楼主: liuxing
[求助] N1 安装homeassistant卡正在准备界面
发表于 2024-12-9 23:47:47 | 显示全部楼层 |阅读模式
如题:有哪位大佬路过帮忙看看,有梯子
[color=var(--success-color)]2024-12-09 23:41:01.850 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemuarm-64-homeassistant:landingpage to ghcr.io/home-assistant/qemuarm-64-homeassistant:2024.12.1
[color=var(--success-color)]2024-12-09 23:41:01.852 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemuarm-64-homeassistant with tag 2024.12.1.
[color=var(--error-color)]2024-12-09 23:41:32.335 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemuarm-64-homeassistant:2024.12.1: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.12.1&fromImage=ghcr.io%2Fhome-assistant%2Fqemuarm-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: no such host")
[color=var(--warning-color)]2024-12-09 23:41:32.337 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
发表于 2024-12-10 00:09:21 来自手机 | 显示全部楼层
有梯子,那大概率dns污染
 楼主| 发表于 2024-12-10 00:12:29 | 显示全部楼层
hassmingovo 发表于 2024-12-10 00:09
有梯子,那大概率dns污染
有方法查看吗
发表于 2024-12-10 10:20:00 | 显示全部楼层
 楼主| 发表于 2024-12-15 01:22:27 | 显示全部楼层
hassmingovo 发表于 2024-12-10 10:20
https://docker.aityp.com/image/ghcr.io/home-assistant/qemuarm-64-homeassistant:2024.8.0.dev2024072 ...
解决了,改host就好了
发表于 2024-12-15 12:19:13 | 显示全部楼层
liuxing 发表于 2024-12-15 01:22
解决了,改host就好了
github的一些地址国内dns污染严重,可以搞个smartdns分流下
GMT+8, 2025-5-8 11:06 , Processed in 0.432283 second(s), 25 queries .
