查看: 835|回复: 2
[人体存在] 求助:ld2410b传感器刷机问题,用flasher刷成功,可状态不对
发表于 2025-2-20 23:07:39 | 显示全部楼层 |阅读模式
哪位大佬能解哈,用esphome网站刷bin怎么都不成功,最后用nodemcu pyflasher刷成功了,结果ha中能看见可是就是状态不对。。
esphome:
  friendly_name: ld2410B-1
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "BmOoUN1dK9Dhy98wgqBL3y4+NmTNxtk2k8SoOoSr0A0="
ota:
  - platform: esphome
    password: "7a82a368c74eb78290a2e7c6c72867b1"
wifi:
  ssid: "0---"
  password: "g-----"
  ap:
    ssid: "Ld2410B-1 Fallback Hotspot"
    password: "PJCthn31QRW2"
captive_portal:
web_server:
  port: 80
uart:
  # id: uart1
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
ld2410:
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
    out_pin_presence_status:
      name: out pin presence status
  - platform: ld2410
    light:
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
    g0:
      move_energy:
        name: g0 move energy
      still_energy:
        name: g0 still energy
    g1:
      move_energy:
        name: g1 move energy
      still_energy:
        name: g1 still energy
    g2:
      move_energy:
        name: g2 move energy
      still_energy:
        name: g2 still energy
    g3:
      move_energy:
        name: g3 move energy
      still_energy:
        name: g3 still energy
    g4:
      move_energy:
        name: g4 move energy
      still_energy:
        name: g4 still energy
    g5:
      move_energy:
        name: g5 move energy
      still_energy:
        name: g5 still energy
    g6:
      move_energy:
        name: g6 move energy
      still_energy:
        name: g6 still energy
    g7:
      move_energy:
        name: g7 move energy
      still_energy:
        name: g7 still energy
    g8:
      move_energy:
        name: g8 move energy
      still_energy:
        name: g8 still energy
switch:
  - platform: ld2410
    engineering_mode:
    bluetooth:
      name: "control bluetooth"
number:
  - platform: ld2410
    timeout:
    light_threshold:
      name: light threshold
    max_move_distance_gate:
      name: max move distance gate
    max_still_distance_gate:
      name: max still distance gate
    g0:
      move_threshold:
        name: g0 move threshold
      still_threshold:
        name: g0 still threshold
    g1:
      move_threshold:
        name: g1 move threshold
      still_threshold:
        name: g1 still threshold
    g2:
      move_threshold:
        name: g2 move threshold
      still_threshold:
        name: g2 still threshold
    g3:
      move_threshold:
        name: g3 move threshold
      still_threshold:
        name: g3 still threshold
    g4:
      move_threshold:
        name: g4 move threshold
      still_threshold:
        name: g4 still threshold
    g5:
      move_threshold:
        name: g5 move threshold
      still_threshold:
        name: g5 still threshold
    g6:
      move_threshold:
        name: g6 move threshold
      still_threshold:
        name: g6 still threshold
    g7:
      move_threshold:
        name: g7 move threshold
      still_threshold:
        name: g7 still threshold
    g8:
      move_threshold:
        name: g8 move threshold
      still_threshold:
        name: g8 still threshold
button:
  - platform: ld2410
    factory_reset:
    restart:
    query_params:
text_sensor:
  - platform: ld2410
    version:
    mac_address:
select:
  - platform: ld2410
    distance_resolution:
      name: "distance resolution"
    baud_rate:
    light_function:
    out_pin_level:
      name: out pin level
发表于 2025-2-21 18:02:27 | 显示全部楼层
直接刷bin我也不成功,但是web引导刷好esphome后再ota更新bin档就可以了
发表于 2025-8-25 15:36:14 | 显示全部楼层
我发现好像是esphome 代码中有 人体存在(仅测试过LD2402)的话 ,如果未接人体存在硬件时,esp32c3会反复重启,无法进入系统。
GMT+8, 2025-9-16 03:14 , Processed in 0.758022 second(s), 14 queries , MemCached On.
