查看: 24517|回复: 12
[修仙教程] Appdaemon实现空调伴侣的万能遥控功能
发表于 2018-2-22 16:53:15 | 显示全部楼层 |阅读模式
首先,介于很多人对appdaemon的误解,这里重新介绍下appdaemon。
AppDaemon is a loosely coupled, multithreaded, sandboxed python execution environment for writing automation apps for Home Assistant home automation software. It also provides a configurable dashboard (HADashboard) suitable for wall mounted tablets.
我就翻第一句:Appdaemon是一个松耦合,多线程,沙盒的python执行环境,为的是给Home Assistant写自动化自动化自动化程序。
HADashboard是通过appdaemon实现的一个前端。
ha本身有自动化那干嘛费这劲开发出这个平台呢,因为原生用yaml和jinjia2的那套东西对于有点编程基础的人来说那就是一坨屎。
简单的ifttt能应付,触发情况复杂的时候condition满天飞,再加上template那惊人的可读性。。。。
吐槽到此为止,下面是正文:
本文实现的内容,是女神和大神在把miio和空调伴侣插件完善之前的过度方案,而且和自动化关系不大,旨在展示ad平台的强大功能。
硬件:
1. 空调伴侣
2. 4进2出的HDMI矩阵 可红外控制(共8个绝对信号)
input_select:
  hdmi_output_a:
    icon: mdi:monitor
    options:
      - PC
      - VTEN
      - PS4
      - Xbox One
  hdmi_output_b:
    icon: mdi:projector
    options:
      - PC
      - VTEN
      - PS4
      - Xbox One
然后在ad的apps文件夹下创建HDMI_Matrix.py,其中的红外码获取见附件。
import appdaemon.appapi as appapi
import miio
import codecs
ip = '10.0.0.148'
Container = miio.Device.discover(ip)
token = str(codecs.encode(Container.checksum, 'hex'), 'utf-8')
AC_Partner = miio.Device(ip, token)
class HDMImatrix(appapi.AppDaemon):
    def initialize(self):
        self.listen_state(self.select_input, "input_select.hdmi_output_a")
        self.listen_state(self.select_input, "input_select.hdmi_output_b")
    def select_input(self, entity, attribute, old, new, kwargs):
        output_a_state = self.get_state("input_select.hdmi_output_a")
        output_b_state = self.get_state("input_select.hdmi_output_b")
        HDMI_Matrix = {
            "A1": "FE00000000000094701fff9Aff080026270E003600AB00E401C603810FAA138825A843000000000000000001010101010101010000010101000100010100000001000105420742061A",
            "A2": "FE00000000000094701fff9Bff0800282711003600AB00E401C503800FA61388259C4300000000000000000101010101010101000101010100000001000000000101010542074207420651",
            "A3": "FE00000000000094701FFF9dFF0800262711003600AB00E301C503800FA2138825954300000000000000000101010101010101000000010100010001010100000100010542074206FC",
            "A4": "FE00000000000094701FFF9eFF0800262712003600AA00E401C503800FA51388259A430000000000000000010101010101010100010100010000000100000100010101054207420604",
            "B1": "FE00000000000094701fff96ff080026270A003700AB00E501C303820FA6138825A043000000000000000001010101010101010100000101000100000101000001000105420742060E",
            "B2": "FE00000000000094701fff97ff080026270B003600AB00E501C603810FAA138825A843000000000000000001010101010101010000000101000000010101000001010105420742061B",
            "B3": "FE00000000000094701fff98ff080026270C003600AB00E401C503800FA51388259C430000000000000000010101010101010101000101010001000001000000010001054207420607",
            "B4": "FE00000000000094701fff99ff080026270D003600AB00E401C503800FA51388259D430000000000000000010101010101010100000101010000000101000000010101054207420608"
        if output_a_state == 'PC':
            ircode = HDMI_Matrix['A1']
            if AC_Partner.send('send_ir_code', [ircode]) == ['ok']:
                self.log("A1 Sent!")
        elif output_a_state == 'VTEN':
            ircode = HDMI_Matrix['A2']
                self.log("A2 Sent!")
        elif output_a_state == 'PS4':
            ircode = HDMI_Matrix['A3']
                self.log("A3 Sent!")
        elif output_a_state == 'Xbox One':
            ircode = HDMI_Matrix['A4']
                self.log("A4 Sent!")
        if output_b_state == 'PC':
            ircode = HDMI_Matrix['B1']
                self.log("B1 Sent!")
        elif output_b_state == 'VTEN':
            ircode = HDMI_Matrix['B2']
                self.log("B2 Sent!")
        elif output_b_state == 'PS4':
            ircode = HDMI_Matrix['B3']
                self.log("B3 Sent!")
        elif output_b_state == 'Xbox One':
            ircode = HDMI_Matrix['B4']
                self.log("B4 Sent!")
最后在apps.yaml下加入这个app的modul和class,当然如果有变量可以在这里传递变量到app(具体参照ad的文档),所有操作和dashboard无异。
HDMI_Matrix:
  module: HDMI_Matrix
  class: HDMImatrix
以上所有操作,除了添加选择器设备时候需要重启ha,其他不用做任何重载操作,包括今后对app的任何修改,ad会自动载入并应用。
本版内所有用yaml写的自动化都可以用appdaemon实现,越复杂的自动化ad的优势越大。
当然对于不懂python的人来说,前面的所有请无视。这里还是要提供下接地气的方式。
附件提供了一个脚本,2个json文件,是在空调伴侣插件出来之前我瞎弄的空伴脚本,其中空调控制部分已经不需要了。
红外的学习可以在bash命令行实现,ha接入红外的发送可以用command line方式,这样就不用appdaemon了,当然正道是等完整插件。
使用方式在domoticz论坛我已经写过这里就不再赘述。
acpartner.py
6.79 KB, 下载次数: 20
mi_ircode.json
1.54 KB, 下载次数: 21
presets.json
2.18 KB, 下载次数: 10
参与人数 2金钱 +40 收起 理由
lidicn + 20 终于遇到会AppDaemon的了!
+ 20 大神的世界,我们不懂~
发表于 2018-2-22 17:09:37 | 显示全部楼层
大神玩法,学习了!目测可玩性和灵活性很高!发到自动化区,浪费了,我移到综合区吧
sank
发表于 2018-2-22 18:15:34 | 显示全部楼层
群里看到的,过来捧个场。谢谢大大的分享
anda 手机认证
发表于 2018-2-22 19:03:25 | 显示全部楼层
厉害,谢谢分享
发表于 2018-2-27 11:02:16 | 显示全部楼层
学习学习
wqqs 手机认证
活跃会员
发表于 2018-3-3 11:04:53 | 显示全部楼层
谢谢分享!
发表于 2018-3-5 10:56:12 | 显示全部楼层
虽然是小白,很多东西看不懂,但是也要关注和学习
发表于 2018-3-19 22:46:48 | 显示全部楼层
虽然看不太懂 但是我觉得这个帖子要火
发表于 2018-3-27 09:21:03 | 显示全部楼层
Jones 发表于 2018-2-22 17:09
大神玩法,学习了!目测可玩性和灵活性很高!发到自动化区,浪费了,我移到综合区吧 ...
求下,小米空调伴侣的那个插件在哪里啊。纯小白。
发表于 2018-3-29 00:48:32 | 显示全部楼层
有日立空調的插件嗎?
GMT+8, 2025-9-15 05:11 , Processed in 0.562603 second(s), 15 queries , MemCached On.
