楼主:
[基础教程] 【HomeAssistant】树莓派连接蓝牙音箱教程(无坑版)
 火.. [复制链接]
发表于 2017-8-15 14:57:01 | 显示全部楼层
我回头试试这个蓝牙音箱!!
发表于 2017-8-15 16:52:30 | 显示全部楼层
谢谢分享!
发表于 2017-8-16 15:23:23 | 显示全部楼层
谢谢,马上回去试试。
发表于 2017-8-17 19:51:40 | 显示全部楼层
测试可以响,但VLC播放不行,不能做TTS,是什么情况????
 楼主| 发表于 2017-8-17 20:21:56 | 显示全部楼层
可能是权限的事,没解决。现在不用这方案做tts。
 楼主| 发表于 2017-8-17 20:22:01 | 显示全部楼层
教程狂人论坛风云人物突出贡献
发表于 2017-8-17 20:30:20 | 显示全部楼层
gzroc 发表于 2017-8-15 14:57
我回头试试这个蓝牙音箱!!
你考虑清楚了,便携式蓝牙音箱,无输出5分钟、10分钟会自动关机。我已经放弃了,测试了蓝牙破音、断断续续的。
发表于 2017-9-1 16:23:35 | 显示全部楼层
支持了啊。。嘿嘿
发表于 2017-9-12 11:05:48 | 显示全部楼层
好东西,谢谢分享
发表于 2017-9-14 11:02:01 | 显示全部楼层
蓝牙显示已连接成功,但是使用#显示可用发音设备
pacmd list-sinks命令时,显示只有一台可用?请教楼主这是怎么回事呢??
1 sink(s) available.
  * index: 0
        driver: <module-alsa-card.c>
        flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY FLAT_VOLUME DYNAMIC_LATENCY
        state: SUSPENDED
        suspend cause: IDLE
        priority: 9009
        volume: front-left: 81920 / 125% / 5.81 dB,   front-right: 78643 / 120% / 4.75 dB
                balance -0.04
        base volume: 56210 /  86% / -4.00 dB
        volume steps: 65537
        muted: no
        current latency: 0.00 ms
        max request: 0 KiB
        max rewind: 0 KiB
        monitor source: 1
        sample spec: s16le 2ch 44100Hz
        channel map: front-left,front-right
                     Stereo
        used by: 0
        linked by: 0
        configured latency: 0.00 ms; range is 0.50 .. 743.04 ms
        card: 1 <alsa_card.platform-soc_audio>
        module: 7
        properties:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = "bcm2835 ALSA"
                alsa.id = "bcm2835 ALSA"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "0"
                alsa.card = "0"
                alsa.card_name = "bcm2835 ALSA"
                alsa.long_card_name = "bcm2835 ALSA"
                alsa.driver_name = "snd_bcm2835"
                device.bus_path = "platform-soc:audio"
                sysfs.path = "/devices/platform/soc/soc:audio/sound/card0"
                device.string = "hw:0"
GMT+8, 2025-9-10 06:18 , Processed in 0.078465 second(s), 17 queries , MemCached On.
