楼主:
[进阶教程] Ubuntu/Debian/树莓派安装MQTT(无坑版)
发表于 2018-3-21 12:05:11 | 显示全部楼层
谢谢楼下分享
发表于 2018-4-8 12:00:37 | 显示全部楼层
学会了,期待更多基础教程
发表于 2018-4-8 17:08:25 | 显示全部楼层
MAPGPS 发表于 2018-3-17 19:20
HA内置MQTT呀,没必要再装一个吧!
只需在configuration.yaml文件里加入以下一行即可:
新版的hassbian1.3.2
2018-03-16-Hassbian.zip
有这个问题,不能自动安装,只能手工安装
发表于 2018-5-3 22:58:07 | 显示全部楼层
666666666666666666666
发表于 2018-5-24 21:43:49 | 显示全部楼层
android@localhost:~$ mosquitto_sub -d -u mqtt -P mqtt -t dev/test
Client mosqsub/16766-localhost sending CONNECT
Client mosqsub/16766-localhost received CONNACK
Connection Refused: not authorised.
android@localhost:~$ mosquitto_pub -d -u mqtt -P mqtt -t dev/test -m "hello world"
Client mosqpub/16995-localhost sending CONNECT
Client mosqpub/16995-localhost received CONNACK
Error: The connection was refused.
囧大,求帮助
发表于 2018-5-30 23:09:02 | 显示全部楼层
很好  学习了
发表于 2018-6-12 19:21:07 | 显示全部楼层
非官方相关报道发个短信发给谁的
发表于 2018-7-27 11:56:28 | 显示全部楼层
下车下车下车下车
sdvd
发表于 2018-8-3 12:16:47 | 显示全部楼层
谢谢分享
发表于 2018-9-5 16:49:00 | 显示全部楼层
刚刚发现是因为修改过hosts文件导致现问题已经解决。
同时升级版本1.4.15
sudo apt-add-repository ppa:mosquitto-dev/mosquitto-ppa
sudo apt-get update
sudo apt-get install mosquitto mosquitto-clients
原帖:
执行mosquitto_sub -d -u mqtt -P mqtt -t dev/test的时候会反馈Unable to connect (Lookup error.).
查日志/var/log/mosquitto/mosquitto.log
root@hassio:/home/ubuntu# cat /var/log/mosquitto/mosquitto.log
1536137022: mosquitto version 1.4.8 (build date Thu, 01 Mar 2018 09:34:49 -0500) starting
1536137022: Config loaded from /etc/mosquitto/mosquitto.conf.
1536137022: Opening ipv4 listen socket on port 1883.
1536137022: Opening ipv6 listen socket on port 1883.
1536137175: Error in poll: Interrupted system call.
1536137175: mosquitto version 1.4.8 terminating
1536137221: mosquitto version 1.4.8 (build date Thu, 01 Mar 2018 09:34:49 -0500) starting
请教问题原因
GMT+8, 2025-9-7 04:57 , Processed in 0.423153 second(s), 10 queries , MemCached On.
