查看: 676|回复: 3
[技术探讨] 求助esp32s3开发板突然连不上了。
发表于 2025-6-30 09:22:51 | 显示全部楼层 |阅读模式
之前还好好的,第二天再次加电,wifi能ping通,但是log里显示:
WARNING Can't connect to ESPHome API for esp32s3-ir @ 192.168.51.110: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.51.110', port=6053))]: [Errno 113] Connect call failed ('192.168.51.110', 6053) (SocketAPIError)
尝试按如下基础配置线刷入板子,显示成功(用esphome和flash download tool都试过),但是还是报错,hass里连不上,ota也报错连不上。
esphome:
  friendly_name: esp32s3-ir
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xIWwQb78JefwkurCguIcAu7LMM5nTTi8Etd4XuHSLek="
ota:
  - platform: esphome
    password: "b9d74554e21b4d015eadd88265f519c0"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32S3-Ir Fallback Hotspot"
    password: "dK3uy0oYHh2q"
captive_portal:
难不成是板子坏了?
发表于 2025-6-30 09:34:51 | 显示全部楼层
是不是IP变了,去路由器后台看看
发表于 2025-6-30 21:28:35 | 显示全部楼层
看看能不能ping通
 楼主| 发表于 2025-6-30 23:04:04 | 显示全部楼层
可以ping通,更换了静态ip也可以ping通
GMT+8, 2025-9-14 03:32 , Processed in 0.211648 second(s), 11 queries , MemCached On.
