查看: 848|回复: 1
[经验分享] 自制天然气报警器esphome esp32 mq4传感器
发表于 2025-5-9 18:35:01 | 显示全部楼层 |阅读模式
新家装修好厨房有一个自带的燃气报警器(接口24v电压),然而并没有什么用,和物业应该没有通信联系。想了想还是改造一下接入ha配合小米机械手实现燃气自动关阀。
硬件:esp32、mq4传感器、电压转换模块
esphome代码如下:
esphome:
esp32:
  board: esp32dev
logger:
  level: DEBUG
ota:
  platform: esphome
web_server:
  port: 80
api:
  password: "********"
wifi:
  ssid: "******"
  password: "*********"
switch:
  - platform: restart
    name: "ESP Restart Switch"
number:
  - platform: template
    initial_value: 150
    min_value: 100
    max_value: 10000
    step: 100
    icon: "mdi:alert-circle"
    optimistic: true
binary_sensor:
    lambda: |-
      // Use LPG concentration sensor ID
      float ppm = id(LPG_Concentration).state;
      float threshold = id(alarm_threshold).state;
      return ppm >= threshold;
  # Raw voltage sensor (ADC reading)
  - platform: adc
    pin: GPIO33
    update_interval: 1s
    unit_of_measurement: "V"
    attenuation: 12db  # Fix deprecated warning
    filters:
      - lambda: |-
          // Convert ADC raw value to voltage
          float voltage = (float)x / 0.694;  // Assume ADC resolution is 12-bit
          return roundf(voltage * 1000) / 1000;  // Round to 3 decimal places
  # LPG concentration calculation template sensor
    id: LPG_Concentration  # Add ID definition
    lambda: |-
      static float last_ppm = 0;  // Cache the last valid PPM value
      float voltage = id(mq5_raw_voltage).state;
      if (voltage == 0 || voltage >= 5.0) {
        return last_ppm;  // If voltage is invalid, return the last PPM value
      float ppm = 39.2332667161086 * exp(1.46671939878595 * voltage);
      last_ppm = roundf(ppm * 10) / 10;  // Round to 1 decimal place and update cache
      return last_ppm;
    unit_of_measurement: "ppm"
    accuracy_decimals: 1
    update_interval: 1s  # Increase update frequency to 200ms
text_sensor:
    name: "ESP 设备 IP 地址"
    lambda: |-
      return std::string(WiFi.localIP().toString().c_str());
注意:1.最好不要用打火机测试燃气数值,容易损坏传感器。
            2.电压和浓度ppm值我折腾了好几天差了很多资料很多视频都没有好的解决办法。现在的计算函数是官方文档中电压ppm值函数图取点拟合函数后的计算公式。
            3.我的电路使用了分压电路,两个10千欧并联后与一个2.2千欧电阻串联。分压比为0.694。具体原理请自行了解。
发表于 2025-5-9 19:34:13 | 显示全部楼层
我用mq135做的,就是空气湿度升高传感器的值也会升高,但是用打火机气体测试很灵敏
GMT+8, 2025-9-14 03:25 , Processed in 0.051383 second(s), 10 queries , MemCached On.
