_HDMI2
    on_press:
          address: 0x2A4C
          data: [0x02,0x80,0xB4,0x36]
    icon: mdiENON_HDMI3
    on_press:
          address: 0x2A4C
          data: [0x02,0x8A,0xB4,0x3C]
    icon: mdiENON_HDMI4
    on_press:
          address: 0x2A4C
          data: [0x02,0x84,0xB4,0x32]
    icon: mdiENON_MUTE
    on_press:
          address: 0x2A4C
          data: [0x02,0x84,0xE8,0x6E]
    icon: mdi:MIDEA_AC_POWER_OFF
    on_press:
      - remote_transmitter.transmit_toshiba_ac:
          rc_code_1: 0xB24D7B84E01F
    icon: mdi:MIDEA_AC_POWER_ON
    on_press:
          rc_code_1: 0xB24D9F60D02F
    icon: mdi:MIDEA_TEMPERATURE_30
    on_press:
          rc_code_1: 0xB24D9F60B04F
    icon: mdi:MIDEA_TEMPERATURE_29
    on_press:
          rc_code_1: 0xB24D1FE0A45B
    icon: mdi:MIDEA_TEMPERATURE_28
    on_press:
          rc_code_1: 0xB24D1FE0847B
    icon: mdi:MIDEA_TEMPERATURE_27
    on_press:
          rc_code_1: 0xB24D1FE0946B
    icon: mdi:MIDEA_TEMPERATURE_26
    on_press:
          rc_code_1: 0xB24D1FE0D42B
    icon: mdi:MIDEA_TEMPERATURE_25
    on_press:
          rc_code_1: 0xB24D1FE0C43B
    icon: mdi:MIDEA_TEMPERATURE_24
    on_press:
          rc_code_1: 0xB24D1FE044BB
    icon: mdi:MIDEA_MODE_HOT
    on_press:
          rc_code_1: 0xB24D9F60BC43
    icon: mdi:MIDEA_MODE_AUTO
    on_press:
          rc_code_1: 0xB24D1FE0B847
    icon: mdi:MIDEA_MODE_COOL
    on_press:
    icon: mdi:MIDEA_MODE_Dehumidity
    on_press:
          rc_code_1: 0xB24D1FE0B44B
    icon: mdi:MIDEA_MODE_FAN
    on_press:
          rc_code_1: 0xB24D9F60E41B
    icon: mdi:MIDEA_MODE_FAN_SPEED_AUTO
    on_press:
          rc_code_1: 0xB24DBF40BC43
    icon: mdi:MIDEA_MODE_FAN_SPEED_LOW
    on_press:
    icon: mdi:MIDEA_MODE_FAN_SPEED_MED
    on_press:
          rc_code_1: 0xB24D5FA0BC43
    icon: mdi:MIDEA_MODE_FAN_SPEED_FULL
    on_press:
          rc_code_1: 0xB24D3FC0BC43
但是我把这些遥控器的 代码写进去后,效验和编译都正常,但是固件写入后,就没有实体了,一个都没???
麻烦大神帮我看看 这个怎么修改!!
yybl 手机认证
发表于 2025-8-20 08:24:17 来自手机 | 显示全部楼层
中文去掉
发表于 2025-8-20 09:56:46 | 显示全部楼层
中文换成英文或者拼音  或者加不同的字母
 楼主| 发表于 2025-8-22 19:01:46 | 显示全部楼层
已解决 确确实实是中文字符的问题  但是把空调代码删了,不然过一会,实体全部变灰色
发表于 4 天前 | 显示全部楼层
中文名也没问题,加引号呀,示例: name: '投影仪开关'
GMT+8, 2025-9-13 03:19 , Processed in 0.275373 second(s), 7 queries , MemCached On.
