查看: 724|回复: 1
[技术探讨] apexcharts-card疑难杂症
发表于 2025-5-16 09:45:41 | 显示全部楼层 |阅读模式
type: custom:apexcharts-card
stacked: true
graph_span: 30d
span:
  start: day
  offset: "-30d"
show:
  last_updated: true
header:
  show: true
  show_states: true
  colorize_states: true
  title: 30天电量
yaxis:
  - id: first
    decimals: 0
    apex_config:
      tickAmount: 5
    min: 0
    max: 25
series:
  - entity: sensor.history_day
    type: column
    color: rgb(51,153,255)
    attribute: history_day_value
    data_generator: |
      return entity.attributes.history_day_value.map(entry => {
        return {
          x: entry.date,
          y: entry.kwh
  - entity: sensor.shantou_temperature
    type: line
    stroke_width: 2
    color: orange
    yaxis_id: first
    group_by:
      func: max
      duration: 1d
这个apexcharts-card加了个温度曲线,就显示不了了,百思不得其解
发表于 2025-6-3 11:28:42 | 显示全部楼层
建议按照Github上的官方例子改entity信息即可
GMT+8, 2025-9-18 02:52 , Processed in 0.583022 second(s), 10 queries , MemCached On.
