查看: 1481|回复: 9
[插件集成] nodered安装节点报错,请教一下各位大佬
发表于 2024-12-19 14:04:00 | 显示全部楼层 |阅读模式
被卡住三天了,解决不了啊
2024-12-19T06:26:20.247Z 安装 : node-red-contrib-http-request 0.1.14
2024-12-19T06:26:12.754Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict node-red-contrib-http-request@0.1.14
2024-12-19T06:34:08.984Z [err] npm error code ETIMEDOUT
2024-12-19T06:34:08.984Z [err] npm error syscall connect
2024-12-19T06:34:08.984Z [err] npm error errno ETIMEDOUT
2024-12-19T06:34:08.986Z [err] npm error network request to https://registry.npmjs.org/node-red-contrib-http-request failed, reason: connect ETIMEDOUT 2606:4700::6810:23:443
2024-12-19T06:34:08.986Z [err] npm error network This is a problem related to network connectivity.
2024-12-19T06:34:08.986Z [err] npm error network In most cases you are behind a proxy or have bad network settings.
2024-12-19T06:34:08.986Z [err] npm error network If you are behind a proxy, please make sure that the
2024-12-19T06:34:08.986Z [err] npm error network 'proxy' config is set properly.  See: 'npm help config'
2024-12-19T06:34:08.987Z [err]
2024-12-19T06:34:08.987Z [err] npm error A complete log of this run can be found in: /root/.npm/_logs/2024-12-19T06_26_12_830Z-debug-0.log
发表于 2024-12-19 14:25:44 | 显示全部楼层
你这样问要卡30天,啥也没有
发表于 2024-12-19 17:19:39 | 显示全部楼层
不是写着吗?npm 连不上。全局
发表于 2024-12-19 21:43:58 | 显示全部楼层
翻啊翻q
 楼主| 发表于 2024-12-20 13:05:21 | 显示全部楼层
zhanfu86 发表于 2024-12-19 17:19
npm error network request to https://registry.npmjs.org/node-red-contrib-http-request failed, reason ...
有梯子的啊
 楼主| 发表于 2024-12-20 13:06:32 | 显示全部楼层
有梯子的啊
发表于 2024-12-20 18:05:20 | 显示全部楼层
我猜要换国内源
发表于 2024-12-20 19:53:52 | 显示全部楼层
这种事,问GPT,绝对好使
发表于 2025-2-3 21:49:28 | 显示全部楼层
解决了吗?我的方法是禁用ha的ipv6
 楼主| 发表于 2025-2-7 13:50:58 | 显示全部楼层
cxw0102 发表于 2025-2-3 21:49
解决了吗?我的方法是禁用ha的ipv6
解决了,就是移动网络问题,我是虚拟机安装得,把虚拟机拷贝到单位后就全解决了
GMT+8, 2025-9-21 04:49 , Processed in 0.094008 second(s), 10 queries , MemCached On.
