楼主:
[进阶教程] Ubuntu/Debian/树莓派安装MQTT(无坑版)
发表于 2019-7-7 22:06:14 | 显示全部楼层
感谢分享,就在找这个
发表于 2019-7-7 23:16:29 | 显示全部楼层
厉害厉害 66666666666
发表于 2019-8-23 14:40:04 | 显示全部楼层
受教了。但是没有效果图
发表于 2019-8-29 20:05:30 | 显示全部楼层
大佬,我是在 Arch 上安装的。创建 /etc/mosquitto/conf.d/mqtt.conf 文件后再把端口映射到外网。使用你那测试网站始终无法成功。
不过我修改了/etc/mosquitto/mosquitto.conf 文件在启动程序,用  systemctl status mosquitto 查看其状态,输出的内容是:
● mosquitto.service - Mosquitto MQTT Broker daemon
   Loaded: loaded (/usr/lib/systemd/system/mosquitto.service; enabled; vendor preset: disabled)
   Active: active (running) since Thu 2019-08-29 19:54:49 CST; 10min ago
 Main PID: 3553 (mosquitto)
    Tasks: 1 (limit: 4578)
   Memory: 2.1M
   CGroup: /system.slice/mosquitto.service
           └─3553 /usr/bin/mosquitto -c /etc/mosquitto/mosquitto.conf
Aug 29 19:54:49 archlinux systemd[1]: Started Mosquitto MQTT Broker daemon.
Aug 29 19:54:50 archlinux mosquitto[3553]: 1567079690: mosquitto version 1.6.4 starting
Aug 29 19:54:50 archlinux mosquitto[3553]: 1567079690: Config loaded from /etc/mosquitto/mosquitto.conf.
Aug 29 19:54:50 archlinux mosquitto[3553]: 1567079690: Opening websockets listen socket on port 9001.
请问这样是不是也是能用了?还是哪里有问题?
发表于 2019-8-31 19:24:43 | 显示全部楼层
感谢分享呜呜呜
发表于 2019-10-16 23:33:24 | 显示全部楼层
学习一下
发表于 2019-11-2 14:35:55 | 显示全部楼层
感谢代码分享
发表于 2019-11-10 15:05:06 | 显示全部楼层
总是提示   连接失败:不支持Websocket协议!
怎么重置密码
发表于 2020-2-12 15:45:47 | 显示全部楼层
谢谢分享
发表于 2020-2-20 20:55:37 | 显示全部楼层
root@aml:~# sudo /etc/init.d/mosquitto start
[....] Starting mosquitto (via systemctl): mosquitto.serviceJob for mosquitto.service failed because the control process exited with error code.
See "systemctl status mosquitto.service" and "journalctl -xe" for details.
failed!
大佬这是什么原因啊
GMT+8, 2025-9-7 04:59 , Processed in 0.999268 second(s), 11 queries , MemCached On.
