查看: 568|回复: 1
[求助] SONOFF ZBDongle-E 在zigbee2mqtt下不能启动
发表于 2025-5-11 00:09:33 | 显示全部楼层 |阅读模式
SONOFF ZBDongle-E 在zigbee2mqtt下不能启动,在zha下可以。
[2025-05-11 00:06:04] info:         zh:ember: Using default stack config.
[2025-05-11 00:06:04] info:         zh:ember: ======== Ember Adapter Starting ========
[2025-05-11 00:06:04] info:         zh:ember:ezsp: ======== EZSP starting ========
[2025-05-11 00:06:04] info:         zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-11 00:06:04] info:         zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2025-05-11 00:06:04] info:         zh:ember:uart:ash: Serial port opened
[2025-05-11 00:06:04] info:         zh:ember:uart:ash: ======== ASH starting ========
[2025-05-11 00:06:05] info:         zh:ember:uart:ash: ======== ASH connected ========
[2025-05-11 00:06:05] info:         zh:ember:uart:ash: ======== ASH started ========
[2025-05-11 00:06:05] info:         zh:ember:ezsp: ======== EZSP started ========
[2025-05-11 00:06:05] info:         zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched.
[2025-05-11 00:06:05] info:         zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.4 [GA]","build":0,"major":7,"minor":4,"patch":4,"special":0,"type":170}
[2025-05-11 00:06:05] info:         zh:ember: [STACK STATUS] Network up.
[2025-05-11 00:06:05] info:         zh:ember: [INIT TC] Adapter network does not match config. Leaving network...
[2025-05-11 00:06:06] info:         zh:ember: [STACK STATUS] Network down.
[2025-05-11 00:06:07] error:         z2m: Error while starting zigbee-herdsman
[2025-05-11 00:06:07] error:         z2m: Failed to start zigbee-herdsman
[2025-05-11 00:06:07] error:         z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-05-11 00:06:07] error:         z2m: Exiting...
[2025-05-11 00:06:07] error:         z2m: Error: [BACKUP] Current backup file is not for EmberZNet stack.
    at EmberAdapter.getStoredBackup (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1163:23)
    at EmberAdapter.initTrustCenter (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:925:29)
    at EmberAdapter.initEzsp (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:708:18)
    at EmberAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1548:24)
    at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
    at Zigbee.start (/app/lib/zigbee.ts:70:27)
    at Controller.start (/app/lib/controller.ts:104:13)
    at start (/app/index.js:149:5)
上面是zigbee2mqtt日志。大家给分析一下。
https://www.zigbee2mqtt.io/devices/ZBDongle-E.html
发表于 2025-5-12 10:56:37 | 显示全部楼层
adapter用 ezsp
GMT+8, 2025-9-13 03:24 , Processed in 0.662149 second(s), 8 queries , MemCached On.
