查看: 1453|回复: 7
[进阶教程] 找真正的MQTT大师,请教关于删除的无效实体的问题
发表于 2024-12-27 19:42:06 | 显示全部楼层 |阅读模式
Bob 体重
sensor.bob_ti_zhong
MQTT
Mary 体重
sensor.mary_ti_zhong
MQTT
Timmy 体重
sensor.timmy_ti_zhong
MQTT
关于上述三个有冬瓜加载项自带的米家体脂称生成的实体,我用了各种办法无法删除,重启后会有。方法包括:
1、对应主题homeassistant/sensor/miscale/Bob/config 发空信息,可以删除,但是系统重启后又来了;
2、删除core.restore_state中对应的对象如下:
      "state": {"entity_id":"sensor.bob_ti_zhong","state":"unknown","attributes":{"state_class":"measurement","icon":"mdi:scale-bathroom","friendly_name":"Bob 体重"},"last_changed":"2024-12-27T11:32:11.054070+00:00","last_reported":"2024-12-27T11:32:11.054070+00:00","last_updated":"2024-12-27T11:32:11.054070+00:00","context":{"id":"01JG3Y6SNEQ39YJS9SPTFKK46F","parent_id":null,"user_id":null}},
      "extra_data": {
        "native_value": null,
        "native_unit_of_measurement": null
      "last_seen": "2024-12-27T11:32:17.228566+00:00"
      "state": {"entity_id":"sensor.mary_ti_zhong","state":"unknown","attributes":{"state_class":"measurement","icon":"mdi:scale-bathroom","friendly_name":"Mary 体重"},"last_changed":"2024-12-27T11:32:11.059760+00:00","last_reported":"2024-12-27T11:32:11.059760+00:00","last_updated":"2024-12-27T11:32:11.059760+00:00","context":{"id":"01JG3Y6SNKDFD8KCNR4GFS8WTJ","parent_id":null,"user_id":null}},
      "extra_data": {
      "state": {"entity_id":"sensor.timmy_ti_zhong","state":"unknown","attributes":{"state_class":"measurement","icon":"mdi:scale-bathroom","friendly_name":"Timmy 体重"},"last_changed":"2024-12-27T11:32:11.062729+00:00","last_reported":"2024-12-27T11:32:11.062729+00:00","last_updated":"2024-12-27T11:32:11.062729+00:00","context":{"id":"01JG3Y6SNP7H35HR2C9ZYGECC3","parent_id":null,"user_id":null}},
      "extra_data": {
3、包括卸载MQTT自带插件和Mosquitto broker 加载项。
均无效。
无解了!
发表于 2024-12-27 21:32:58 | 显示全部楼层
曾经的经验,retain:true
 楼主| 发表于 2024-12-27 21:53:41 | 显示全部楼层
诗yu光明 发表于 2024-12-27 21:32
曾经的经验,retain:true
不能说的清楚的吗?
发表于 2024-12-27 22:31:31 | 显示全部楼层
lambilly 发表于 2024-12-27 21:53
不能说的清楚的吗?
mqtt.png 类似于nodered中的这样,保存选是,retain:true。再发送一次空消息
发表于 2024-12-28 00:13:54 | 显示全部楼层
电脑安装MQTT Explorer,删除那个主题咯。还有的话,找找发布这个主题的插件或者自定义组件呀啥的,看重载或重启的时候是不是会自动发布这个主题。
 楼主| 发表于 2024-12-28 20:47:47 | 显示全部楼层
诗yu光明 发表于 2024-12-28 00:13
电脑安装MQTT Explorer,删除那个主题咯。还有的话,找找发布这个主题的插件或者自定义组件呀啥的,看重 ...
收到,谢谢。
发表于 2025-1-5 01:40:51 | 显示全部楼层
请问解决了吗,我也遇到了这问题
 楼主| 发表于 2025-1-6 09:03:30 | 显示全部楼层
枫糖叶落 发表于 2025-1-5 01:40
请问解决了吗,我也遇到了这问题
解决了,就是发空指令,起初几次在HA中带的MQTT插件发,不行,后面下载了WINDOWS的MQTT终端发好象就可以了。
GMT+8, 2025-9-16 03:16 , Processed in 0.056916 second(s), 11 queries , MemCached On.
