查看: 849|回复: 2
[技术探讨] DIY手持 土壤氮磷钾检测仪,接入HA
发表于 2025-4-27 12:15:57 | 显示全部楼层 |阅读模式
手持 土壤钾检测仪,接入HA
esphome:
  friendly_name: "NPK8266"
esp8266:
  board: nodemcuv2
logger:
api:
ota:
  - platform: esphome
wifi:
  ssid: !secret wifi_ssid
  use_address: 192.168.88.57
  ap:
    ssid: "Npk8266"
    password: "12345678"
captive_portal:
web_server:
button:
  - platform: restart
i2c:
  sda: D3
  scl: D4
uart:
  tx_pin: D6
  rx_pin: D7
  baud_rate: 4800
  stop_bits: 1
modbus:
  send_wait_time: 200ms
modbus_controller:
  - id: modbus_bus
    address: 0x01
    modbus_id: mod_bus
    command_throttle: 0ms
    setup_priority: -10
    update_interval: 5s
font:
  - file: 'JDSTJ.ttf'
    glyphs: 氮磷钾传感器含量-_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz
#SSD1306 OLED显示屏配置
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C   #SSD1306常见I2C地址
    lambda: |-
      // 显示设备名称
      //it.print(0, 0, id(font1), TextAlign::TOP_CENTER, "氮磷钾传感器");
      // 显示氮含量
      it.printf(0, 0, id(font1), TextAlign::TOP_LEFT, "氮含量: %d mg", (int)id(nitrogen_sensor).state);
      // 显示磷含量
      it.printf(0, 20, id(font1), TextAlign::TOP_LEFT, "磷含量: %d mg", (int)id(phosphorus_sensor).state);
      // 显示钾含量
      it.printf(0, 40, id(font1), TextAlign::TOP_LEFT, "钾含量: %d mg", (int)id(potassium_sensor).state);
# 传感器定义
  - platform: modbus_controller
    modbus_controller_id: modbus_bus
    address: 0x1E
    unit_of_measurement: "mg/kg"
    accuracy_decimals: 0
    register_type: holding
    value_type: S_WORD
    address: 0x1F
    value_type: S_WORD
    address: 0x20
    value_type: S_WORD
485型土壤氮磷钾传感器.pdf
816.4 KB, 下载次数: 18
 楼主| 发表于 2025-4-30 14:56:04 | 显示全部楼层
土壤氮磷钾传感器是假的,如有不信的可以弄一杯氮肥的水,把传感器放进去试试
发表于 2025-4-30 22:40:46 | 显示全部楼层
撒一把盐 就知道 有多假了,但支持技术分享
GMT+8, 2025-9-18 02:50 , Processed in 0.297876 second(s), 9 queries , MemCached On.
