查看: 1031|回复: 1
[经验分享] 大华乐橙摄像头API
发表于 2025-2-10 08:41:45 | 显示全部楼层 |阅读模式
大华官方有提供API, 通过APPID和APPSECRET获取Token;
[PHP]
//签名规则
function getPayloadArray(){
        global $AppId, $appSecret;
        $time = time();
        $nonce = uniqid();
        $result = array(
                'system' => array(
                        'ver'   => '1.0',
                        'appId' => $AppId,
                        'sign'  => md5("time:{$time},nonce:{$nonce},appSecret:{$appSecret}"),
                        'time'  => $time,
                        'nonce' => $nonce
                'id' => '98a7a257-c4e4-4db3-a2d3-d97a3836b87c',
                'params'=> array()
        return $result;
//获取Token
function getToken(){
        $url = 'https://openapi.lechange.cn/openapi/accessToken';
        $payloadArray = getPayloadArray();
        $payloadJson = arrayToJson($payloadArray);
        $res = cURL($url, $method = 'POST', $header = [], $payloadJson);
        $resArr = jsonToArray($res);
        if($resArr['result']['code'] == '0'){
                $accessToken = jsonToArray($res)['result']['data']['accessToken'];
                $expireTime = jsonToArray($res)['result']['data']['expireTime'];
                writeCookie($cookieName = 'accessToken', $cookieValue = $accessToken, $expireTime);
                return $accessToken;
        return $res;
//获取直播列表
function liveUrl($accessToken){
        $url = 'https://openapi.lechange.cn/openapi/liveList';
        $payloadArray['params'] = array(
                'token' => $accessToken,
                'queryRange' => '1-50'
                return arrayToJson($resArr['result']['data']['lives']);
        return $res;
发表于 2025-2-10 08:46:44 | 显示全部楼层
有啥用有啥用有啥用有啥用
GMT+8, 2025-9-16 03:02 , Processed in 0.804019 second(s), 10 queries , MemCached On.
