查看: 296|回复: 1
冬瓜ha安装失败
发表于 2025-6-19 16:21:41 | 显示全部楼层 |阅读模式
装好等了一天没初始化完,死心了 改ip挂科学 结果发现
2025-06-19 16:17:36.541 ERROR (MainThread) [supervisor.docker.interface] Can't install r.hassbus.com/home-assistant/qemux86-64-homeassistant:2025.6.1: 404 Client Error for http+docker://localhost/v1.48/images/r.hassbus.com/home-assistant/qemux86-64-homeassistant:2025.6.1/json: Not Found ("No such image: r.hassbus.com/home-assistant/qemux86-64-homeassistant:2025.6.1")
2025-06-19 16:17:36.542 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
这个要怎么解决啊????
发表于 2025-6-20 11:25:01 | 显示全部楼层
冬瓜的不用科学。还有,虚拟机的话,注意扩容
GMT+8, 2025-8-2 16:17 , Processed in 0.945457 second(s), 6 queries , MemCached On.
